Question About Plasma Cam and Bumper Fab - JeepForum.com
post #1 of 12 Old 04-26-2011, 11:04 PM Thread Starter
krazymatt
I plan on fabbing a front bumper out of 3/16" Plate steel. I like the XRC Style of bumpers but I want to create my own version. My friend has a plasma cam cutting system and he said he'll do the cutting for a small fee. Now I know most of the time in these situations you start off with cardboard patterns then you transfer them on to steel. When using a plasma cam system, how do you get the cardboard patterns onto the computer for the plasma cam?
krazymatt is offline
post #2 of 12 Old 04-27-2011, 12:41 AM
KMD
1976 CJ7
Scanner I believe.
KMD is offline
post #3 of 12 Old 04-27-2011, 04:28 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Either measure them out and enter the dimensions..
or take a digital pic from above, import the JPEG into the CAD, trace it out and scale it to size. That's usually pretty quick..
BESRK is offline
post #4 of 12 Old 04-27-2011, 05:41 AM Thread Starter
krazymatt
Thanks. That should be pretty simple then. Is there any advice I should follow as far as building this style of bumper nice and strong? I know the easiest way to make a tough bumper is to use a piece of 2x5" rectangular tubing, but that's to plain for my tastes. I know it will be a bit tougher to make a strong bumper out of plate steel. Any advice is welcome. THanks...
post #5 of 12 Old 04-27-2011, 06:56 PM
dodger889
Steel plate bumpers can be stronger that tubing bumpers Depends on the design and how well the welds are. remember The more triangulation you have the stronger it will be.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 12 Old 04-27-2011, 07:35 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Just make sure to run a flap disk along the plasma cut edges to remove all traces of the plasma dross. Otherwise, you'll run into porousity pinholes when you start grinding the welds down... ask me how I know..
BESRK is offline
post #7 of 12 Old 04-27-2011, 11:08 PM Thread Starter
krazymatt
I haven't decided for sure if i'll use the pc to cut the metal. My friend was telling me about some f the isues. I might be better off using the grinder or cutoff wheel. I'll see.
post #8 of 12 Old 04-28-2011, 04:39 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've got a plasma table.. if given the choice, I'd use it to cut everything.. everytime. It is that much better.
BESRK is offline
post #9 of 12 Old 04-28-2011, 07:36 AM
jatepper
As BESRK said, absolutely no way! You will not get a better, straighter, more accurate cut then the CNC.
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #10 of 12 Old 04-28-2011, 01:44 PM
mferrari
DelmarvaOffroad.com
mferrari's Avatar
I have a plasma cam table and the easiest way for you would be to grab deminsions from each piece and design it manually in the system. Pictures, tracing, and correct size gets really tough with the pcam software.
Michael Ferrari
Team 120 - DOR Racing - Racing for Operation Homefront
Operation Homefront (OHF) provides emergency financial and other assistance to the families of our service members and wounded warriors.
Thanks to our Sponsors:
Delmarva Offroad - F-O-A Shocks - BD Turnkey Engine - Under Cover Fab - Jer-C Transmissions - Quigley Driveshafts
You call it rolling, we call it R&D! 443-951-JEEP
mferrari is offline
post #11 of 12 Old 05-01-2011, 08:47 AM Thread Starter
krazymatt
I started laying out some cardboard to get an idea for my front bumper, and man it's tough to get the cardboard to stay the way you want it. It's getting discouraging real fast especially when this is all new to me. I've used cardboard patterns to reinforce a frame but building a cardboard bumper is another story.
post #12 of 12 Old 05-01-2011, 01:48 PM
KMD
1976 CJ7
You need the thin single layer cardboard not the coragated stuff.
KMD is offline
Xj bumper build with plasma cutter 25jon25 Fabrication Shop 5 11-30-2009 07:04 PM
New plasma cutter, eye protection question mforbes Fabrication Shop 11 08-07-2009 12:57 AM
Plasma Cutter Amp Question jonlb Fabrication Shop 1 06-28-2009 07:19 PM
plasma cutter PBR Fabrication Shop 1 01-08-2008 05:14 PM
PIAA 520 Plasma, are the lenses clear or plasma? Stricken Audio, CB & Ham Radios, GPS, & Electrical 4 09-20-2004 09:42 AM
