Rear bumper fab - JeepForum.com
post #1 of 27 Old 11-26-2012, 07:31 PM Thread Starter
zboss86
Rear bumper fab
It was fun doing a front bumper, so here's my attempt on the rear...
Cleaning out the garage... check what I have for sale here:
http://midsouthjeeps.com/forum/index.php?/topic/20693-jeep-parts-for-saletradebumper-2-spacers-relocation-brackets/
zboss86 is offline
post #2 of 27 Old 11-26-2012, 08:18 PM Thread Starter
zboss86
Any particular order you guys do that speeds up grinding the welds? Are you guys only using flap disc or do you you use a hard disc and then smooth it out with a flap disc? What grit flap disc do you use? I'm sure I'll get faster I as my welding improves and have less mess to clean up....
I had another question, but I'm going to move it to another thread...
Last edited by zboss86; 11-27-2012 at 09:00 AM. Reason: moved question to another thread
zboss86 is offline
post #3 of 27 Old 11-29-2012, 09:24 PM
Jason
Grinding disc until it's close to smooth; careful not to gouge it. Then a 36 grit flap disk, progressively finer to get it smooth, usually 60 or 120 grit.
We're men! We don't need no stinkin directions!
Jason is offline
post #4 of 27 Old 11-30-2012, 05:01 AM Thread Starter
zboss86
I'll have to get some 36 grit flap disc to try... I pretty much use 60 grit on the whole bumper.
zboss86 is offline
post #5 of 27 Old 11-30-2012, 06:37 AM
Jason
That's a cool looking design. How does it mount? Any plans for D-ring mounts for recovery gear?
Jason is offline
post #6 of 27 Old 11-30-2012, 06:56 AM
Jim1611
Jim1611's Avatar
I've found that by leaving the outside corners open and filling with weld there's not much grinding. Cut the pieces to fit so that they end up looking like the picture below. Weld the outside bead first, you'll fill the gap with weld, then weld the inside fillet. After it's all welded about all there is to do is clean the edge up a little and it makes for a stronger joint.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is online now
post #7 of 27 Old 11-30-2012, 07:29 AM Thread Starter
zboss86
Thx, I just mimic'd a few other designs... I'm going to add a trailer hitch receiver and and a couple shackle mounts. It has plates tacked on to set the bumper on while I'm fabbing. I'm going to weld on some mounts to bolt it to the stock location. I'll also tie the stock location to the frame a little better.
I agree Jim1611, that makes for a lot stronger weld. It's also great for a rounded edge b/c there's not much clean up. But I've found out it makes it a pain when I want to make a sharp corner. I have to come back and add "filler" weld and grind it out to a point. Just depends on the look I'm going for...
BTW, I viewed your build... sweet!
zboss86 is offline
post #8 of 27 Old 11-30-2012, 11:14 AM
Molonlabemike
Love the design, any shots of how the back side looks and mounts up?
Molon Labe
Molonlabemike is offline
post #9 of 27 Old 11-30-2012, 03:57 PM Thread Starter
zboss86
thx, not yet... but I should by the end of the weekend.
zboss86 is offline
post #10 of 27 Old 11-30-2012, 09:39 PM
Molonlabemike
Sound great
Molon Labe
post #11 of 27 Old 12-02-2012, 04:32 PM Thread Starter
zboss86
Built some frame tie-ins for the bumper. I have some shots of the back and a few other angles. I definitely learned a lot from this build... I could the next one stronger, cleaner, and a lot faster. But I'm having fun and getting better, so that's what matters.
I still got to add in the clevis mounts and the trailer receiver. I'm going to round off the sharp edges a little bit, clean it up, prime it, and spray it with some bed liner like I did the front bumper.
My shop is part of series of storage units. Two of the next door units got broke into to a couple weeks back, so my next project will be a steel security cage to lock my welder, plasma, and expensive hand tools in. After that, I'm going to get started on a tire carrier.
image-1083619163.jpg   image-2235362485.jpg   image-845302273.jpg   image-1746731890.jpg   image-1926645909.jpg
zboss86 is offline
post #12 of 27 Old 12-02-2012, 05:07 PM
jrallen
Lools pretty sweet! Why not build it so it's sandwiched between the body mounts and the frame instead of cutting it to fit around the mounts?
jrallen is online now
post #13 of 27 Old 12-02-2012, 05:16 PM Thread Starter
zboss86
Yeah, it'd look better, one of those things I'd change if I was to do over..
zboss86 is offline
post #14 of 27 Old 12-02-2012, 05:55 PM
jrallen
Ohh, I'm not worried about the looks. I think it looks great! I just know that it'd be stronger, especially if you plan to use it for any kind of recovery.
post #15 of 27 Old 12-02-2012, 06:20 PM Thread Starter
zboss86
Didn't even think about it being stronger... I saw it cut like that on the one that poison spyder does. Monkey see monkey do(or try).
I'm also going to make a mount to the center where the trailer hitch ties in...
You guys must do some serious yank'n on the recovery, LOL
zboss86 is offline
