Rear Bumper w/Swingout Tire Carrier Follow Along - Page 118 - JeepForum.com
 9Likes
post #1756 of 2229 Old 08-04-2012, 05:44 PM
deron1
Wow that was quite a read. Very nice looking stuff. I am very much interested in pricing for rear bumper/carrier w/ high lift and gerry can mounts and frame tie-ins. For a 2005 LJ Rubi shipped to Central California 93614.
2005 Jeep Rubicon Unlimited - Sahara Edition. #923/1000.
deron1 is offline
post #1757 of 2229 Old 08-04-2012, 07:57 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Deron.. just sent you a PM.. thanks!!
BESRK is offline
post #1758 of 2229 Old 08-05-2012, 11:03 PM
82cj7401
1976 CJ7
Rear Bumper
Eddie,
Followed your ideas and this is what I built for a 69 Commando. Still need to build the tire carrier.
[/IMG]cket.com/albums/h72/82cj7401/bumper3.jpg[/IMG]
82cj7401 is offline
post #1759 of 2229 Old 08-06-2012, 03:31 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nice!
BESRK is offline
post #1760 of 2229 Old 08-06-2012, 09:43 PM
CJ-Dan86
Eddie!!!!
Works on the CJ!!!!!!!!!!!!!!!!!!!!!!!
B@d @$$ comando!!!
CJ-Dan86 is offline
post #1761 of 2229 Old 08-09-2012, 11:41 PM
HONDOK9
Hey Eddie, I just got back from the Jeep Jamboree on the Rubicon Trail and my bumper/tire carrier that I built from your design (and some of your parts) kicked A**. I'm hear to tell you that it held up like a tank! I banged that thing on some serious drops and all it did was take a little paint off the bottom corners!!! Here are some pics of my version. Sorry the pics are soo big. I'm not so computer savvy! I don't have any pics of it finished. I'll see if I can get some on here later. Thanks again for all your help and an awesome design!!!
tire carrier 001.jpg   tire carrier 004.jpg   tire carrier 005.jpg   tire carrier 006.jpg
You can have cheap, and you can have quality, but you can't have both!
HONDOK9 is offline
post #1762 of 2229 Old 08-09-2012, 11:55 PM
HONDOK9
By the way, since you are a metal/welding guru, I'm designing an off-road jeep trailer and I've been toying with the idea of making it out of aluminum. What is your take on this? Yes, it will be lighter, but how does aluminum hold up to flexing, and the stresses that a moderately heavy load and off-roading will dish out? I know Featherlight makes a bunch of different types of trailers out of aluminum. Do you think this is a good idea? Cost may prohibit it from happening but I would like your take on it.
HONDOK9 is offline
post #1763 of 2229 Old 08-10-2012, 05:37 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Aluminum would be plenty strong for a trailer. The downside would be cost and welding the aluminum. Not sure if the reward is worth the extra cost/work.
BESRK is offline
post #1764 of 2229 Old 08-10-2012, 06:23 PM
HONDOK9
Thanks Eddie! I'll compare the cost difference and see if I can choke it down!!! If not, then Steel it is!
HONDOK9 is offline
post #1765 of 2229 Old 08-12-2012, 03:04 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Well.. both McMaster Carr and Northern no longer carry the red "Blitz" style bases for 5gal Jerry Cans So, it's gonna be either "make my own" base, or switch to something else.
I've made a couple Jerry can bases out of sheet.. bent on the brake. While they worked okay, they still used a strap to hold the gas can in place.
I've had a couple people ask me about doing a mount for the Rotopax Cans so I figured I give it a go. I ordered one of their 1.75gal cans and the basic Mounting bracket. The stuff came in late last week. Since I had a couple tire carrier bumpers to knock out this weekend, I figured it'd be a good time to knock out a mounting bracket to mount them on my swingarms.
The 1.75gal cans are 3.5" thick. I figured 2 of them could be stacked together and mounted without having to shove the spare tire too far back. So, I made my mount figuring most folks would probably stack 2 cans together.
Here's the Rotopax mounting bracket.
Here's the mount I did.. simple 90deg bracket cut from 3/16". A small gusset at the bend to help rigidity. I'll probably change the bolt pattern at the head to an "arc'd slot" to allow the Rotopax bracket to be spun to different angles. I oriented this first one with the gas can's spout at the very top.
Here's the bracket from behind.. I slotted the gusset into the bend so I could plug weld it in from behind. The bolt holes in the base are setup to work with 2" square tube.. allowing the bracket to be slid in/out a couple inches.
Quick test fit on the swingarm I was working on.
From the backside..
BESRK is offline
post #1766 of 2229 Old 08-13-2012, 05:14 PM
8pitcher
8pitcher's Avatar
Is there any other place that sells those kind of jerry can mounts?
8pitcher is offline
post #1767 of 2229 Old 08-13-2012, 05:44 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The Blitz Bases? I was paying about $25-$28 each for them (with shipping) from McMaster and Northern. With Northern I didn't have to pay shipping. With McMaster, I could "drop ship". Both have since stopped carrying them.
I've seen them on eBay.. anywhere from $25-$60 each. Maybe Amazon?
BESRK is offline
post #1768 of 2229 Old 08-13-2012, 05:46 PM
8pitcher
8pitcher's Avatar
Ok thanks. I will look into those. And if I can't find them I will get back with you.
8pitcher is offline
post #1769 of 2229 Old 08-13-2012, 05:49 PM
tdkask
I got the last one at Northern there in Norfolk. Was on sale for $14.99. Wish I'd gotten the opportunity for more at that price.
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #1770 of 2229 Old 08-15-2012, 05:03 AM
tjsean0308
Well I wouldn't hold your breath for those to come back in stock anytime soon. I wish I had gotten one and a jerry can to match before now.
"Blitz USA, a manufacturer of gasoline containers that has operated for nearly five decades in Miami, will close on July 31, putting 117 employees out of work.
-quoted from this interview with Blitz's PR person.
You might want to buy a couple of cans now for hurricane season while you still can.
tjsean0308 is offline
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
