#46 | ||
Vendor
I do the same thing. Between buying steel and new tools/equipment I do not make anything either it seems.
Have a great day!!! Zach Vaughn. AtoZ Fabrication, Inc. 570-385-3931--shop 570-385-3932--fax MADE IN AMERICA---and proud of it!!! Now scheduling cage/custom work so call now to get on the calendar. CHECK OUT OUR DIY FAB PARTS FOR SALE!! We also offer the best prices available on: Advance Adapters Clayton Offroad Suspension Amsteel Winchline and accessories Staun beadlocks and deflators |
#47 |
I stickied this thread ! thanks BESRK for a great write up .
JIM :{>
originally posted by Mikeythefireman : Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there. Custom Stuff--- [URL=http://www.JCfabanddesign.com]JC Fab & Design[/URL] ORANGE JEEP CLUB MEMBER # 1 1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff 2003 Inca Gold Rubicon , <------ Sissy jeep :) |
#48 |
GROUND POUNDER
Woohoo! No problem. I've got somemore ideas bouncing aroung in my head. As I spill them out onto metal I'll take pics and writeup some other stuff.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#49 |
SO BUMPERS ARE GONE DAMN IT I WAS SSAVING MY PENNIES FOR FRONT AND REAR AND JUST ORDER A COMBO! your neighbor officially sucks!
[SIZE=2][B]HI, my name is phlex234 and i approve this message because it's my destiny[/B][/SIZE] [B]Jeep 2.5 Low Output club member #2 92 Red YJ, 3.5 Bds lift, 1" body lift, 1" motor mount lift, 33 in tires, long travel DT3000 shocks, m.o.r.e. 3/8 boomerang shackels, 4:56 gears, Tj flares, rock-it man front and rear bumper, Terraflex SYE and Tom Woods CV driveshaft, herculined tub, custom homemade rocker panels, powered by the almighty 4 cylinder[/B] [URL=http://www.jeepforum.com/forum/showthread.php?t=155355]NEVER FORGET[/URL] |
#50 |
GROUND POUNDER
Yeah... I'd really like to find out which one it was. I know I made quite a bit of noise (with the 7" grinder) but I always limited grinding between 10am and 5pm. Sorry for those of you who planned on purchasing these bumpers... I really am sorry as it was a source of extra income for the Jeeps... now I gotta dust off the credit cards again
#51 | |
85 CJ7 4.0L/SM465/Dana300/AMC20/Dana30, MPFI,154K miles - 33" 12.5's Pro Comp MT's, one piece axles, Detroit Softlocker rear, Lock Rite front, Warn Hubs, 4.56 R&P, 4" BDS lift, Warn x8000i, Warn winch guard, Hi-Lift, Tuffy console, Four X Dr. rocker guards, Rock Hard sport cage, Kilby OBA with 1.75 gal tank and York 10.3cc compressor, Tube fenders by GenRight Offroad, Fabricated rear bumper and tire carrier. Last edited by Jeep Daddy; 10-31-2004 at 09:29 AM.. |
#52 |
GROUND POUNDER
Man!! I wish I could've bought steel at some of those prices before I made about 50 bumpers! Only reason I can think of for the higher prices that I paid are that this is the only steel distributor here in Newport News. I might have been able to go southside (Norfolk or Portsmouth) but it would have been a long trek with metal sticking out the back of my pickup truck. Maybe when I start up making bumpers again I'll look for a better distributor. I should have another trailer by then to haul larger quantities too. That's cool that you've got a distributor that sells small quantities too...
#53 | |
Today I tried cutting a piece of 6" x 1/4" steel down the middle so I'd have 2 3" wide pieces but that chop saw is not dealing with a large piece that well. I wonder if they have different grades of cut off abrasive wheels????
85 CJ7 4.0L/SM465/Dana300/AMC20/Dana30, MPFI,154K miles - 33" 12.5's Pro Comp MT's, one piece axles, Detroit Softlocker rear, Lock Rite front, Warn Hubs, 4.56 R&P, 4" BDS lift, Warn x8000i, Warn winch guard, Hi-Lift, Tuffy console, Four X Dr. rocker guards, Rock Hard sport cage, Kilby OBA with 1.75 gal tank and York 10.3cc compressor, Tube fenders by GenRight Offroad, Fabricated rear bumper and tire carrier. |
#54 |
GROUND POUNDER
I've tried cutting steel down the middle with a chopsaw in the past and it doesn't work too well. Finally dished out the $$$ for a plasma cutter and it is one of the most used machines in the shop. It's awesome. I've used it to cut metal lengthwise, burn off frozen leaf spring ubolts that used to be a PITA, and gouge out old welds on brackets or mistakes. It zips thru that 1/4" steel like butter. If you just need a small piece of something, you can pick up some steel at Lowe's too. That steel distributor here won't even sell scrap steel. It's full length or nothing. Then, they charge $1 a cut to cut it in half. Guess you can do that when you're the only store in town..
