Rear Bumper w/Swingout Tire Carrier Follow Along - Page 133 - JeepForum.com
 9Likes
post #1981 of 2229 Old 07-18-2013, 08:30 AM
Jeep Daddy
Jeep Daddy's Avatar
Unique
If this isn't unique, I don't know what is..
Originally Posted by tdkask View Post
I don't think I ever shared my recent "upgrade" latch mechanism. I like to re-purpose stuff in builds when possible.
I de-rusted a large wrench I found in the mud at a metal salvage yard and did some cutting/welding to make this. Please excuse the ugly flux-core welds.
It uses the angle of the open end to help keep it back and down, and a pull-pin latch (like in Eddie's J-hook setup) is the latch for it. Works great.
This a GPF bumper with a tire carrier I added on, BTW.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #1982 of 2229 Old 07-19-2013, 02:41 PM
Harold_Ray
That's neat!!
Harold_Ray is offline
post #1983 of 2229 Old 07-19-2013, 02:59 PM
rikkards
rikkards's Avatar
Originally Posted by BESRK View Post
The bottom edge of my bumpers sit above the bottom edge of the frame. I just put a "Z" bend in the mounting tab that goes from the bottom of the bumper to the frame. Before I had a pressbrake, I used to do the bend with a vise and a hammer.
With regards to positioning that "hook" for the latch...
I bolt the latch in place on the end of the arm. I then clamp the 2"x2" square tube "tower" to the backside of the end of the arm. I hold the latch hook in place and slip the latch's "Ubolt" over it. I then tack the hook in place on the tower. That ensures a good fit between the hook and the ubolt.
My latch mounting plates are also slightly raised in relation to the end of the arm. This helps the latch's Ubolt clear the bumper..
Decided I can't live with it. I have started taking off the latch and hook. The hook is off already. Need to grind down the remnants and clean up the hook. I should be able to do the same thing with the latch. Out of curiousity what thickness is the steel you used for the extension the latch is attached to? It looks like at least 3/16th
Machete don't tweet
- Machete
rikkards is offline
post #1984 of 2229 Old 07-19-2013, 04:02 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
It's 3/8".. I drill and tap it for the latch attachment bolts.
BESRK is offline
post #1985 of 2229 Old 07-29-2013, 06:18 AM
E. Humphries
Eddie, I sent you a pm
Black Jeep Society #369
E. Humphries is offline
post #1986 of 2229 Old 08-02-2013, 03:30 PM
TURBevO8
On the rear swing out can you get 5x4.5 and 5x5.5 dbl bolt pattern as an option?
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is offline
post #1987 of 2229 Old 08-02-2013, 05:17 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I cut my tire plates with both patterns. However, I usually use "Black" Grade 8 Bolts (1/2"-20 x 1.5" long) as the lug studs, I weld them on the back side to keep them in place.
If I pound in splined 1/2" wheel studs, they could be knocked out and reused in the alternate lug pattern.
BESRK is offline
post #1988 of 2229 Old 08-03-2013, 05:32 AM
TURBevO8
Thanks!
TURBevO8 is offline
post #1989 of 2229 Old 08-07-2013, 05:45 AM
rikkards
rikkards's Avatar
Well I got mine all painted up and mounted. I would post pictures but look at Bzerks and it pretty much looks the same (just not as nice welds). The biggest bear was getting the frame tie ins installed. I had got the A2Z ones as I had ordered a bunch of stuff from them already and threw it in. The problem was there are three holes on the frame side and it is the two closest to the back that it uses and the nuts do not have any easy way of mounting. After some trial and error including putting the nut in a wrench and taping it in. I found the easiest way was to stick the nut on the end of your finger and put it up against the hole and then put the nut on. Once it had turned enough then put a wrench over the nut and then tighten.
Otherwise it doesn't rattle a bit and came out nice. Unfortunately now I have to finish renovating our ensuite bathroom as I have neglected it during this whole affair
Also big thanks to Eddie for doing this thread and everyone else for providing inspiration!
Machete don't tweet
- Machete
rikkards is offline
post #1990 of 2229 Old 08-21-2013, 11:19 AM
Roadhawg
Does anyone have a drawing or CAD or sketchup file of the tyre carrier with some dimensions on it?
Ive been planning to build this whole thing with a buddy who owns a metalwork shop before an epic 2week trip into Botswana in October....
i was gonna measure out the tyre carrier next week but like an idiot i went and got into a motorcycle crash last week and both my hands are cast up (plates and pins had to go in)...hence the ****ty typing also.
anyone got a drawing i can copy/cheat off ?
Stu.
'06 Sahara, on Koni's and KM2's
'84 Mk1 Golf Rust Rod
Roadhawg is online now
post #1991 of 2229 Old 08-21-2013, 07:06 PM
rikkards
rikkards's Avatar
Post #1970 is a rough one I threw together. It gets you about 90% there
Machete don't tweet
- Machete
rikkards is offline
post #1992 of 2229 Old 08-22-2013, 02:45 AM
Roadhawg
Thanks man....but im looking for the swing arm specifically. ive got the bumper drawn up already.
thanks anyway
Stu.
post #1993 of 2229 Old 08-22-2013, 03:47 AM
rikkards
rikkards's Avatar
thanks anyway
Doh, that was one I had found which is a lot nicer drawn than mine but didn't have the swingaway portion. Warning it is ugly.
What you need is this
Bottom tube: 42"
Left diagonal: 22.63"
Right Diagonal: 22.63"
Vertical: 16"
The pivot point is around 7" from the edge of the bumper assuming the bumper is 58"
Machete don't tweet
- Machete
rikkards is offline
post #1994 of 2229 Old 09-06-2013, 07:03 PM
nlopez2518
2015 JK Wrangler
Bumpers
Hey Beserk, I pm you asking for prices for front and rear bumpers with rear tire swing for a 06 TJ. Also, can you make rocker guards with a step for the same jeep?
nlopez2518 is offline
post #1995 of 2229 Old 09-07-2013, 03:21 PM
jstman
If you are going to make Rocker Guards, I want some too!!
jstman is offline
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
