Rear Bumper w/Swingout Tire Carrier Follow Along - Page 103 - JeepForum.com
 9Likes
post #1531 of 2230 Old 10-03-2011, 10:48 AM
JPcpa
2017 JK Wrangler
Eddie, I picked up a bumper/carrier from you a few years ago for my TJ Rubicon and just got an LJ. Can you shoot me a Pm with price for one with the LJ side extensions and frame tie-ins, with lead time?
Also, do you powder coat wheels? I've got 5 M/T classic locks that I'd like to pc black.
I'm in Richmond, so don't need shipping.
Thanks...Ian
2017 JK Willys
2004 LJ, Auto, Zone 3.5"/1.25"BL/MML/285 KO2s
2005 Rubicon
99 Sport
JPcpa is offline
post #1532 of 2230 Old 10-04-2011, 12:58 PM
MikalCarbine
Originally Posted by BESRK
Here's how I normally do it...
Bumper is pretty clean when it leaves the shop. We run over it with a high speed wire brush to clean it up. However, you can go over the welds with a "stainless toothbrush" to finish them up and then maybe wipe the whole bumper down with a green 3M Pad.
Wipe it down with something like "metalprep" or any other phosphoric acid based "etcher", rinse off residue and blow dry (hair dryer will work okay in a pinch).
Do a final wipe down with a degreaser ( I like lacquer thinner).
Shoot 2-3 coats of "self-etching" primer (Rustoleum sells a rattle can version).
Then, shoot 2-3 medium coats of your top coat of choice.
Anyone know where to find metalprep or equivalent locally? I have everything else to finish this up except an etcher.
MikalCarbine is offline
post #1533 of 2230 Old 10-04-2011, 03:32 PM
Thumper01
1987 YJ Wrangler
Try Ace hardware.
Thumper01 is offline
post #1534 of 2230 Old 10-04-2011, 04:59 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've seen it at Lowe's before.. in the area where they sell all the solvents (Lacquer Thinner, Acetone..etc.).
BESRK is offline
post #1535 of 2230 Old 10-04-2011, 06:34 PM
yellow85cj
Home Depot has Prep and Etch. Where the thinners are in paint dept. I use it to soak rusty parts in.
It is a phosphoric acid base. Don't let "acid" scare you. If it does, read the ingredients in the next can of Coke you drink.
Currently in pieces - all of them
yellow85cj is offline
post #1536 of 2230 Old 10-05-2011, 04:15 PM
MikalCarbine
thank you!!! I spent over 1.5 hours looking before reading this
I'm going to use it on my frame and some other rusty spots on my tub tonight as well as the bumper when it comes
post #1537 of 2230 Old 10-07-2011, 09:30 AM
MikalCarbine
Is it necessary to use water to rinse off the phosphoric acid or can you go straight to wiping it with acetone?
post #1538 of 2230 Old 10-07-2011, 02:56 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If you let the Phosphoric Acid dry, it'll become a "chalky powder".. that will need to be scrubbed off (a 3M Greenpad works well).
If you don't get the chalky residue off (especially in corners), it can bleed thru the paint.. making blemishes.
It's easier to spray the acid on.. keeping the surface wet, then rinse it off, and blow it dry (with compressed air or even a hair dryer) before it flash rusts.
Edit: We normally wipe the bumper/swingarm down with phosphoric acid before it leaves the shop (it's a good rust inhibitor). You'll see what I'm referring to with the white chalky powder..
BESRK is offline
post #1539 of 2230 Old 10-18-2011, 06:54 PM
JPcpa
2017 JK Wrangler
Here's some pics of that TJ Front Bumper I did a couple weeks back. The owner had it LineX'd. Almost booboo'd and made the bottom edge come to within 1/8" of hitting the steering box. I think I'm going to just revamp it a little and add in a steering box skid.. why not?
Cell phone pics...
Quote so I can find this easier... Nice bumper.
2017 JK Willys
2005 Rubicon
99 Sport
JPcpa is offline
post #1540 of 2230 Old 10-23-2011, 08:28 PM
JPcpa
2017 JK Wrangler
Got my second ground pounder bumper carrier in 3 years today. The incremental improvements/cnc work are very nice. The cuts and welds are clean.
I wiped down with laquer thinner, primed with self etching and couple coats of hammered black. I used the same on my last one and it is still holding up well.
Looking forward to getting the new GP front bumper in a few weeks...and get rid of my current sb tube bumpers...
2017 JK Willys
2005 Rubicon
99 Sport
JPcpa is offline
post #1541 of 2230 Old 11-03-2011, 03:32 AM
coleslaw
1987 YJ Wrangler
Great job on the bumpers. I am getting ready to make a swing-out for mine and found some good tips here. I have a bumper that looks just like the one the OP made except it is 3" wide instead of 2. I didn't make them as I didn't have a welder at the time but got BOTH the front and rear bumpers off ebay for 320 bucks. Guy that made em had to have lost money on that one.
Here is my tip for mounting the rear bumper. When I got my jeep the rear crossmember had a cheesy little bolt-on hitch on it, that had rusted and then been welded and that had rusted and the tail end of the frame had rusted (both sides). So I cut all that off and welded in Safe-T-Caps to repair the frame. Since I was going to replace the front bumper as well, I took the OEM bumper off, welded on some wings to accomadate the rear body mounts (got a welder) and attached it to the the rear frame with 1/2" through bolts. NOTE; if you try this make sure to check the fit of the gastank skid plate when you are test fitting. I didn't and ended up having to remake the filler neck as the old one was too short...PITA. I then bolted the new bumper to this. The bumper stands out more that usual and gives me a good step as well as plenty of room for the swing out with cans, etc mounted behind and is rock solid.
Coleslaw
A country that tries to spend itself to prosperity is like a man standing in a bucket and trying to lift himself by the handles.
Winston Churchill
87 YJ I6, nuttered and rushed, 2.5" lift, 31x10.5, custom made f&r bumpers, Mojave heater, TJ flares, Superwinch S9000, hm swingout tire carrier, tool drawer, custom electical control, and more in the works...........
coleslaw is offline
post #1542 of 2230 Old 11-04-2011, 09:08 AM
Domino
1980 CJ5
Got my front bumper and winch plate in yesterday and man these things look great! Thank you Eddie for such a high quality product and the best customer service!!! I have already recommended you and will continue to do so!
Domino is offline
post #1543 of 2230 Old 11-04-2011, 05:50 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Thank you for the kind words sir!!
BESRK is offline
post #1544 of 2230 Old 11-14-2011, 09:55 AM
MikalCarbine
What is everyone using for jerry cans with this bumper? I'm very interested in the Duestche Optik NATO cans http://www.deutscheoptik.com/product_info.php?products_id=2162 but don't know if it'll fit the (Blitz?) mount provided with the bumper
By the way, all done painting and mounting, looks great! Just waiting for hi-lift and jerry can before I install the mounts
Uploaded with ImageShack.us
post #1545 of 2230 Old 11-15-2011, 01:57 PM
midnight_f150
How well do these bumper work for towing?
midnight_f150 is offline
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
