Putting together an emergency stick welding kit for trail use, thoughts? - Page 2 - JeepForum.com
post #16 of 97 Old 08-09-2010, 11:22 AM
bryanm
1978 CJ5
I took a look at the Premier Power Welder it seems they are very proud of it when I look at the price.
I realize it is much more capable and probably weighs less than a couple of batteries but for $869.95
+$35 S/H seems pricey.
bryanm is offline
post #17 of 97 Old 08-09-2010, 12:02 PM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep that's a great (!) welder but $870 is too rich for my blood. I won't be carrying two batteries, the second battery will be from someone else I'm wheeling with.
Gone on vacation until August 25.
Jerry Bransford is offline
post #18 of 97 Old 08-13-2010, 07:23 AM
BigBass
I wouldn't carry any 60 series wire at all. Buy a tub of 7018 1/8" it's been my principal go to wire for the last 4 years. As far as a helmet get an old fashion one that flips and cut it down some for size. I also recommend leaving an extra dark lens in the glove box you can always hold that in front of your eyes in a pinch. Also buy a set of torchwear tig gloves there a little light but they double as excellent work gloves and they're also what I use for shooting gloves.
For a grand your might as well spring for the miller blue star welder generator. Some of them have there own wire feeders now
All Long Islanders Check out OutLawedOffroad.com throw my user name BigBass in the referral box
BigBass is offline
post #19 of 97 Old 08-13-2010, 09:26 AM Thread Starter
Jerry Bransford
Administrator
Why do you recommend 7018 over any 60 series? Everything I read and hear from very experienced welders recommends 6010, 6011, etc. for what I want to do with it.
post #20 of 97 Old 08-13-2010, 11:33 AM
Netpackrat
Jerry, I agree that 7018 is not the correct rod for this application, but be sure that you get a DC rod. 6011 is an AC rod, so it won't work as well if you use it to weld with batteries. 6010 would be my choice.
Netpackrat is offline
post #21 of 97 Old 08-13-2010, 11:47 AM Thread Starter
Jerry Bransford
Administrator
Thanks, I was planning to go with 6010 after reading the DC vs. AC info above. 1/16 or 3/32 seems to be the best diameter for 24vdc according to BESRK whom I trust on this stuff too so that's how I'll go, probably get both of those sizes in 6010.
post #22 of 97 Old 08-13-2010, 12:22 PM
BigBass
I like the arc quality of 7018, it burns threw nasty stuff pretty well if you can't clean it and it's good for over heads too. As for running off of batteries thats not something I've ever done so maybe a 60 series wire would run better. In my experience any time I'd run that small I would opt for mig or tig but I always worked of a welding truck or in a shop.
BigBass is offline
post #23 of 97 Old 08-13-2010, 03:10 PM
Netpackrat
The thing that concerns me the most is that the 7018 has to be kept extra dry, preferably in a rod oven. That could be a problem for a package of rod that is going to ride around in the back of a Jeep for who knows how long until it is needed.
post #24 of 97 Old 08-13-2010, 03:31 PM
Area.3.Fiftyone
I mentioned a weldernator in my previous post.
Is there a reason why one isn't being considered? I'll bet it work way better than just batteries.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #25 of 97 Old 08-13-2010, 03:54 PM Thread Starter
Jerry Bransford
Administrator
No doubt but all I need to make my quick emergency last-ditch-effort-when-nothing-else-will-work trail kit is welding rod and arc welding suitable welding goggles. The rest of it I already have.
Plus where the TJ with a/c is concerned, there's no real place to install the second alternator a welderator would require. The TJ's alternator and separate voltage regulator which is contained within the PCM isn't suitable for the alternator modification needed to make the weldernator work.
post #26 of 97 Old 08-13-2010, 08:30 PM
jason m
Nothing but the facts
jason m's Avatar
I repared a broken cast tranny mount on a 205 case with jumper cable, some Knickle rod on one end, 3 pairs of sunglass's and a tee shirt around my face. IT works and got this guy off the trail. Note to self never say in a crowd that your a welder
I would suggest to carry some Knickle rod, your Jeep might not have alot of cast mounts but alot of the early Jeeps and trucks do. Plus with knickle rod you can weld mild steel just as easy as 6011.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #27 of 97 Old 08-13-2010, 10:07 PM
bryanm
1978 CJ5
Just for information sake 6011 is AC, DC straight, DC reverse polarity---6010 is DC reverse polarity. DC straight is rod negative - DC reverse is rod positive --- 7018 is a low hydrogen rod leaves a heavy glass slag works best welding flat and up hill but is an all position rod --- in my opinion is harder to restart than 6011 or 6010, 7018 does lose some of the rods low hydrogen properties but old bouncing around in a toolbox 7018 rods will still make welds on some metal that will crack out if you try to weld with 6011 or 6010 if it were me I would carry both they have their uses. maybe the best suggestion was repair rod I don't remember the number but the one I have used is sold by Hialloy don't know if it is spelled right but the rod is blue it will weld cast and some of the castings like pitman arms stuff like that tends to run much like 7018. Just my 2 cents
bryanm is offline
post #28 of 97 Old 08-14-2010, 12:40 AM
Ironworker709
Ironworker709's Avatar
6010 will burn through the nasty junk 100% better than 7018 and gets a deeper penetration and works well for all positions.
As far as using in it in a shop where i can clean and prepare the weldment area i would prefer 7018 over the 6010,but in an emergency on the trail with all the dirt and grease and having no access to power tools,i would definitely want a 6010 ROD over a 7018 ROD
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #29 of 97 Old 08-14-2010, 12:59 AM
1990offroadYJ
I just watched "The Colony" for the first time the other day and they made a welder out of 3 batteries and jumper cables to make a bracket for an alternator. It seemed to work ok. I dont know if you could find online what they used but i guess it would be worth a shot.
1990offroadYJ is offline
post #30 of 97 Old 08-14-2010, 01:26 PM
bryanm
1978 CJ5
a good rod container is pvc pipe. I had some made with 2" glued a cap on 1 end and a female threaded coupling on the other and use a threaded plug as a top
bryanm is offline
batteries , battery welding , jumper cables
Stick welding tips Hesher420 Fabrication Shop 61 04-13-2010 03:14 PM
Stick welding Contra Fabrication Shop 12 05-14-2009 06:42 AM
Welding More YJ Rear Shock extensions to my frame with lincoln 220v stick welder bigstinger Fabrication Shop 4 05-30-2008 05:29 AM
Stick welding- Some tips? Ryanpowell167 Fabrication Shop 3 05-09-2007 08:58 PM
welding with arc / stick 1rockhead Fabrication Shop 15 01-12-2007 08:20 AM
