Question about MIG settings/technique - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Question about MIG settings/technique
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 11-10-2013, 08:29 AM   #16
hmantractors
2004 KJ Liberty
Welds
Hi, 45 on the bevel, less than 1/16" for a land and about 1/8" gap between the pieces. You will never penetrate otherwise. If you do, you are going to have some dog ugly welds.
hmantractors is offline   Reply With Quote Quick reply to this message
Unread 11-12-2013, 07:23 PM   #17
andrewmacc
I was just having a discussion with my pipe welder buddy about this general idea.. I was saying that nothing beats a good tight fit-up if you can penetrate through the material thickness like on .120 wall tubing on a rollcage, but that a properly gapped set-up is easier to get 100% penetration on with thicker material.
You won't get 100% penetration on most things, and often it's not required, either. There's some give and take, it depends on what's being welded, like if you're welding a bracket on and both sides of the weldment will have weld, then that's just as fine and dandy.
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline   Reply With Quote Quick reply to this message
Unread 11-14-2013, 05:30 PM   #18
hmantractors
2004 KJ Liberty
Welds
If you are going to do a one sided weld then I would gap. If you can do a backside weld as well, then, I would back grind the material and do a proper 100% weld. I will admit I come from a pipe background.
