Rear Bumper w/Swingout Tire Carrier Follow Along - Page 130 - JeepForum.com
 9Likes
post #1936 of 2230 Old 03-30-2013, 12:05 AM
WSS
WSS's Avatar
1972 CJ5
Couple steps closer to the tow bar being usable. I am using H-3 pins(7/8" dia.). they are a bit long, so I will cut, re-taper and re-drill for the hitch pin clip. Should make it a "no-tool" tow bar.
WSS
If you are a Purist, don't click here:
My CJ5 Build and fun stuff:
WSS is offline
post #1937 of 2230 Old 04-02-2013, 05:10 AM
highred
1979 CJ7
Originally Posted by BESRK View Post
1" trailer spindle rated for 1000lbs (Spindle
Besrk,
Your description calls for this 1" trailer spindle. However, the description in the link you provide at etrailer.com says this is a 1 1/4" spindle.
Is this the correct spindle to order?
Thanks,
Rob
highred is offline
post #1938 of 2230 Old 04-02-2013, 05:05 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Rob.. the diameter of the spindle where the seal rides, is 1 1/4" dia. However, the part that the bearings ride on, is 1" dia.
I stopped using those small spindles a short time after this thread was started. I purchased a lathe so I could make my own spindle tubes, and stepped up to the 1.375"dia (at the lower bearing) spindles (1.75" dia at the seal portion).
BESRK is offline
post #1939 of 2230 Old 04-09-2013, 09:19 PM
jbparisi
WSS
So I used a 1"x3" clevis, a couple 1" washers and a hitch pin. May not look as fancy as that nice red paint job but it certainly did the trick.
jbparisi is offline
post #1940 of 2230 Old 04-09-2013, 09:36 PM
tdkask
Slightly different tow bar setup on mine, but same clevis mounts, I believe (unless changed in last year?), but I used 7/8" shackles that fit very tight in there (actually had to clearance a couple thousandths to fit) so I can leave all the time as shackles, and use to hold tow system.
I always like dual use utilitarianism, and also occasionally use my GPF bumper(s) as a work surface or anvil.
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #1941 of 2230 Old 04-09-2013, 11:44 PM
WSS
WSS's Avatar
1972 CJ5
Paint is just a color! Function is where it's at. You got it. I like the compact pins. Did you drill or cut the holes?
WSS is offline
post #1942 of 2230 Old 04-10-2013, 09:59 AM
jbparisi
I did neither
Eddie made these for me (THANKS EDDIE !!) & I suspect he cut them out.
I also have 7/8 shackles and tried the screw pin idea. It worked but there was just a little play. The 1" clevis pin is nice and snug but allows smooth pivot with little play.
jbparisi is offline
post #1943 of 2230 Old 04-10-2013, 10:59 AM
WSS
WSS's Avatar
1972 CJ5
I did neither
I think Eddie is on to something here. I'll post some progress pics a little later today of the rest of the set-up. I realize with these mounts, width (were the shackles are mounted) is not as important as it was with my last towbar. Truly universal, I could hook it up to many Jeeps with shackle mounts.
WSS
WSS is offline
post #1944 of 2230 Old 04-10-2013, 11:12 AM
mrott
So I've probably received the best email from my wife today in quite a while... (normally emails consist of the typical "honey do" type list)
"Fedex stopped by today and left 2 ridiculously awkward and heavy pieces of metal sitting on the front step. WTF?"
In other words, that must mean the bumper and tire swing has arrived!! I can't wait to get home today and check it out then start prepping/painting to install it this weekend and grab a few pics of it all. I'll be sure to share some BESRK/Ground Pounder pictorial results as well as a little review.
mrott is offline
post #1945 of 2230 Old 04-19-2013, 01:08 AM
WSS
WSS's Avatar
1972 CJ5
More towbar stuff..........
Getting ready for a shake down trip this weekend.
More towbar details on my build thread.
Cheers!
WSS
WSS is offline
post #1946 of 2230 Old 04-24-2013, 11:09 AM
highred
1979 CJ7
Hey Eddie,
What is the length of this front bumper? I think this is the perfect length and I would like to duplicate.
Thanks,
Rob Caldwell
highred is offline
post #1947 of 2230 Old 04-24-2013, 05:11 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Rob.. I think that one was 42" long. That one was a looooong time ago.
BESRK is offline
post #1948 of 2230 Old 04-25-2013, 03:58 PM
jstman
Way over due pictures of My bumpers from Eddie!
Eddie,
I owe you an apology, because I waited so long to post my pictures. The truth is i got busy with life and haven't had a chance to post.
As a testimony to Eddie's bumpers, everything fit like a glove! Couldn't ask for a better fit or better durability. These are HEAVY and I wouldn't be afraid to hit a brick wall with these.
The only change I would make is that I would have them powder coated instead of painting them. Maybe in the fall, I'll pull them and have them blasted and powder coated.... Maybe..lol
Lastly, Eddie made me a skid plate for the steering box, but it hasn't made it's way on the Jeep yet, nor have the Rotopax holder, nor the Hi-Lift jack holders, but these two are because I haven't bought the rotopax can or the jack.
jstman is offline
post #1949 of 2230 Old 04-25-2013, 04:14 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Shannon.. thanks for posting those pics!!! Jeep's looking great!
BESRK is offline
post #1950 of 2230 Old 04-30-2013, 09:16 PM
johnnyreb
1980 CJ5
Hey Eddie,
This is my first post since joining and finally made my way through all 130 pages. Your rear bumper and swing out has inspired me, now I have 20 feet of 2x4 tubing in the shop. You do great work. I was also impressed with the rear disc brackets I got feom you a few weeks ago.
johnnyreb is offline
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
