Rear Bumper w/Swingout Tire Carrier Follow Along - Page 137 - JeepForum.com
 5Likes
post #2041 of 2187 Old 02-13-2014, 04:22 PM
RKCWLER
I dislike wire brushes as much as the next guy. I have pulled a lot of pieces out of clothing, rugs and carpets (tracked in from garage). I bought this product a few weeks ago, at HD to sand the trim on the roof eaves. This morning I used it to remove the PC on my rear bumper. It worked real good, but I needed an old sand disc to complete the bottom side. I should have taken a pic before the prime coating. But here is one before removal.
(Edit: Use a dust mask and full, enclosed eye protection! My lids got swollen. Maybe allergic to the powder coating.)
My better half will be out of town this weekend (1st time in 38 years she misses V-Day & B-Day), so I will finally get started on the rear bumper this weekend. I have been delayed on yet another project I just had to make. Isn't she a beauty? Got a lot of ideas from the knife makers on Youtube.
RKCWLER is offline
post #2042 of 2187 Old 02-13-2014, 05:03 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I use those stripping disks (normally, the black ones) for cleaning bumper blanks. They do a great job of cleaning up 2x4 tubes. Really knock down the mill scale quickly.
BESRK is offline
post #2043 of 2187 Old 02-13-2014, 05:31 PM
zachv
That is funny--we just started using them heavily as well. I had one in the tool box for years and one of mu guys wound up trying it for removing paint from an XJ we were doing a long arm install on and it worked great. They remove paint and grime, but not the material like a flap disc. No we have a bunch in various sizes. We get them from Lehigh Valley Abrasives.
Have a great day!!!
Zach Vaughn.
570-385-3931--shop
zachv is offline
post #2044 of 2187 Old 02-13-2014, 08:36 PM
RKCWLER
BESRK - What grit do you use to remove scale?
I have used these maxi disc and they do a good job of various sanding, deburring, paint removal and even polishing, if you use a high number grit. I have a few in 60 grit now, but my most used is the standard 36 grit flat sand disc. I keep the used ones to deburr and smooth without gouging.
RKCWLER is offline
post #2045 of 2187 Old 02-15-2014, 06:47 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
For bumper blanks, I use those Black Stripping Disks to clean up the surface and remove the scale.
I don't usually remove mill scale from flat plate. I just leave it in place. If it's something I'm gonna powdercoat, I toss it in the blasting cabinet and take it down to "white metal".
For general metal removal, I'll often start with a 7" grinder and a 36 or 48 grit disk. I then switch to the 4.5" grinder and a 60 grit type 29. I also use the "Maxie" style fat disks.
I get my disks from AA Abrasives... ordering in bulk.
If I really needed a lot of flat stuff without mill scale, I'd probably just order P&O plate. The problem with that, is the humidity here in VA isn't kind to P&O that sits on the shelf for a long time. It ends up flash rusting pretty quick. The mill scale is pretty good about keeping rust at bay for at least a month or two..
BESRK is offline
post #2046 of 2187 Old 02-15-2014, 08:56 AM
tdkask
You can knock down flash rust pretty easily with muratic acid or even just "The Works" toilet cleaner (active ingredient is HCL acid). I just toss it on a drum or a couple sawhorses and rince with acid and then water. For best results, follow up with a phosphoric acid to protect.
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #2047 of 2187 Old 02-21-2014, 06:54 AM
RKCWLER
Here's what the tire carrier looks like now. I would like to mount the 3rd light in the same area. Don't want to cut up the OEM enclosure. Has anyone see a similar size/shape brake light that can be mounted in a sheet metal enclosure?
RKCWLER is offline
post #2048 of 2187 Old 02-21-2014, 12:06 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've used round "push-in" trailer lights (2.5"dia) inside a short piece of 2.5" muffler tube.
BESRK is offline
post #2049 of 2187 Old 02-21-2014, 12:24 PM
fourwheelin
Like!
fourwheelin is offline
post #2050 of 2187 Old 02-21-2014, 02:26 PM
TanMan99
Trailer light that is trimmed to fit and ran the wires through the plate. I put some silicone on the back so i can take the tire off and it stays on.
TanMan99 is offline
post #2051 of 2187 Old 02-21-2014, 09:13 PM
cjjon7
1983 CJ7
Would you mind snapping a picture of your destaco latch setup on your swingout? Im trying to figure out.how guys are mounting them effectively
cjjon7 is offline
post #2052 of 2187 Old 02-22-2014, 06:09 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Here's how I do mine..
I use a short piece (about 3" long) of 2" square tube to attach the "hook" for the De Sta Co. I attach the actual latch to the end of the swingarm with a plate that I cut on my plasma table. The latch, then pulls the arm "down and forward".. locking it against that square tube.. and the latch tongue.
BESRK is offline
post #2053 of 2187 Old 02-22-2014, 07:23 AM
cjjon7
1983 CJ7
Ahh very nice, that clears it all up right there. Was unsure on where to mount the hook
cjjon7 is offline
post #2054 of 2187 Old 02-23-2014, 02:16 PM
RKCWLER
BESRK - I really liked your latch design, but I wanted a lower profile. It took a little more work, but I am only making one.
As far as the 3rd brake light, I may just find one to fit into a 2" x 2" tube.
Look closely and you will see parts to make a removable rack.
RKCWLER is offline
post #2055 of 2187 Old 02-23-2014, 06:20 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I like that.. does that style of latch have the "toggle plus" trigger? The little latch that keeps it from popping open..
BESRK is offline
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 09:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-15-2009 12:14 AM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 10:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 04:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 12:11 PM
