Rear Bumper w/Swingout Tire Carrier Follow Along - Page 138 - JeepForum.com
 9Likes
post #2056 of 2228 Old 02-23-2014, 07:05 PM
tdkask
Not sure if I ever shared my modded latch, and it's not very easily mass produced, but I have been extremely pleased with how well this locks into place. Maybe a bit overboard visually, too... but I think it's cool.
It's made from a massive wrench i found rusting in the mud at a salvage yard. I built the pivot point by drilling through the wrench (hard as hell... wish I'd have had a plasma cutter then) and sleeving on either side with steel tubing. It pivots on a really big grade 8 bolt, at the unthreaded part. The upper pin that locks it in place is the same that BESRK puts on the J-lock setup. The lower tab it locks onto was mocked up in cardboard and finessed after installed.
Works 100% great. Only drawback is that I have to disassemble and clean (wire wheel) and grease, then reassemble the pin lock at top about every 4-6 months... 5 minutes work probably.
Locks in TIGHT... no give, no rattle, never a fear of hitting it on anything. I'd build this design on a bumper again, only the pivot would be prettier now that I have a lathe and a plasma cutter. Even if it weren't a over-sized wrench, one of you guys with a CNC plasma could make a handle with the same principle. (I recommend a long handle... I push to get this locked in so tight.)
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #2057 of 2228 Old 02-23-2014, 07:14 PM
RKCWLER
Originally Posted by RKCWLER
I like that.. does that style of latch have the "toggle plus" trigger? The little latch that keeps it from popping open.
Yes it does. It is the 344. It's basically the same one as the 341. Only a right angle. I will post more pictures later.
I think I saw this same wrench latch on another forum or post.
Eat-Sleep-Fish
RKCWLER is offline
post #2058 of 2228 Old 02-23-2014, 08:22 PM
RKCWLER
Here is a picture that shows the locking lever. Got it from MCM for about $70. I know it's almost double the cost of the 341, but.............it works for me.
RKCWLER is offline
post #2059 of 2228 Old 02-24-2014, 06:15 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Wow.. those are indeed kinda pricey!
One of these days, I need to start making my own latch system. Add that to the mile-long list of projects..
BESRK is offline
post #2060 of 2228 Old 02-24-2014, 01:15 PM
ShebZJ
I've been following this thread for years! Great craftsmanship and quite frankly, a great role model. Your advice and guidance in this thread and many others have been incredibly valuable.
I have a Torchmate and i was watching your video about cutting bumper blanks using it. Very cool. I know you said that your bumper blanks are 58" long, but in the vid it seems that some of that is cut away when you do the taper. What is the final width of the blank?
Thanks again for all the help.
97 ZJ, 8" total lift on IRO Springs w/RC Long Arms, 33" KM2's, Black Rock Krawlers, KOR Steering Box Brace, IRO HD OTK Steering and Rear Adjustable Track Bar, Custom Bumper, XRC8 Winch, NP231 swap with SYE, 8.8 and Trussed HP D30...both Spartan locked!
ShebZJ is offline
post #2061 of 2228 Old 02-25-2014, 07:08 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Thanks for those kind words!
Actually, I cut the tube to 58 1/2" long (on my drycut saw). That leaves a little "wiggle room" at the ends. After cutting both sides, I trim off the "drop" with a Portaband.
BESRK is offline
post #2062 of 2228 Old 02-25-2014, 07:17 PM
cjjon7
1983 CJ7
TDKASK thats a pretty righteous looking setup youve got there, clever!
What do you guys recommend for a suitable De sta CO latch ( in terms of Max load rating ) for runing a 36" tire and probably some gear on the swinger as well.... 2k seems like the obvious choice but dang those are expensive!!!
cjjon7 is offline
post #2063 of 2228 Old 02-25-2014, 08:58 PM
JJeeper09
Eddie, saw my old jeep the other night with your bumpers on it. John in the silver tj bought some bumpers from you a little while back. He seems to love them and they are solid! Wish I never sold my rear bumper!
Looks good as always and I hope you are doing well!
James
JJeeper09 is offline
post #2064 of 2228 Old 02-26-2014, 06:30 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hey James! Yep.. still alive and kicking.. been busy between my "dayjob" and the shop. At least we're gettin more daylight each day, so that's good!
BESRK is offline
post #2065 of 2228 Old 02-26-2014, 07:30 PM
RKCWLER
Did I say rack? Maybe a build thread?
RKCWLER is offline
post #2066 of 2228 Old 02-27-2014, 08:46 PM
cjjon7
1983 CJ7
Anyone have a good design for a removable over-the-tire rack for a triangular swingout like the one above?
Im looking to have all sorts of accessory mounts on mine but am struggling with a mental design block on how to proceed.
cjjon7 is offline
post #2067 of 2228 Old 02-28-2014, 02:42 PM
TanMan99
Originally Posted by cjjon7 View Post
Would you mind snapping a picture of your destaco latch setup on your swingout? Im trying to figure out.how guys are mounting them effectively
BESRK beat me to it but here is mine. Looks much better painted with bedliner.
TanMan99 is offline
post #2068 of 2228 Old 02-28-2014, 02:45 PM
TanMan99
Very nice setup. I may have to modify mine a bit.
TanMan99 is offline
post #2069 of 2228 Old 02-28-2014, 02:55 PM
RKCWLER
Anyone have a good design for a removable over-the-tire rack for a triangular swingout like the one above? Im looking to have all sorts of accessory mounts on mine but am struggling with a mental design block on how to proceed.
The one I'm building will be removable. Notice the telescoping tubing with the holes in it. This is so I can adjusted up or down with a locking pin. I will also be adding mounds for my highlift jack, fuel tank and water if necessary.
Eat-Sleep-Fish
RKCWLER is offline
post #2070 of 2228 Old 03-01-2014, 05:59 PM
cjjon7
1983 CJ7
That will be nice, i was planning on using u bolts through plates to attach mine but I do like how yours will lift off with pins
cjjon7 is offline
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
