Rear Bumper w/Swingout Tire Carrier Follow Along - Page 17 - JeepForum.com
 9Likes
post #241 of 2228 Old 05-22-2007, 11:21 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hmmmm.. I can still see the pics. Maybe Cardomain was down for awhile? At any rate, here are the pics of my current mounting system. I like it. Still use it. As for mounting the hinge spindle, that's pretty straightforward. Just make sure that you mount it so that it will clear your tailgate when opened. Nothing sucks worse than to finish a bumper, paint it, bolt it on and have the tailgate open right into the hinge tube.. chipping a nice black paint job. Ask me how I know.
Basic latch catch and angle iron to lock end of arm...
Latch mounted at an angle to pull arm forward and downward locking it into the angle iron. Make sure to mount latch high enough so it clears the bumper when you open and close it. Also be careful as the latch opens up a long way. It is possible to slam the latch into the bumper and bend it.
BESRK is offline
post #242 of 2228 Old 05-22-2007, 07:50 PM
jeepteejay
Yeah, Cardomain was down. I got an email about it today from them.
Thanks though...hope I can do the same with mine, though my bumper sits in closer to the body than yours does, but I'll make it work.
jeepteejay is offline
post #243 of 2228 Old 07-03-2007, 10:35 PM
Idahomie
Latch?????
Where can I get one of those latches?
Idahomie is offline
post #244 of 2228 Old 07-04-2007, 07:41 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
You have to buy it from me for $299
I get them from smallparts.com part #341-R.. they cost about $31 plus shipping. That is for the Zinc plated model.. you can get them in stainless too for about double the price.. here's the link....scroll down to the 2000lb model.
http://www.smallparts.com/products/d...lclamps331.cfm
BESRK is offline
post #245 of 2228 Old 07-04-2007, 08:12 AM
foreman1063
foreman1063's Avatar
This place has pretty good prices on Destaco latches.
http://www.jtsmach.com/jtswebshop/To...rodcode=TA132c
foreman1063 is offline
post #246 of 2228 Old 07-04-2007, 05:57 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I checked that link.. it does have the Model 341 latch for about $22 but you really want the 341-R as it has the "Toggle Plus" locking system. It requires a separate trigger latch to be pulled before it can be opened up.. no chance of an accidental/unintentional opening..
BESRK is offline
post #247 of 2228 Old 07-05-2007, 02:55 PM
foreman1063
Good point, I wish I had the safety latch on mine.
post #248 of 2228 Old 07-06-2007, 06:09 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If you have the 341 latch, it should have the holes where the safety trigger goes. You could probably cut out some metal to make a latch trigger or.. just drill the latch for a small pin that goes thru the latch arm to keep it closed.
BESRK is offline
post #249 of 2228 Old 07-06-2007, 08:14 AM
foreman1063
Nah, I have the 331 latch. I'm planning on installing a safety pin just haven't got a roundtuit. Wish I would have seen the "R" series first.
post #250 of 2228 Old 07-16-2007, 05:14 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Was just looking at the first rear swingaway I made.. I've changed quite a bit of stuff since then..
Then..
Now.. (only had a trailer spare with the correct lug pattern).
BESRK is offline
post #251 of 2228 Old 07-19-2007, 09:29 AM
Scotch740
Scotch740's Avatar
I really like your design. I will be taking a lot of ideas from it when I build my own. Although I think I will be using some of DR. Hooks rear winch mount ideas also.
I am glad to see the bars on the side to protect the back side of your body. With my Unlimited I am really nervous about coming down on a pointy rock there and CRUNCH. Then its time for a wheel base strech and body cutting.
Any pics of a bumper with those side bars on a jeep?
If the bank only knew what I was doing to "their" Jeep as my dad puts it
Scotch740 is offline
post #252 of 2228 Old 07-19-2007, 10:36 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Not yet.. that was really the first one I did.. at the customer's request. I've gotten spoiled wheeling in a buggy.. I forget sometimes that normal rigs have sheetmetal that doesn't fare too well when ground against the rocks..
Eventually, if I get enough of them out there, I'm sure someone will either post or email me pics of one of my bumpers with that stuff on it.. when that happens, I'll post pics here.
BESRK is offline
post #253 of 2228 Old 07-30-2007, 08:46 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Here's a couple pics of that bumper on the vehicle.. a nice LJ.
BESRK is offline
post #254 of 2228 Old 07-30-2007, 08:51 PM
Scotch740
Scotch740's Avatar
WOW that looks awesome. Those are going on my design list for my rear. Nice LJ, whos ever it is.
post #255 of 2228 Old 08-13-2007, 10:03 AM
Chris_
Will you be making any of these to sell soon? About how much would you charge for something like this if you can make one to sell?
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
