raising winch with 1.5" square - JeepForum.com
post #1 of 5 Old 01-26-2011, 01:49 PM Thread Starter
slafferty
My stinger has support bars that are welded from the stinger to top piece of the bumper. My superwinch fits right in between the bars however i just bought a warn that does not fit between the bars. If i were to use some 1.5" square with a 3/16"-1/4" wall to mount the winch up higher would it be sufficent? I will have to use longer bolts that go through the 3/16" bumper and 1.5" sqaure then into the winch.
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
slafferty is offline
post #2 of 5 Old 01-26-2011, 02:05 PM
TJ06WRANGLER
Your first weak link will be the bolts. The next will be the tubing. It might work. Add to that the cantilever effect if/when you get a good load on it. Personally if I was to do that I would use a solid square piece. If nothing else it would give me more peace of mind. Might not be any better, but it couldn't be worse.
Also, believe me I could be totally wrong, but that is what initially comes to mind.
TJ06WRANGLER is offline
post #3 of 5 Old 01-26-2011, 02:54 PM
wushaw
Rockin jeep
wushaw's Avatar
Or at least sleeve the bolt holes to keep things from collapsing.
wushaw is offline
post #4 of 5 Old 01-26-2011, 03:07 PM Thread Starter
slafferty
Thats a good idea. Anyone think it will be better to weld the a few peices of sqaure across the top of the bumper then wled a flat plate to them and just bolt the winch to the plate with the short bolts?
That might work better.. I think it'll look cleaner too. I know there are a few "raised" TJ winch plates that use a 90deg bend at either end of the winch plate to raise it up an inch or two.. The tubing would be doing something similar if mounted out toward the ends of the winch plate..
MY BUILD THREAD
post #5 of 5 Old 01-26-2011, 07:10 PM
wushaw
Rockin jeep
wushaw's Avatar
Welded & some gussets...yea no prob. The winch plate I built is raised since the roller fair lead is flush with the bumper.
wushaw is offline
Cool Video of Winching your Jeep "Backwards" with a front facing winch jackattack General Jeep & Off-Road Equipment 6 03-09-2010 08:35 PM
working pressure of 2" x 3" square tube 3/16" wall TNeustadt Fabrication Shop 8 10-29-2009 06:05 PM
Raising a 3.5" Lift From IRO More? redhatman Tires & Wheels 1 11-10-2007 09:02 AM
"Generic" Wireless Winch Installed Today Chris @ GATR General Jeep & Off-Road Equipment 15 05-17-2007 05:30 PM
Raising springs Mels95YJ Tires & Wheels 3 05-06-2003 05:46 PM
