Rear Bumper w/Swingout Tire Carrier Follow Along - Page 101 - JeepForum.com
 9Likes
post #1501 of 2229 Old 09-02-2011, 01:40 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Originally Posted by tdkask View Post
I called Eddie today and will drop by next weekend (one of the benefits of being local) to discuss some ideas and slight variations on bumpers. I already have the rear base bumper and want to get a swing out rack on it soon... and now that I've seen the above front bumper may need to discuss a CJ version. wish I'd have asked you to set it up on the front of mine when I was there last... think I saw it in its later stages.
I have seen the way he's building these and tell ya, they're solid. It will be the last surviving piece of my Jeep, probably. You can't find a nicer guy or someone more enthusiastic about his product. If there's anything he may be doing wrong it's spending too much time putting up with a million questions from guys like me when he should be building your bumper... but again it's a testament to his superb customer service and wish to give you what you need.
There are so any reasons to buy from him (quality, price, customer service, American made, willing to help others, and stands behind his work) and only one reason NOT to... I need to order my next project oon, and if you beat me to it I'll have to wait.
See ya next weekend, Eddie... and this time we'll get me a bottle opener on there for sure!
Thanks Dave!! .. and it's pretty easy to get a bottle opener on the swingarm..
My son is trying to get me to pull/sell my CJ's current front bumper setup and make one similar to that TJ Front Bumper. Might make a fun Winter project.
BESRK is offline
post #1502 of 2229 Old 09-03-2011, 02:05 PM
redrubicon11
would you mount the factory brake light on it?
redrubicon11 is offline
post #1503 of 2229 Old 09-03-2011, 02:23 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I suppose you can. However, I don't have any factory brake light assemblies laying around to be able to mock one up.
I used to offer a 3rd Brake Light option that consisted of a 2" diameter LED trailer light that pushed into a piece of tube welded to the center of the tire mount. However, it would only work with rims that had a 3" diameter opening.
There are also the little bolt-lites (can't recall the name at the moment) that have an LED bulb built into the end of a threaded bolt.
BESRK is offline
post #1504 of 2229 Old 09-03-2011, 02:36 PM
grebva3
Eddie,
When you get this bumper ready for production please email me! Jeremiah.Malmberg@gmail.com
_ONLY IN A_
|_Jeep_|
(OlllllllO)
grebva3 is offline
post #1505 of 2229 Old 09-03-2011, 04:39 PM
tdkask
I'd kinda like to get that design, but am often too impatient to wait until the winter... lol... will have to see how it all plays out.
Maybe you could mount a basic 4" LED trailer light behind it to show through the center hole? It'd mean a spacer behind? Or a square hole at the end of the reese style tube setup that takes the smaller rated hitch tube... then holds with a pin... so modular like the gas can or lift racks?
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #1506 of 2229 Old 09-03-2011, 08:27 PM
Coop02x
You could but you would have to do some altercations to the factory mount to get it to work (probably a little more than it would be worth). I would probably go with something a little more discrete/cleaner look.
Coop
Coop02x is offline
post #1507 of 2229 Old 09-04-2011, 01:08 PM
Modeler
Thanks Eddie, I finally got it installed as well as the Delta lug hole brake lights yesterday. Today I tidied up the wiring of the brake lights to "P" clamps instead of cable ties.
I was able to remove the factory HMBL wiring completely because I found that standard banana plug female terminals slipped right on the factory door jam pins.
Back side with the tidied up wiring
I attached the factory rubber bumpers from the tailgate to the angled arms to make the tire even more secure. It didn't move around before I added them so they are just piece of mind.
I have to learn to take pictures on days that aren't hazy or cloudy. LOL
Speed costs money, how slow do you want to go?
Modeler is offline
post #1508 of 2229 Old 09-04-2011, 01:24 PM
tdkask
love the LED third brake lights in the lugnut holes.
tdkask is offline
post #1509 of 2229 Old 09-04-2011, 03:11 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Dave.. thanks for posting those pics!! You know I was "right click save picture as"..
Do you have a link for those lights? I'd like to look into those as maybe an option..
BESRK is offline
post #1510 of 2229 Old 09-04-2011, 04:36 PM
Harold_Ray
Those are pretty darned neat!!
Harold_Ray is offline
post #1511 of 2229 Old 09-04-2011, 08:37 PM
Modeler
Eddie it is I who should be thanking you. As expected the build quality was spot on and every part of the install went perfectly.
Link to the Delta site: http://deltatechindustries.com/site/01-6581-50
I got mine through Quadratec as I had a gift certificate left over from Christmas: http://www.quadratec.com/products/16181_101.htm
You do have to modify the Delta lights a bit, I used a Dremel with a fine sanding drum to narrow the diameter so that they would pass through the lug holes correctly. The Delta instructions show drawings of what you need to do, but make no suggestion as to how. The Dremel on the lowest setting went through the resin like butter, took less than a minute to do each pigtail.
Modeler is offline
post #1512 of 2229 Old 09-04-2011, 08:41 PM
Harold_Ray
1510 posts and 449,947 views; can you believe that, and this thread has been going since 08-26-2004, 12:33 AM. That, folks, has got to be some kind of record, and the neat thing is this thread isn't going to die. The longevity and interest is unbelievable!!
post #1513 of 2229 Old 09-06-2011, 12:25 PM
redrubicon11
looking good and how much would you charge to build one of these
post #1514 of 2229 Old 09-06-2011, 04:11 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Just PM'd you some info..
BESRK is offline
post #1515 of 2229 Old 09-08-2011, 04:15 PM
96rokee
Hey ive been researching this thread for awhile now
and ive finally got the money together to go ahead and start building mine.
but ive run into a snag.
and thats finding DOM tubing..
i went to the link in your first page
but the shortest length i can buy is 12"
i only need 4"
curious if youd be willing to sell me a piece?
im trying to mimic your design on the first page.
if so can i get a price of the dom tubing alone.
and then a price of the spindle and everything rossette welded and ready?
96rokee is offline
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
