Question about MIG settings/technique - JeepForum.com
post #1 of 18 Old 11-02-2013, 05:26 PM Thread Starter
Dumpsterfish
Hola JF,
So I had some time today and some 1/4" hot roll plate scraps to play with, so I set up the miller 211 on 230v with 75/25 and .035 solid.
After several passes at various settings and using various techniques (stringer, weave overhand circles/weave underhand, whip, etc), this is the best I could come up with:
I'm satisfied with the bead itself, but as you can see, this didn't fully penetrate. I used a 45d bevel on each edge of the butt joint to make a 1/8" deep v groove, and had the welder set to voltage 7 and wire 55.
My question is this: do welder manufacturers assume a fully beveled joint when printing recommended settings? Do they assume you'll be manipulating/weaving at all? I really concentrated on maintaining a stick out of 3/8 and a 5d drag angle, but never quite burned all the way through.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
Dumpsterfish is offline
post #2 of 18 Old 11-04-2013, 10:05 PM
youngjeepr
The recommended settings are just to get you in the ball park of the right settings. Every person sets their machine up differently. As for your penetration did you leave a gap between the 2 plates? Did you have a landing on the bevels?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #3 of 18 Old 11-04-2013, 10:24 PM
nixer600
I usually leave it on auto set, and set the metal thickness a little thicker than what it is, and I'm usually happy with the weld.
Your beads look nice.
Sent from AutoGuide.com Free App
nixer600 is offline
post #4 of 18 Old 11-05-2013, 06:53 AM
Gyrocaptain
2007 KJ Liberty
Either move the wire closer to the front of the puddle and down into the root(key hole) or
do a root pass and then a hot pass.
Gyro
Gyrocaptain is offline
post #5 of 18 Old 11-05-2013, 10:36 AM Thread Starter
Dumpsterfish
Thanks for the tips. I did not leave a gap at all, and the bevels only went about halfway down (1/8). I think I'll try to gap it about 1/16 and see if that helps.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #6 of 18 Old 11-05-2013, 11:41 AM
youngjeepr
Make the gap about an 1/8" and bevel it all the way until you have about an 1/8" landing (flat spot) left. Then run a root pass then a cap or a fill and cap how ever many it takes to make it flush or close to flush with the plates
post #7 of 18 Old 11-05-2013, 11:49 AM Thread Starter
Dumpsterfish
1/8. Got it. So when miller says in the brochure that this machine is capable of 3/8 in a single pass...are they lying? Or do they assume like an .045 wire and 100% co2 setup on a different kind of weld? Didn't read the fine print...
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #8 of 18 Old 11-05-2013, 05:53 PM
danielbuck
1946 CJ2
Originally Posted by Dumpsterfish View Post
and a 5d drag angle
are you dragging? I don't know if it makes a whole lot of penetration difference, but I usually push if I'm using gas.
danielbuck is offline
post #9 of 18 Old 11-06-2013, 10:35 AM Thread Starter
Dumpsterfish
I've tried both, and I honestly didn't see much difference in penetration. The bead profile changed, but pushing didn't get any farther down.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #10 of 18 Old 11-06-2013, 10:37 AM
youngjeepr
People will argue back and forth weather you get better penetration or not by pushing.. When I was going to school for welding I was taught if there's slag you drag if there's not you push.
post #11 of 18 Old 11-06-2013, 11:30 AM
danielbuck
1946 CJ2
That has kinda been my experience too. Don't really notice much difference, but since it's always been suggested to me to push while using gas, I try and do that for what it's worth.
post #12 of 18 Old 11-06-2013, 12:38 PM Thread Starter
Dumpsterfish
Won't have a day off until Friday, but I'll try setting up a few different tests to see which will work out better for me.
Should probably be working on 3/16" anyway, since that seems to be the most common thickness for bumpers, sliders etc.
But then, there's my personal motto: if it's worth building, it's worth overbuilding.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #13 of 18 Old 11-07-2013, 08:22 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
<--------- Drags for penetration.. pushes for less penetration (sheet metal..etc).
BESRK is offline
post #14 of 18 Old 11-07-2013, 09:43 AM Thread Starter
Dumpsterfish
That's what I've read...seems to make sense.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #15 of 18 Old 11-09-2013, 04:16 AM
andrewmacc
There's really not much more penetration.. Jody on weldingtipsandtricks did a nice little demonstration of that, along with vertical techniques and showing the abysmal penetration down handing gets.
I use push for all MIG. Pushing gives a flatter bead profile, pulling builds up more. If I need buildup, I'll pull. Sometimes pulling is a little more accepting of gaps in the fit up.
If it's got slag, drag.
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
