is this press big enough? - JeepForum.com
post #1 of 4 Old 02-13-2011, 09:32 PM Thread Starter
mike481
mike481's Avatar
I'm going to be re-gearing my axles myself in a few weeks and I need a press. Do you guys think the harbor freight 12-ton press will work? I know the 20 ton is a good price but I just don't see enough reason to justify getting it. I know a guy with a 50 ton press if I really need something big.
Thanks
Mike
Chuck- A better dog than I could ever deserve
RIP 4-14-2012
mike481 is offline
post #2 of 4 Old 02-14-2011, 01:29 PM
glenn-91YJ
glenn-91YJ's Avatar
Thanks
Mike
For a little more money I would get the 20 ton. I picked one up just before Christmas on sale and used a 20% coupon to get it for $169. The 12 looked too flimsy to me. I made a brake to bend 3/8" steel to build a plow frame and it worked great. Money well spent!
glenn-91YJ is offline
post #3 of 4 Old 02-14-2011, 02:53 PM
sherlocktk
I used a HF 12 ton for my press when I did my axles on my cj. No issues whatsoever. (also used to to get ball joints out) Get the 12 unless you plan on eventually doing a press brake or using it for somehting beefier.
sherlocktk is offline
post #4 of 4 Old 02-14-2011, 10:01 PM
SilverJ
SilverJ's Avatar
I tried to use the harbor freight 12ton and bent the press lower beam befor the crush sleeve budged on my pinion. It worked well for the bearings though.
SilverJ is offline
Looking to buy a shop press JOExFROMxNY Fabrication Shop 10 10-27-2011 10:04 PM
My DIY press brake JOExFROMxNY Fabrication Shop 8 12-10-2010 09:43 AM
Hydraulic Press cubewhiz Fabrication Shop 12 09-26-2010 01:44 PM
Shop Press? SuperWade2 Fabrication Shop 15 04-07-2010 07:56 AM
My New Drill Press BESRK Fabrication Shop 5 10-26-2008 09:11 PM
