A question about mounting rocker guards - JeepForum.com
post #1 of 4 Old 09-19-2012, 03:02 PM Thread Starter
tomjohn777
I have a question about mounting rocker guards. I have seen where some company's use the body mounts on the bottom to mount their guards. If I used 1/4" plate do I need to trim 1/4" off the rubber mounts? I removed the factory running boards, but some of the bracket remains, I could tac weld the 6x4" angle to it instead, but I have not seen this done before. I plan on using 6- 5/16" SS screws and a 1/8" backing plate for the top mount.
tomjohn777 is offline
post #2 of 4 Old 09-22-2012, 08:31 AM
gunshw301
My poison spider rockets required trimming of the body mounts for installation. So yes, you will want to cut them down.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #3 of 4 Old 09-25-2012, 09:03 AM
kjg26
kjg26's Avatar
My currie rocker guards do not require trimming. It does mount to the tub as well as the body mount
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #4 of 4 Old 09-27-2012, 07:33 AM
firefighter315
It is just going to be a preference thing. Keep in mind though, if you are using 0.25" plate, you will be adding that much to only 6 of the 10 mounts on the tub. The other 4 toward the rear will be torqued down with less rise in each mount. I don't know that a 0.25 difference will matter greatly, but the difference has to be felt somewhere in the span of the tub across the frame. The 11th mount at the front clip won't matter as much as the components are separated from the rest a bit. Probably more forgiving at that point.
My YJ Build Thread
firefighter315 is offline
Rocker guards Crimbshaw188 General Jeep & Off-Road Equipment 6 03-17-2012 03:07 PM
Re-painting Rocker Guards/Corner Guards snowcrash General Jeep & Off-Road Equipment 3 03-01-2008 10:58 PM
Rocker guards Wrangler11 General Jeep & Off-Road Equipment 19 03-31-2007 09:32 AM
AEV Rocker Guards JPNHigh General Jeep & Off-Road Equipment 0 11-20-2005 03:53 PM
Looking for Rocker Guards DaMoose General Jeep & Off-Road Equipment 16 12-08-2004 03:19 PM