#55 | |
#56 |
GROUND POUNDER
Once you use the plasma, you'll buy one... sooner or later
The 110 volt plasmas struggle a little with 1/4" but the 220 volt ones shouldn't. Most of the 220 volt cutters will use either 110 or 220 and they switch automatically. All you have to do is make an adapter plug for it.
#57 |
BESRK,
when finishing w/ POR-15 and the Chassis black, what equipment / settings are you using to spray it ?? also, in your experiance what if the difference between conventional POR-15 and the Chassis Black ?? how would you compare these finishes to powdercoat ?? thanks,
[SIZE=1][B]01 silver aniv. edn[/B], 6cyl 5sp D44 dual top 2" coil spacer SSV kit | 265/70R16 AT REVO's on Moab wheels AirLift towing assist bladders (rear), cabin controlled air TopFive rack (ski / surf) | Corbeau seats Hella FF1000 lamps | ...little stuff... [URL=http://www.sounddomain.com/id/tanzjeep]false floor slick stereo install[/URL] |
#58 |
GROUND POUNDER
It's hard to say what pressure I'm shooting at as I just turn the air pressure down on the gun until I get the pattern I want. I use a HVLP gravity feed gun that uses a max pressure of 17 psi (if I remember correctly). With my old Devilbliss gun (siphon feed), I set the pressure to about 50-55 psi and shot it. The difference between the two is that the POR 15 (base) flows out a lot nicer (into all the nooks and crannies) and is tougher when dry. The Chassis Black can be shot "wet" which will leave a semi gloss finish or you can turn down the air a little bit and sort of "spatter" it on which will provide a matte finish. Powder coating is definately tougher to begin with.. but POR 15 is pretty tough too (especially if you spray on several thin coats) and can be touched up easily. However, POR 15's shelf (after opening the can) is probably about 2 months or so (depending on humidity) so plan it out by buying what you can use at the moment.. pints, quarts or gallons.
#59 |
I am building a similar tyre carrier for my TJ but using tubes. I will post the pics once I am done. On the issue of the neighbour – yes it sux but there is a reason one cannot run a business from a residential area. Here is the situation in South Africa. (hope you never have the same problem in the US) In apartheid years you were not even allowed to own a welder, grinder or any other manufacturing type tools. You needed to show them a manufacturer’s license before you could get a power tool. Those were harder to get than a firearm license. Now in post apartheid South Africa the situation is different. They wanted to stimulate the economy and create jobs. In this free for all environment we don’t have quite residential areas anymore (except if you are willing to fork out $$$$$) Your neighbour might be building in his garage for a while and one morning you wake up there is a mini factory next door. They allow this without upgrading the roads, water or power supplies. We have power outages every day for a couple of hours because the system that was designed for home use is now supplying power to 10 factories. Your children can’t ride their bicycles in the street as there are big trucks driving up and down. The roads are being damaged by the trucks - Makes for a great offroad track right on my doorstep. So although your neighbour is a #@%$#@%# , you need to sacrifice some things to protect your (and every other American’s) way of life. BTW Extremely neat welding. Have you ever done coded welding before? ![]()
[FONT=Verdana]04 Sport 4" Currie lift with Anti-Rock Rock Krawler 4 link rear Skyjacker 2" body lift Safari Snorkel 35" Procomp X-terrain Mickey Thompson Classic lock Aussie locker front & rear 4.88 gears CV Drive shaft 4WD SYE 215 Ponies I6[/FONT] |
#60 |
GROUND POUNDER
I've gotten over the whole thing. I think it was the grinding that pissed them off the most. No big deal. I retire from the military in a couple of years and will probably pursue something then. As for right now, I can focus more attention on my projects. For one, I just towed home a military M1008 truck with a Dana 60/GM 14 Bolt combo that are gonna be stuffed under my 71 CJ5. So... I guess the peaceful days of no grinding are about to come to a "grinding" halt
As for the welding, no.. I haven't done any code work. I bought my first welder about 20 years ago and have just learned by reading, practicing... and then practicing some more. Next major project.. probably a 3 link suspension for the rear of my Big Lime!! I'll be sure to photo document the whole thing too... ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
