Rear Bumper w/Swingout Tire Carrier Follow Along - Page 57 - JeepForum.com
 9Likes
post #841 of 2229 Old 12-02-2009, 08:39 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I use the same basic bumper for CJs, YJs and TJs. The only thing I change is the mounting plate bolt pattern (YJ and TJ are the same).
BESRK is offline
post #842 of 2229 Old 12-02-2009, 09:12 PM
bogiemj
Thanks a lot! I really appreciate it.
bogiemj is offline
post #843 of 2229 Old 12-02-2009, 09:47 PM
LuckRider
LuckRider's Avatar
Eddie, have you ever thought about threading the mounting plates like you did for the shipping bolt? I don't know if that would be a PITA, but it would force you to have to bolt from the rear side of the crossmember... not sure if many would like that.... Then again, you do still need access to that backside to bolt it in anyways... Just some random thoughts I have had.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #844 of 2229 Old 12-03-2009, 04:42 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I have considered it. I know there are a few bumper manufacturers out there that do it (I think Zach does).
Couple reasons I don't..
I now cut my mounting plate holes on my plasma table so they're slotted 1" for some adjustability left/right. If I drill/tap the plates, the only adjustability would be from the small slots in the rear crossmember itself.
Also, I'm pretty much a "one-man-band" (although my son now helps me a few days a week). To drill/tap eight 1/2" holes for each bumper would add on a considerable amount of time.. time=$$ so price would go up. I could outsource drilled/tapped blocks from a CNC machine shop but again... more overhead=$$.
I think using bolts thru a mounting plate also make it a little easier to install the bumper. You can get an outer bolt thru each mounting plate, lift the bumper into position and rely on those 2 bolts to help hold the bumper up while you install the rest of the bolts.
BESRK is offline
post #845 of 2229 Old 12-03-2009, 09:56 PM
kevin_tall_jeep
I just want to say that there is alot of really good fabricators here on jeep forums. I am not the greatest fab'er so this took me a long time to finish this. I want to thank all of the input that gave me the ideas for my bumper
Now I have the whole bumper finished and painted with two clevis mounts and 3/4" d-rings. I finished it a while ago just havn't got around to posting the pictures. Sorry for the poor quality, cell phone pics. I'll post finished pics this weekend
kevin_tall_jeep is offline
post #846 of 2229 Old 12-04-2009, 12:15 AM
Curt's_97
Mines a little different. Thought i'd post up. Swing out swing down i made with my poop kinker.
After a couple seasons of beating she's still holding strong.
And when i first put it together a couple years ago
Curt's_97 is offline
post #847 of 2229 Old 12-04-2009, 04:41 PM
green89yj
wait. How does it swing down?
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #848 of 2229 Old 12-04-2009, 10:25 PM
prd_cdn
prd_cdn's Avatar
I think he pulls the Snap Locks out, and it rotates on the tube.
Excellent design !!! Very Cool and ingenious !!!
prd_cdn is offline
post #849 of 2229 Old 12-05-2009, 11:16 AM
RichardD
1987 YJ Wrangler
That is one really cool setup! Nice work.
RichardD is offline
post #850 of 2229 Old 12-05-2009, 11:47 AM
Curt's_97
Thanks guys. Yup, it's all sleeved and has pins.
post #851 of 2229 Old 12-05-2009, 12:10 PM
green89yj
OH. Gotcha. I was lookin at those but couldn't tell what they were.
post #852 of 2229 Old 12-06-2009, 02:24 PM
kevin_tall_jeep
Finished pics
post #853 of 2229 Old 12-11-2009, 01:56 PM
Flajeeper1
1987 YJ Wrangler
Carrier locking pin
Eddie, your work is beautiful. I have a suggestion to reduce the wear on the paint where the locking pin to hold the carrier open rubs on the steel surface before it drops into the locking hole. They make thin nylon material with adhesive on one side that could be mounted where the pin rubs. It would protect the paint. It can be cut with sissors.
Flajeeper1 is offline
post #854 of 2229 Old 12-11-2009, 07:48 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've thought about that.. you can get that stuff from McMaster Carr. However, the pin can be lifted, turned and locked in the "up" position so it doesn't drag at all. On my own personal bumper, I just let it drag/rust and shoot it with Rustoleum a couple times a year... mainly when I'm painting "rock rash" at the same time.
... and thank you for the kind words!
BESRK is offline
post #855 of 2229 Old 12-13-2009, 09:53 AM
ROADDOG516
Hey Eddie thanks for the paint tips. Now that Im done fabbing my rear bumper, wondering if you have any pics or ideas for a front bumper with a winch. I just got a new winch and based on your rear bumper design am going to build a front bumper with winch mount. Im going simple with D rings and a small winch gaurd, and going to shape the same as the rear just shorter. Not trying to be a PITA but your ideas are great and just looking for best templates to go on. Thanks again. PS anyone else who has great ideas please jump in...
YJ=THE LAST REAL JEEP!
1966 Willys
1993 YJ
2013 JKU Sahara
ROADDOG516 is offline
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
