Rear Bumper w/Swingout Tire Carrier Follow Along - Page 139 - JeepForum.com
 6Likes
post #2071 of 2212 Old 03-01-2014, 07:10 PM
Mattific
Mine
Comes back from powder coat Monday
Mattific is online now
post #2072 of 2212 Old 03-01-2014, 07:32 PM
tdkask
Not trying to be negative, but I have really rattled the heck out of my rear bumper wheeling. I'd be careful to make that rack really solidly mounted if headed down more than a mild trail. Again, I like the idea, but don't know if it would hold up to serious abuse with weight that far up a couple verticle poles. Keep us posted. I'd like to find a good solution that can take a bearing.
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #2073 of 2212 Old 03-01-2014, 09:10 PM
RKCWLER
tdkask: Thanks for the insight.
I was thinking of a gusset between the A and the upright receivers. I am not into black diamond trails, yet. But I feel confident, when done, that the rack will get me to any fly fishing hole off the beaten path.
Eat-Sleep-Fish
RKCWLER is offline
post #2074 of 2212 Old 03-02-2014, 04:42 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Originally Posted by Mattific View Post
Mine
Attachment 1132657
Nice! I'd hate to see what happens if you ever back the rear corner of your Jeep into another vehicle.. it'll be like a can opener!!
BESRK is offline
post #2075 of 2212 Old 03-02-2014, 11:54 AM
Mattific
Or if my knee comes in contact with it
post #2076 of 2212 Old 03-03-2014, 10:17 PM
ShebZJ
Originally Posted by BESRK View Post
Thanks for those kind words!
Actually, I cut the tube to 58 1/2" long (on my drycut saw). That leaves a little "wiggle room" at the ends. After cutting both sides, I trim off the "drop" with a Portaband.
Thanks for the insight. I tried cutting one on the Torchmate but obviously my programming needs some work as when I flipped it over, the cuts were slightly off. Simply inverting didn't workout perfectly, so maybe i'll have to make a center reference point to work off of.
In a previous post you mentioned buying your receivers instead of making them. After making a few and calculating the time, it is definitely not worth the effort. I found some for a great price, but I can only find them powdercoated. I did some experimenting with removing the powdercoating but the labour was not worth it in my opinion. Do you have a source for receivers that are bare steel?
Thanks Eddie, much appreciated!
97 ZJ, 8" total lift on IRO Springs w/RC Long Arms, 33" KM2's, Black Rock Krawlers, KOR Steering Box Brace, IRO HD OTK Steering and Rear Adjustable Track Bar, Custom Bumper, XRC8 Winch, NP231 swap with SYE, 8.8 and Trussed HP D30...both Spartan locked!
ShebZJ is offline
post #2077 of 2212 Old 03-03-2014, 10:41 PM
tdkask
Maybe it maybe not helpful, but Walmart sells a receiver labeled as an adapter for about $12 in the automotive section. In the last couple bumper builds I did the hitch was flush recessed, so I just used 2.5"x.25" wall square tube (2"x2" I.D.) that I had lying around.
tdkask is offline
post #2078 of 2212 Old 03-04-2014, 10:07 AM
ShebZJ
I like the flush recessed look, and i do that on front bumpers, but for the rear I like to have the option of doing either. Furthermore, on certain designed swingouts, i have the upper reciever and having one pre-made would be a great time saver, because there are only so many hours in the day and it seems there are never enough! Eddie has said this on more than one occasion and i get it now!
I have found what i want for $5 bucks a piece which is crazy cheap, but like i said, they are powdercoated Ugh!
ShebZJ is offline
post #2079 of 2212 Old 03-04-2014, 10:25 AM
cjjon7
1983 CJ7
Amazon.com has some really nice ones for 12 each, raw steel and 8" in length
cjjon7 is offline
post #2080 of 2212 Old 03-04-2014, 11:50 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I was getting my Tubes from a place called Jem's Tubes out of Michigan. I think the last batch I got (100) was about $7 each shipped. However, the wait time became an issue so I ended up going to eBay and ordering from either Jeg's or Summit. They're about $14ea but they're raw steel, and usually sitting at my doorstep 3 days after the order. Sometimes, ya just gotta pay for convenience.
ShebZJ.. on those bumper tubes. I don't flip them end for end, I roll them over. I cut 2 at a time.. back to back. After the torch cuts the one side, I flip both bumpers over and swap them for each other.. then cut them again.
I lay a "spacer" piece of tubing up against the "X" axis of the table.. to square up the bumpers and scoot them far enough from the X side so they don't hit the stepper motor on the gantry. I've got the "starting measurement" wrote down in my notes.
Basically, I lay the bumper in place (slide the ends up against a stop), jog the torch all the way as far as it will go to "negative Y", zero the table locations, use the "point" feature to move the torch to the start point (using that measurement that I have wrote down), rezero the table.. and hit start.
If I had bigger balls, I'd lay out 10 bumpers and do them all at once.. or ruin them all at once
BESRK is offline
post #2081 of 2212 Old 03-04-2014, 05:17 PM
ShebZJ
LOL so true. Gambling is not my thing, or i might try that also.
Thanks for the advice. I'll need to change how i did it for sure. My situation differs slightly because my table is only a 4x4 so the "blank" is just off the end of the table and out of range for the taper on one end. I can get both shackle mounts, reciever and the one taper, but then i have to flip end to end for the last taper. I suppose if i was more savy, i could put the blank diagonally, but i doubt i could do it acurately.
I'll play around with my drawing and hope it works better next time. As it sits now, this one is close enough that i can still use it so a bumper building i will go!
Cheers for the great thread and insights. It's pretty awesome to see where you started and how far you've come in the last 10 years.
ShebZJ is offline
post #2082 of 2212 Old 03-04-2014, 06:54 PM
O1dSoldier
1978 CJ5
#jatepper
Hate to hi-jack the thread but I've been trying to get in touch with you about your roll bar tie-ins you make. I'd like a set if your still making them.
Paul
Sent from my Etch-A-Sketch
O1dSoldier is offline
post #2083 of 2212 Old 03-05-2014, 08:44 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Originally Posted by O1dSoldier View Post
#jatepper
You might be able to get ahold of him thru his Targetman.com website..
BESRK is offline
post #2084 of 2212 Old 03-05-2014, 01:35 PM
munypit
Besrk, do you sell the "new" style locking pin assembly for the tire carrier and also need some bumper tie in plates for a cj 7. Received the shackle pieces, they look great. Also thanks for keeping this going so long, I'm getting ready to start my rear bumper build.
munypit is offline
post #2085 of 2212 Old 03-05-2014, 02:08 PM
O1dSoldier
1978 CJ5
jatepper
I hadn't considered that. Thanks.
Paul
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
