Plasma Cutter - JeepForum.com
post #1 of 27 Old 10-20-2012, 12:40 PM Thread Starter
jerryjeeper
Plasma Cutter
Looking to buy a new Plasma cutter for home use and am open to suggestions on brand and size. I definitely want a dual voltage unit in case I have to use it on 115V. My shop has 220v available for any heavy duty work. Hoping to find one for around $750 or less.
Thanks in advance for any shared ideas. Considering the Eastwood or Hobart unit.
jerryjeeper is offline
post #2 of 27 Old 10-28-2012, 08:36 PM
wushaw
Rockin jeep
wushaw's Avatar
I have a TD cutmaster 52, it works fine, I use it pretty often and it's great for cutting old stuff real quick. If I were to buy again I would go with Hypertherm.
wushaw is offline
post #3 of 27 Old 10-29-2012, 09:55 AM
KMD
1976 CJ7
Save some more and get a Hypertherm 45
KMD is offline
post #4 of 27 Old 11-01-2012, 10:18 AM
brownbagg
1930 MK Compass
I got the hyperthem 30. Pretty nice machine. Paid 1200. The 45 would be better. But the 30 will cut quarter plate no problem.
brownbagg is offline
post #5 of 27 Old 11-01-2012, 01:11 PM
KMD
1976 CJ7
You will be happy with it. Hypertherm makes great machines.
KMD is offline
post #6 of 27 Old 11-01-2012, 02:39 PM Thread Starter
jerryjeeper
How is the service on the Hypertherm unit and are the consumables readily available? Both Hobart and Miller are easily serviced in my area.
post #7 of 27 Old 11-01-2012, 05:25 PM
JohndKc
1987 YJ Wrangler
My Hypertherm Powermax 65 stopped working a few months ago. All i did was get in contact with a qualified repair technician on Hypertherm's website, brought the unit in to his shop and had my machine back "relatively" quick. It was a little bit of a drive, but an extremely painless process in regards to warranty.
EDIT: Have your cash in hand and keep your eye out for a used system on craigslist. I purchased my P65 for 1800 with 2.5 years left on the 3 year warranty. It also came with a bunch of the little goodies that i wouldn't have bought if i would have bought it new.
33rd BCT
Alpha 2/122 FA
68W
JohndKc is offline
post #8 of 27 Old 11-02-2012, 07:42 AM
Orlie
For $750.00 you are going to have a hard time finding one that is a name brand. I know people don't like to buy Chinese stuff, but when I wanted to buy a plasma I could not afford $1500.00. I bought one off of eBay for $300.00 it is a semadre. It is 50 amps dual voltage and for what I need it works great. It will cut 1/4" all day, I tried to cut 1/2 inch it will cut it but slow. People buy what they can afford; some people can afford the name brands other can't. Good luck on buying your plasma they are nice to have in the shop.
Orlie
Orlie is offline
post #9 of 27 Old 11-02-2012, 01:20 PM
kercher
kercher's Avatar
so what is up with something like this.
http://www.northerntool.com/shop/too...6604_200336604
I am also shopping around for something that will have minimal use, but will help when needed. 1/4" plate is the biggest i need to cut.
kercher is offline
post #10 of 27 Old 11-03-2012, 01:49 AM
1989comanche
1989 MJ Comanche
The ones with built in compressors are pretty weak compared with the ones that don't. Get a hypertherm Pmax 30 it will do anything a normal home mechanic would normally need.
1989 Comanche
Mostly stock except homemade custom bumpers
1989comanche is offline
post #11 of 27 Old 11-03-2012, 05:50 AM
Orlie
I said the same thing when when I bought my plasma, 1/4 is the max I will need to cut. I lied to myself.
Orlie
Orlie is offline
post #12 of 27 Old 11-03-2012, 05:34 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
That Hobart is only 12amps... it's meant for sheetmetal.
I'd really look for something around 40amps for the typical "home garage".. where you plan on cutting brackets..etc.
Buy once, cry once.
BESRK is offline
post #13 of 27 Old 11-10-2012, 06:07 PM
my-jeep-earl
1971 CJ5
I'd stick with the Hypertherm line, they are great machines. The 30 is rated at 3/8", will sever 1/2" and the 45 is rated at 3/4" and will sever up tp about 1-1/8". Nice thing about the 45 is that the consumables from the 30 fit the 45 torch so you can turn it down and do "fine cuts" (yard art and such). I know Airgas has an ad going now through the end of the year, but look around, well worth it, I love mine!
my-jeep-earl is offline
post #14 of 27 Old 11-10-2012, 07:35 PM
zboss86
I like the Hypertherm 30 pretty well myself...
zboss86 is offline
post #15 of 27 Old 11-15-2012, 09:08 AM
RenoF250
I bought a PM45 off of Craigslist for $900 with ~$150 in consumables. It had been used very little. It is a nice machine. More power even when you don't need it lets you cut faster and longer.
RenoF250 is offline
