Rear Bumper w/Swingout Tire Carrier Follow Along - Page 127 - JeepForum.com
 7Likes
post #1891 of 2223 Old 02-06-2013, 06:57 AM
robplumm
Originally Posted by BESRK View Post
Hey Ian! Yep.. I've done a few JK bumpers. Don't really have a "production" JK bumper yet but I've got most of the parts in CAD to knock one out on the vehicle in a day or two.
As for the Shackles.. I use 3/4" Shackles from Northern. Rated at 6.5 Tons and have a 7/8" diameter pin. A 7/8" shackle has a 1" diameter pin but they'll bind in the clevis mount hole unless you clearance them with a die grinder. The pins usually have a "forging line" on them that interferes with the fit in the pin hole.
Hand is good. That liquid bandaid really worked well. I just kept it clean and brushed on the liquid bandaid a few times a day. I now keep a bottle of that stuff at the shop for all the little nicks/cuts that we get on our hands (almost daily). Now, I just need something for severe burns..
Big jar of Silver sulfadiazine
robplumm is offline
post #1892 of 2223 Old 02-14-2013, 09:20 PM
WSS
WSS's Avatar
1972 CJ5
quick fist mount question.....
I mounted four QFs today on my tailgate rack and used the supplied plastic rectangle shaped washer to put the 10-32 screw through and they set up tight but I am wondering if it is strong enough and if anyone else has mounted them different or had any problems with that mount configuration?
The Qfs will be used to hold a shovel and a ax/max using two QFs each.
WSS
WSS is online now
post #1893 of 2223 Old 02-15-2013, 05:52 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I probably wouldn't use them for the Baja 1000, but for normal wheeling, I think they're fine. If in doubt, you could run a zip tie around the center to clamp them tight.. not like you'd have to snip it off daily.
BESRK is offline
post #1894 of 2223 Old 02-16-2013, 01:47 AM
WSS
WSS's Avatar
1972 CJ5
Zip tie! Good idea. Thanks for the reply. I like the function of them and they have a decent load rating, just that 10-32 screw and the piece of plastic made me nervous.
WSS
WSS is online now
post #1895 of 2223 Old 02-16-2013, 06:12 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've shoved a 1/4" bolt thru the hole.. and used a metal washer.
BESRK is offline
post #1896 of 2223 Old 02-16-2013, 10:52 PM
WSS
WSS's Avatar
1972 CJ5
1/4" would feel more secure to me too. For now I will crisscross zip tie it. When it is all done, the swing out will close up pretty close to it, so I think they will be contained even if an end cuts loose or something like that.
I did get the rack done today. It is step one of the bumper build. The swing out will have two 5gl cans and a (rubicon) rack over the tire. The tire is a 33" but still adding lots of weight back there. I may have to get some Ground pounder fab 6" ctr boomerang shackles to compensate for the sag in the back!
WSS
WSS is online now
post #1897 of 2223 Old 02-17-2013, 06:35 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nice! Like the way it's tucked up tight against the tub.
BESRK is offline
post #1898 of 2223 Old 02-21-2013, 12:59 PM
midnight_f150
Any pictures of your current style of bumper?
midnight_f150 is offline
post #1899 of 2223 Old 02-21-2013, 01:12 PM
jcalhoon84
1980 CJ5
Bought it 2 weeks ago and mounted it yesterday.
image-1911562115.jpg   image-1504991140.jpg   image-644297419.jpg   image-2198933210.jpg   image-818267580.jpg
jcalhoon84 is offline
post #1900 of 2223 Old 02-21-2013, 01:26 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Looks Great !!!
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #1901 of 2223 Old 02-21-2013, 01:40 PM
jcalhoon84
1980 CJ5
Thanks, and build quality was excellent, very over built!
post #1902 of 2223 Old 02-21-2013, 01:47 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Ain't worth building if it can't be overbuilt.. Thanks again.. and thanks for posting some pics!!
BESRK is offline
post #1903 of 2223 Old 02-21-2013, 01:53 PM
midnight_f150
Thank you! I like that he went with the new style lock back pin.
post #1904 of 2223 Old 02-24-2013, 03:19 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Did a couple tow bar adapters today.. to adapt a 2" square tube (with 1/2" bolt hole near the end) tow bar to my clevis mounts on the front bumper..
Cut from 1/4"..
BESRK is offline
post #1905 of 2223 Old 02-24-2013, 03:28 PM
Tomb Raider
Addicted...
Lookin real good sir.
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
