quick tire carrier build. (lots of pics) - Page 2 - JeepForum.com
post #16 of 48 Old 01-10-2011, 12:05 PM Thread Starter
papi32
I really like how you did the shovel mount. I have been looking for a way to do this and I think I may somewhat "copy" your set up as far as how you clamped the handle to secure the jack.
You are doing a really good job though. Keep up the great work![/QUOTE]
Ya the shovel mount is pretty easy, but watch out when you weld it since it likes to warp because of the heat. I couldn't find any other way to do it that i could weld on. The only disadvantaged is that there are 4 wing nuts= more to loss on the trail.
papi32 is offline
post #17 of 48 Old 01-10-2011, 12:11 PM
jeepn012
Awesome work. I still haven't broken into welding my own stuff.
Just curious, but are you going to leave the CB antenna that high? Guess you don't have an parking garages there..
1990 YJ - 96 to 03 My first. She will be missed.
2004 TJ - 03 to 11. Old Faithful. I will have another TJ one day.
2007 JKU - SOLD
2005 LJ - In the mail, hope I like it. Everybody's doin it, here is the build:
jeepn012 is offline
post #18 of 48 Old 01-10-2011, 12:14 PM Thread Starter
papi32
Welding isent that hard just take your time and learn to get a nice bead down, and focus on the penetration of the weld.
Ya my CB antenna is going to stay that high, we do have parking garages but i think i go in one once a year. I will take it off when i need to, i will have it off all the time unless i go offroading since it wont fit in the garage!
papi32 is offline
post #19 of 48 Old 01-11-2011, 07:07 AM
Fropleyqk
Fropleyqk's Avatar
2014 JK Wrangler
Really nice job man. Looks real good.
Fropleyqk is offline
post #20 of 48 Old 01-11-2011, 04:04 PM Thread Starter
papi32
Thanks.
papi32 is offline
post #21 of 48 Old 01-11-2011, 04:11 PM Thread Starter
papi32
Good news. So yesterday i got home before the the UPS guy came so i started to get it ready for the latch. I put a new tube on there, one that is a little bigger, and has much better welds than the last one. I also took the time to cap the top so i wouldn't have to worry about water getting in and rusting it.
Now for the bad news. Once the UPS guy got here i was exited to finally finish it. Opened the box and saw the latch, it was miniature. I knew this couldn't be right so i looked up the part number and i ordered the one with only 360 holding pounds. So that was disappointing. I am not going to spend the time and money to buy another one from them. But i think i have decided on going the T-bolt way. It seems very easy to do and cheap. I know i will have to worry about it coming undone but, once i start to hear it i will just pull over and tighten it. I think i will put a pin in the back side of the bolt so id doesn't come all the way out once the pin is in place, or just put an extra wing nut on it. Not sure yet but will get it finished tomorrow most likely.
papi32 is offline
post #22 of 48 Old 01-11-2011, 04:59 PM
rompinthewoods
Very good job on the carrier. I wish my welds look as good as yours. I built my own carrier a few months ago and I spent a lot of time grinding my welds to make them look decent. I used the t-bolt style latch and it works great. I have not had a problem keeping it screwed in. A pin on the other side is a good idea though. I may do that as well.
If I have to drill out another bolt, I'm just going to start welding parts on.
rompinthewoods is offline
post #23 of 48 Old 01-11-2011, 05:43 PM Thread Starter
papi32
Hey thanks, if you wouldnt mind could you put up a pic of your t bolt latch. Thanks.
clayton
papi32 is offline
post #24 of 48 Old 01-11-2011, 06:15 PM
ArrizX
Looks great.
Just watch out for the bug holes in your welds.
ArrizX is offline
post #25 of 48 Old 01-12-2011, 10:39 PM Thread Starter
papi32
Got all of it finished today other than the gas can mounts, thats in another couple of weeks. I want to get it on so i can go wheeling this weekend.
Here are all the pieces being painted.
went for a little test drive once i got it all installed. Not a sound other than the hi lift.
Picture of the T-latch. was really hard to get all 3 holes to line up just right.
This is the frame tie in i made. really solid.
Within the next couple of weeks i will be making the gas can holders for both sides of the tire carrier. So look back in the future.
thanks for looking.
Clayton
papi32 is offline
post #26 of 48 Old 01-13-2011, 08:33 AM
jatepper
Great job. Looks really good!!!
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #27 of 48 Old 01-13-2011, 12:10 PM
Tracker401
I'm really kinda interested in the "Tee bolt" latch. I like the idea that you can keep the mount tight to (hopefully) keep the rattling to a minimum. My question is, how much of a PITA is it when you need to get into the back end of the jeep? I get into mine 3-5 times a day and I'm afraid it would get old unscrewing the latch each time, then securing it again. I'm kinda torn between the good and the bad.
Good job on the build! I like the frame tie in's you made...good job! I've got to do a bumper when it warms up AND I get a little time. I've got a lot of ideas banging around in my head...!
Thanks for sharing!
Tracker401
Tracker401 is offline
post #28 of 48 Old 01-19-2011, 04:12 PM Thread Starter
papi32
Thanks for sharing!
Tracker401
Well if you open the back alot i would go with a latch set up. But you could make it work if you get the right sized bolt, mine is a little to long and is a pain in the *** to get out. Also if you go the t-bolt way make sure your bolts line up perfectly or it gets really hard to screw in and unscrew the bolt. But overall i really like this set up since it is really solid and is defiantly not going to go anywhere!!
papi32 is offline
post #29 of 48 Old 01-23-2011, 10:15 PM
krazymatt
That looks awesome bud! Very good work. What size rectangular tube did you use for the rear bumper itself? I want to start building me some bumpers and carrier sometime this year as soon as I can get a hold of some steel.
krazymatt is offline
post #30 of 48 Old 01-23-2011, 11:03 PM Thread Starter
papi32
Thanks!! The previous owner made the bumper, but i cleaned up the welds and filled some holes. But to answer your question the lower bumper part is 2x4 peace.
Clayton
papi32 is offline
Xj rear tire carrier build DannyRoark89 Fabrication Shop 12 06-09-2010 05:23 PM
CJ7 tire carrier build rustymudder Fabrication Shop 5 05-06-2010 06:36 PM
Tire Carrier build redbaron1 Fabrication Shop 78 04-28-2010 08:59 PM
another tire carrier build with a twist Bigboyky Fabrication Shop 16 03-19-2010 07:59 PM
Crawler build from scratch.... Lots of pics. BlueTorch Fabrication Shop 123 04-09-2009 12:45 PM
