Rear Bumper w/Swingout Tire Carrier Follow Along - Page 14 - JeepForum.com
 9Likes
post #196 of 2229 Old 11-09-2006, 07:03 PM
GOLDNUGGET
Great work on the bumper. Do you have any pics of your front bumpers? I'm working on my design now. I would love to see some pics. Please email me at jeffgooch@alltel.net if it is not too much trouble.
Thanks.
GOLDNUGGET is offline
post #197 of 2229 Old 11-10-2006, 06:56 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Thanks.. my front bumpers are pretty basic with the occasional stinger or 2" receiver here and there.. One thing I try and do on CJs is capture the side bolt holes for mounting a front bumper..
Did one for a buddy's XJ last a while back too... it was a PITA to piece it all together.. winch plate is just sitting on the bumper that's why it looks crooked..
BESRK is offline
post #198 of 2229 Old 11-19-2006, 07:07 AM
Overdrive
Besrk,
Thanks for the inspiration. I have completed my front bumper (a while ago but didn't post it here) and am hard at work on the rear...
Overdrive is offline
post #199 of 2229 Old 11-19-2006, 04:33 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Overdrive, your link to your pic isn't working..
Edit: It's working now..
BESRK is offline
post #200 of 2229 Old 11-20-2006, 05:54 AM
Overdrive
Hmmm, that's weird. I see the pic on my PC.
Here is the link:
http://www.team-lan.com/Coppermine/a..._TJ_Bumper.JPG
post #201 of 2229 Old 11-20-2006, 05:01 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nice! Are those two holes open to the inside of the bumper or are they sealed off? Can you get a close pic of one, I'd kinda like to see how you did that..
BESRK is offline
post #202 of 2229 Old 11-21-2006, 03:28 PM
Overdrive
They are all the way through. It took a LONG time to blend them in. Here are some closeups:
Links if the above doesn't work.
http://www.team-lan.com/Coppermine/a...bumper%201.JPG
http://www.team-lan.com/Coppermine/a...bumper%202.JPG
http://www.team-lan.com/Coppermine/a...bumper%203.JPG
Here are some pics of the rear. Of course I decided to get fancy with the rear. Angled and inset. The part I am having trouble engineering is the insets for the rear. You can see my first attempt at an inset "box" but it's going to take a LOT of grinding with a small dremel in order to smooth out the inner welds. Any ideas?
Links to above pics:
http://www.team-lan.com/Coppermine/a...bumper%207.JPG
http://www.team-lan.com/Coppermine/a...bumper%208.JPG
post #203 of 2229 Old 11-21-2006, 04:50 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Use a strong air grinder with bigger bits. Those holes on the front bumper are really well done. You've got more patience than I do..
BESRK is offline
post #204 of 2229 Old 11-23-2006, 06:54 AM
Overdrive
Thanks for the feedback!
I have a quick question on the spindle. I finally tracked down the correct DOM tubing but want to make sure of your initial specs:
"First, I cut the pivot tube from the 2 1/2" DOM tube.. 4 1/4" long. Then I cut an inner bearing separator from 2" OD pipe and rosette welded it in 4 places to hole it in place..
So, the lenth I need is 4 1/4" right?
post #205 of 2229 Old 11-23-2006, 08:28 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
It actually works out a little better if you use 4.5" instead. Slide your inner separator in it, drop the bearings in it, slide the seal in the bottom and drop it on your spindle with the washer and nut cinched down by hand and the dust cap on top. Then, insert the spindle in the bumper and adjust everything so that you have about 1/4"-3/8" from the bottom of the pivot tube to the top of the bumper. Tack your spindle in place, tack your separator in place, disassemble and weld up everything. If you do it like that, it makes sure everything fits. I did one assembly a long time ago that fit well but I didn't leave any room for the dust cap so I had to start over. Also, with that size DOM, the bearings and seal my be a sloppy fit. I take a center punch and "dimple" the inside where the bearing races sit. I also "dimple" the area where the seal sits. That raises the metal and keeps the seal from falling out the bottom. You can also "glue" it in with a little weatherstripping adhesive or silicone.
Now that I've got a lathe, I'm gonna look around for some thicker wall DOM and turn it down so I don't have to use a weld in separator and I can make it a press fit for the bearings and seal.
BESRK is offline
post #206 of 2229 Old 11-26-2006, 03:02 PM
drew76924
drew76924's Avatar
someone already problably asked this question but will this rear bumper fit a TJ... nice work i really like it
RIP: 97' TJ on 35's (rolled)
03' Mustang GT Turbo Vert
drew76924 is offline
post #207 of 2229 Old 11-27-2006, 05:25 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Yeah.. the only thing I do different between CJ and TJ/TJ bumpers is use a different mounting plate and I add a couple small brackets that catch the bolt hole under the frame of the YJ/TJ. Biggest thing to watch out for is the tire carrier dimensions. I had a buddy who built himself a nice bumper but it was a few inches narrower than mine. He asked me to "retrofit" it with a tire carrier. Even though I moved the carrier pivot out as far as I could, it still kept him from opening his tailgate all the way. We knew that was gonna be an issue but I figured I'd just toss that info out there..
BESRK is offline
post #208 of 2229 Old 11-27-2006, 06:19 PM
drew76924
drew76924's Avatar
ya cuz i mean i have 31's right now but soon i'm uppin it to 33's and i don't want to risk it with the stock carrier
post #209 of 2229 Old 11-28-2006, 06:42 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Necessity is the Mother of all invention right?.. I started this tire carrier because I wanted the wife's CJ to be able to lug around a 33" tire. Thing's have kinda snowballed since then..
BESRK is offline
post #210 of 2229 Old 12-01-2006, 04:07 AM
Overdrive
Besrk,
OK, finally got the correct DOM (took 2 tries). 2 1/2" OD, I had to purchase about 3 1/2 feet of it but I went ahead and had them cut me a 4 1/2" piece for the hinge since my cheap chop saw would have done a horrible job making a nice cut.
I had a hard time finding the bearing race seperator (2" OD pipe for the inside). The best I could do was a 1.75" OD piece of pipe that "loosly" fits inside the DOM. I will try HD or Lowes this weekend to see if I can find a better fitting one. My question is how long to make the insert with the DOM being 4.5"
Thanks for your help!
Also picked up 20' of 2" x 3" and 20' of 2" x 2" square tube for the carrier. Cost me $95. Seems like most steel places don't want to sell small quantities. They charge almost the same in "cutting fees" if you want a smaller than 20' piece than if you purchased the whole thing. Oh well, I can always find a use for steel!
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
