Random stuff I've made - Page 9 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Random stuff I've made
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 01-28-2012, 07:18 PM   #121
G30SFF250
This is genius!!!
I have a shop table with a 3'x6'x3/4 thick steel top. I will guess around 1,000 lbs.
I will do this to my table. Thank you! and
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline   Reply With Quote Quick reply to this message
Unread 01-31-2012, 11:59 AM   #122
Jamesbbh
Originally Posted by G30SFF250 View Post
This is genius!!!
Awesome man glad I could help! The table doesn't get moved often but these come in very handy when needed.
Build thread (sorta)
http://www.jeepforum.com/forum/f22/9...-mods-1153079/
Random stuff I've made thread
http://www.jeepforum.com/forum/f37/r...-made-1171226/
Jamesbbh is offline   Reply With Quote Quick reply to this message
Unread 01-31-2012, 11:59 AM   #123
Jamesbbh
A marlin sculpture a buddy is paying me to do:
Drew it up
Freehanded with sharpie then plasma
Traced/cut out other side
Started on base
Nothing has been cleaned up or ground down yet and all of this was done in about 1 1/2 hrs
Unread 02-12-2012, 12:40 AM   #124
DannyRoark89
1995 XJ Cherokee
i would be pissed if i went to grab some bolts to slap something together and the one i needed was recently turned into a statute of a dude pooping! plus with the price of bolts these days your basically welding gold together for no reason! either way man kuddos! you are extremely creative, my hats off to your sir!
DannyRoark89 is offline   Reply With Quote Quick reply to this message
Unread 02-12-2012, 01:49 AM   #125
Jamesbbh
Well I didn't do the statue of someone Shi*ing, that was posted by someone else, and I have literally a 5 gallon bucket full of bolts and screws that are way past their prime. Any real project that needs fasteners I usually buy new. So thatnks? haha
Unread 02-24-2012, 08:13 AM   #126
Jamesbbh
Little project last couple weeks.
Drew this
Cut it out of stainless
Made a base and welded/bent it up
Finished and clear coated
Unread 04-03-2012, 08:08 AM   #127
Jamesbbh
It's been a while!
Little random something for my friend's wedding (his wife wanted a jazz band a while ago and I remembered)
Unread 04-04-2012, 02:10 AM   #128
TJRHD
That is awesome man!
NOT A HATER
TJRHD is offline   Reply With Quote Quick reply to this message
Unread 04-04-2012, 03:50 PM   #129
Jamesbbh
Thanks !
Unread 04-30-2012, 05:38 PM   #130
Pikes_Peak_Trailers
James - it's been a long time since I checked in. I love the band set, with the stand up bass. Brilliant!
Have you gotten into alum welding? if so, I have probably a box worth of drops of alum plate and 1" sq tube.
Dave.
Pikes Peak Trailers LLC.
Hand Built Off Road Trailers (customized for you)
[url]www.pikespeaktrailers.com[/url]
[email]dave@pikespeaktrailers.com[/email]
Pikes_Peak_Trailers is offline   Reply With Quote Quick reply to this message
Unread 05-01-2012, 07:49 AM   #131
Jamesbbh
Dave.
Hey man! Thanks on the band set, it was a hit at the wedding. Same here, I've been busy with work and whatnot I don't get on here as much. I actually just got the argon tank filled up and was planning on learning some aluminum next, haha! So yeah I could definitely put that box of drops to use.
Unread 05-01-2012, 04:11 PM   #132
Pikes_Peak_Trailers
Cool. I am finishing up a build right now and will get a box of alum out to you either this week or late next. I will shoot you an email once it leaves.
The drop will be some 1" sq 11g tube, 18g floor plate and 18 flat sheet. I will try and get a mixture in there so that you can practice on different thicknesses.
Take Care,
Dave.
Unread 05-04-2012, 09:15 AM   #133
Jamesbbh
Take Care,
Dave.
Awesome, Thanks dave.
Unread 05-29-2012, 03:49 PM   #134
Jamesbbh
Did this the other night.
Unread 07-13-2012, 01:42 PM   #135
Jamesbbh
Little guy that i've been working on for a local art show next week.
