Rear bumper tire carrier/stinger build...on a budget - Page 4 - JeepForum.com
post #46 of 59 Old 03-02-2012, 09:50 PM Thread Starter
Viper723
I finally figured out how I am going to do the hinge, so I worked on that today, as well as making a t-handle to latch the arm. I think it will be convenient and very strong they way it will be hooked up. I just hope all of the geometry comes together on assembly...
Built not Bought.
"The walls between art and engineering exist only in our minds"-Theo Jansen
Viper723 is offline
post #47 of 59 Old 03-09-2012, 09:10 PM Thread Starter
Viper723
Here are the pics of what I got done today... It is finally coming together. I love the lines of the stinger...
Okay and as for the black widow... this gal is a trooper. I welded a tube across the stinger 4 days ago, then cut it this morning because I didn't like the look. As I was cutting, it crawled out and onto the cement. Scared the bejesus out of me! It was in a fully welded tube for 4 days and lived 0.o I safely transplanted it to a tree. So I think I will call this model the Black Widow... seems appropriate. I already have the spiderweb gusset for it too
Built not Bought.
Viper723 is offline
post #48 of 59 Old 03-11-2012, 05:49 PM
Steve707
What do you think of that bender? I'm looking at the same one on craigslist right now for $140 with dies and a stand.
Steve707 is offline
post #49 of 59 Old 03-11-2012, 11:41 PM Thread Starter
Viper723
It is a fun little tool for thinner material, but it wont do tubing of course... ive tried
Built not Bought.
Viper723 is offline
post #50 of 59 Old 03-12-2012, 12:07 AM
Steve707
Did you try using heat, or a cheater? I'll probably pass on it if it can't do tubing.
Steve707 is offline
post #51 of 59 Old 03-12-2012, 02:30 AM Thread Starter
Viper723
I did not use heat. It has enough grunt, it just crimps it. I tried doing 30 small bends and the best I could do was slightly squashed, but heat may help
Built not Bought.
Viper723 is offline
post #52 of 59 Old 03-12-2012, 02:38 AM Thread Starter
Viper723
Okay So I got everything roughed and tacked, and I tested the fit before I put any more work into it. I think it will work. The hinge system I am going to use will be enough... I hope. It will look more full with a tire too.
Built not Bought.
Viper723 is offline
post #53 of 59 Old 03-14-2012, 01:37 AM Thread Starter
Viper723
I got all of the grinding done on the bumper and gave the inside a coat of bare metal primer. I still need to finsh the stinger and swingout welding and grinding.
Built not Bought.
Viper723 is offline
post #54 of 59 Old 03-16-2012, 01:05 AM Thread Starter
Viper723
Okay Her we go... I got the inside coated with a thick coat of rustoleum brushed on, and just primed it with self etching primer(which is a sweet color, I may paint things with it later)... I then gave it 2 coats of Rustoleum hammered black. I heard a lot of guys so it wasn't really jet black, but dark gray(which is what I was praying for anyways) and it turned out the exact shade that I wanted!!! So tomorrow I will finish welding and grinding the swing out parts. I will take a picture of the color in the sun tomorrow.
Built not Bought.
Viper723 is offline
post #55 of 59 Old 03-17-2012, 01:29 AM Thread Starter
Viper723
Here is the back bumper as of this morning. I love the way the paint came out. I really think this is my go to paint from now on. What do you guys think of the color?
Built not Bought.
Viper723 is offline
post #56 of 59 Old 03-17-2012, 05:43 PM Thread Starter
Viper723
Okay I got a lot done today. I finished the emblem plate which I masked and sandblasted to get the texture. I love the way it came out. and finally got the hinge mounts taken care of. They work... not the smoothest setup but it should be strong. Now I need to get the finish grinding and painting and lights taken care of.
Built not Bought.
Viper723 is offline
post #57 of 59 Old 03-21-2012, 12:07 AM Thread Starter
Viper723
Here it is everyone!!! I think it came out awesome. Much stronger than I first thought. I am surprised at how close to the plan it turned out to be.
Built not Bought.
Viper723 is offline
post #58 of 59 Old 03-23-2012, 05:12 PM
Tenshots1
pretty awesome looking. stock spare rim is messing up the look tho
1998 XJ Build:
Tenshots1 is offline
post #59 of 59 Old 03-23-2012, 11:10 PM Thread Starter
Viper723
Thanks man. Well I agree that a matching rim would be awesome, but all 5 33's on rims for 450 bucks was too good to pass up haha
Built not Bought.
Viper723 is offline
diy , stinger bumper , swing , tire carrier
TJ Rear bumper/ Tire carrier build TreverTJ Fabrication Shop 43 02-25-2013 04:34 AM
YJ rear bumper/tire carrier build in back yard Ironworker709 Fabrication Shop 31 03-03-2012 02:12 PM
Another rear bumper/tire carrier build with a little more beef! flipper1 Fabrication Shop 4 04-14-2010 01:02 PM
Rear bumper / Spare tire carrier... Lunchbreak build! Kenbo-Slice Fabrication Shop 71 02-12-2010 08:23 PM
Rear Bumper/Tire Carrier Build Bikertrash Fabrication Shop 38 12-23-2006 07:06 PM
