Rear Bumper Project - JeepForum.com
post #1 of 12 Old 01-06-2007, 09:58 AM Thread Starter
NWilhelm
Rear Bumper Project
Wednesday a friend and i decided to make a rear bumper for my tj. we headed down to the metal yard to check out the scrap pile and got enough materials for two bumpers. we decided to make two and sell the second one or something. i'll try to get pics of the bumper as soon as i can.
heres a list of materials:
2"x4"x1/4" wall rectangular stock 55" long (can sub thinner material if you like but I like it beefy!)
approx 7" length of 2 1/2"x2 1/2"x1/4" wall stock for receiver (can sub a store bought receiver tube.. Northern has one for like $10)
approx 7" of 2 1/2"x1/4" thick flat stock for chain plate
approx 6" length of 3"x1/4" wall square stock (for mounting legs and receiver lip)
approx 18" of 3"x3/8" thick flat stock cut in half for the bumper mounting flanges
approx 18" of 2"x1/4" thick flat stock for bumper end caps
approx one foot of 2"x3/4" thick flat stock for clevis mounts
...and a bit of expanded metal to make a logo (we are dorks...but my friend has other stuff he can use the logo for.)
PS - we followed BESRK's write up minus the swingout tire carrier. THANKS BESRK!!! and....we're both in high school
: Black Hard Top/Strapless Bikini/Viking Fast Back Top | Warn Rock Crawler Front Bumper | Homemade Rear Bumper | Black Herculiner interior | Rokmen Rear Corner Guards |
NWilhelm is offline
post #2 of 12 Old 01-06-2007, 10:15 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Glad the writeup helped.. now, where's the pics!!?
BESRK is offline
post #3 of 12 Old 01-06-2007, 10:17 AM Thread Starter
NWilhelm
i'm workin on it. i still have to get them from my friends dad. he was the photographer.
NWilhelm is offline
post #4 of 12 Old 01-07-2007, 05:33 PM Thread Starter
NWilhelm
Here is mine mounted on my tj. the other one is identical. enjoy!
NWilhelm is offline
post #5 of 12 Old 01-07-2007, 08:26 PM
99redwj
good job!keep it up
Matthew
1999 4.7 Grand Cherokee
IRO 4" lift,JKS quick discos,DT 8000's,Baja MTZ 32x10.5x16,Cragar 8's,Flowmaster 40
2006 5.7 Grand Cherokee
2003 4.0 Wrangler
4" Pro-comp lift,33x12.50x15 Pro-Comp MT,Warn bumper,American racing AR-172,Piaa fogs
99redwj is offline
post #6 of 12 Old 01-08-2007, 05:56 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nice! What's the WW thing stand for?
BESRK is offline
post #7 of 12 Old 01-08-2007, 04:17 PM Thread Starter
NWilhelm
it stands for Wilhelm Williams Fabrication. my last name is Wilhelm and my friends last name is Williams (obviously).
NWilhelm is offline
post #8 of 12 Old 01-12-2007, 11:33 AM
Bikertrash
Bikertrash's Avatar
Great job!
Bikertrash
2004 LJ Unlimited Hardtop, Solar Yellow,Automatic
Rubicon Express 3 1/2" SuperFlex
33" x 12.5" x 15" Cooper STTs
Bikertrash is offline
post #9 of 12 Old 01-12-2007, 03:08 PM Thread Starter
NWilhelm
thanks didnt you have a write up too, bikertrash?
im workin on one it takes a while
NWilhelm is offline
post #10 of 12 Old 01-13-2007, 10:44 AM
Bigbob
Bigbob's Avatar
Originally Posted by NWilhelm
What is the object of having the extention between the crossmember and the bumper? I see many folks build them this way. I just bolted my 2"X5" directly to the crossmember and it seems better that way. I guess if you were gonna put a swingout on it the extention may be needed. What's the reason? Thanks, bob
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #11 of 12 Old 01-13-2007, 05:17 PM Thread Starter
NWilhelm
I did mine this way for several reasons:
one i prefer the look of it out a bit, two i plan on adding a tire carrier later, three i needed practice welding and i wanted to practice on something out of the way
NWilhelm is offline
post #12 of 12 Old 01-14-2007, 10:17 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I do mine like that for a couple reasons. One, I do quite a few bumpers. It's much easier to generically drill 4 predetermined holes in a plate than to drill and sleeve a bumper blank... and I would sleeve to prevent crushing of the bumper body. I will cut/drill an entire length of flat steel (3"x1/2" thick), toss all the pieces into a vat of acid for 24hrs, and then rinse/dry/stack them on the shelf for future use or sale. Then, when I actually make the bumper, I just drop the plates onto my jig (the actaul rear frame portion of a CJ, YJ/TJ) and set the bumper on it for tacking. Tack up, remove and weld a good fitting bumper.. quickly. And yes.. it does help when doing a tire carrier. Keeps the carrier off the tailgate.
BESRK is offline
Just picked up steel for my first welding project...rear bumper danheit Fabrication Shop 3 01-29-2007 09:53 AM
Front Bumper Project Jeep4Ever Fabrication Shop 46 04-15-2006 01:19 PM
first bumper project started heavyhitter Fabrication Shop 10 03-10-2006 12:18 PM
Where to find rear bumper w/integrated rear hitch in bumper? djaychris General Jeep & Off-Road Equipment 15 01-09-2006 07:29 PM
my new bumper project NOTQUITEMUSASHI Fabrication Shop 9 02-24-2005 10:52 AM
