Rear Bumper w/Swingout Tire Carrier Follow Along - Page 10 - JeepForum.com
 9Likes
post #136 of 2228 Old 12-21-2005, 04:55 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Okay.. changed a few things on the current bumper that I'm making.. moved the De Sta Co latch (the new style with the safety lock) out to the end of the arm to pull down and forward. This locks the arm into a piece of angle iron. I also made a swingout locking pin to hold the arm open. Also, scraped the idea of a universal top mount for accessories and just added a Hi Lift Mount. It locks the jack into place with two bolts/wingnuts and captures the handle with a piece of tube cut in half.. here's a few pics..
Here's the angle iron mount that will capture the end of the swing arm.
... another shot of the mount from an angle view
Here is the De Sta Co latch on the end of the swing arm. It will pull the arm down and forward locking it into the angle iron mount.
Here's the same latch assembly from above..
BESRK is offline
post #137 of 2228 Old 12-21-2005, 05:02 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Here's the swingarm stop...
The pieces I used... a piece of 3/8" rod, a small spring and a roll pin.
Here is the small "half moon" plate with the hole drilled in it for the stop pin.
Here's the swing arm pivot with the small piece of tube welded to it.
Here it is assembled... the spring pressure pops the pin down into the hole to hold the carrier open. The little roll pin is what keeps the spring in place on the pin.
BESRK is offline
post #138 of 2228 Old 12-21-2005, 05:09 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Finally the Hi Lift Mount.. a couple of pieces of 3/8" plate with bolts welded thru them to act as mounting studs for the jack's "spine". A piece of tube cut in half holds the jack handle.. it can be tapped up into place after the jack is mounted to snug up the fit reducing rattles.
Simple setup..
From the backside.. important that the jack mounts from this side as the other side will have the tire on it.
With a jack snugged in place.. zero movement.
From the other side.. after the jack is bolted on, you can tap that curved piece up a little to snug the jack handle against the jack.. keep it from rattling.
My cozy work space..
BESRK is offline
post #139 of 2228 Old 12-21-2005, 08:07 PM
7DJEEP
Nice! That's a pretty indestructible bumper there!
7DJEEP
“Arguing on the Internet is like running in the Special Olympics, doesn’t matter who wins, you’re still a retard”
Upgrades, Modifications, Personal Repairs
MC2100 Carb, Nutter Bypass, New U-joints on rear , Custom Front Bumper/Warm 6000lb Winch, Filters & Fluides. The rest is stock I believe.
Stock & Factory Options
AMC 258 6 Cyl., 4 Speed Manual Transmission (Model ?), AMC 20 Rear- Dana 30 Front (gears unknown), Black Paint, Hardtop/Steel Full Doors, 31" Tires (Worn Out)
7DJEEP is offline
post #140 of 2228 Old 12-21-2005, 08:46 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I was just gonna use the single tube in the center to hold up the tire but I was afraid it might fall over so I tossed on another two to hold it up on each side. Bumper and swingarm combined weigh about 100-110 pounds. Gas mileage?.. we drive Jeeps... who cares?!
BESRK is offline
post #141 of 2228 Old 12-21-2005, 08:56 PM
7DJEEP
I like the way you angled the high-lift jack, looks great!
Thanks
7DJEEP
7DJEEP is offline
post #142 of 2228 Old 12-29-2005, 03:50 PM
NMPhi767
We finished the bumper based loosely off of this project. Thanks for all of the information. I will try to post a pic later.
1981 CJ-5
Stock Stockety Stock Stock Stock!
NMPhi767 is offline
post #143 of 2228 Old 12-29-2005, 05:29 PM
Jeep Daddy
Jeep Daddy's Avatar
I like it too. Keep up the good fab work. When are you going to adapt it for gas/water cans?
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #144 of 2228 Old 12-30-2005, 08:09 PM
NMPhi767
Alright, since I can't post pics, there is one at the link below.
1981 CJ-5
NMPhi767 is offline
post #145 of 2228 Old 12-31-2005, 05:08 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I ditched the flat plate at the top of the carrier idea. Haven't really given much further thought to it. I'm making another one for a YJ right now and might toy with gas/water can mounts.. maybe one on each side?..
BESRK is offline
post #146 of 2228 Old 01-02-2006, 07:14 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Just some random pics of the last bumper I made.. might help someone get the creative juices flowing....
The Pivot Gusset is one of the bumper end pieces cut to fit.
Swing Stop to hold the Tire Carrier open..
New Latch Location.. pulling forward and down to lock the Swingarm into its mount
Small 3/16" piece to catch the bolt hole in the bottom of the frame
The center post is 18" tall..
Hi Lift Mount... tap off the wingnuts and the Jack is free..
BESRK is offline
post #147 of 2228 Old 01-04-2006, 08:14 PM
EaglesSJ
EaglesSJ's Avatar
What kind of paint is that?
EaglesSJ is offline
post #148 of 2228 Old 01-04-2006, 08:26 PM
97TJGUZZY
97TJGUZZY's Avatar
Here is my latest
This is what I started with
here are some finished pics...we only had his little spare to put on for now...his fullsize spare was at my house...but you get the idea.
For info on outdoor adventures in South Carolina check out
97TJGUZZY is offline
post #149 of 2228 Old 01-04-2006, 08:45 PM
grymsr
Vintage Member
grymsr's Avatar
very slick job!
I will be hunting for a good swing out one of these days. If yours shows up on ebay, i'll be bidding.
grymsr is offline
post #150 of 2228 Old 01-04-2006, 08:45 PM
mxer
mxer's Avatar
How come this the bumper isn't tied into the frame??
BTW, I'm pretty sure you're the guy I bought some D ring mounts from off of ebay back in the summer....that was awesome shipping...thanks
80 CJ7, lifted, 33's
mxer is offline
Swingout tire carrier question........... Flingit1200s Fabrication Shop 5 11-22-2009 08:41 AM
Swingout Tire Carrier / Rocker Guards ckhanna71 Fabrication Shop 14 09-14-2009 11:14 PM
rear bumper w/swingout rckjeep Fabrication Shop 1 02-11-2007 09:13 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
Tube Rear Bumper w/Swingout Tire Carrier Lime Jeep Fabrication Shop 12 05-15-2006 11:11 AM
