Pipe Kinking in pipe bender, Tried everything - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Pipe Kinking in pipe bender, Tried everything
NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDWe have Engo 10k Synthetic IN STOCK!!! Hurry while supplieSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREE
Unread 06-08-2014, 08:10 AM   #1
VBJeepWJ
2003 WJ
So I will start by listing the bender and pipe,
http://www.harborfreight.com/http-ww...2888-html.html
http://www.homedepot.com/p/Unbranded...BTBE/202310232
I have tried packing it with dry sand, wet sand with water, lubricating everything, but I still get one kink on the bottom side that is bad like a fold and then it rises out of the die, This starts fairly early at like 30 degrees, and even before that it doesnt look amazing. I figure I have to be doing something wrong because I have seen people use this with success. I know it doesnt give the best bends in the world, but they should still be useable and not just scrap. Any suggestions guys? Again it is just a single kink in the middle and then the pipe rises out of the die slowly.
VBJeepWJ is offline   Reply With Quote Quick reply to this message
Unread 06-08-2014, 07:19 PM   #2
jason m
Nothing but the facts
jason m's Avatar
When bending pipe with that style bender each hole represents a different size of pipe, starting from the center and working your up/out, you start with 1/2" sch40 then 3/4" and so on and so on.
So to bend 1.5" sch40 pipe you need to use the 5th hole out from the center, with the right size center shoe. Some pipe cant handle being bent, it will kink wrong or just rip open. But then some pipe will bend nice and easy, just depends on how well it was made which pipe really has no real high standard made unlike DOM.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt....
jason m is offline   Reply With Quote Quick reply to this message
Unread 06-08-2014, 07:30 PM   #3
skizriz
skizriz's Avatar
1978 CJ7
What Jason said.Use the proper spaced holes for the size of pipe. I use my HF pipe bender alot, and it never kinks it. I was actually surprised at how nice of bends it does. 90* with no deformation at all, no sand, no nothing.
Go to a plumbing supply house to get pipe. It's usually local made (ask them) and way better quality than the overseas made box store junk. Just looking at it you can see the better quality. Plus it's nice when it's not covered with that layer of black goop.
78 CJ7.. 258.. TH400/Dana18.. SOA/stock YJ springs.. 35" General Grabbers.. Waggy 44s.. 4.88 gears...Spartan/Lockright...Fiberglass front to rear
skizriz is offline   Reply With Quote Quick reply to this message
Unread 06-08-2014, 08:42 PM   #4
VBJeepWJ
2003 WJ
Jason.
I did use the bender correctly and had everything set up as you said and it still kinked it on approximately 5 or 6 bends
Unread 06-08-2014, 09:37 PM   #5
AtTheHelm
I was also having this problem a while back. What happened to me is the 'lips' of the die (also 1.5) spread apart so it didn't hold the pipe tight. Returned the die to HF and they replaced it. The new one they gave me has been working good. I don't use actual pipe in mine, only 'pipe size tube' from my steel supplier. It's bare uncoated tube rated for structural rather than astm pipe.
Also, if you put a couple short pcs of angle iron between the rollers and the pipe you won't get those dimples from the rollers.
AtTheHelm is offline   Reply With Quote Quick reply to this message
Unread 06-09-2014, 08:15 PM   #6
jason m
jason m's Avatar
Try some different pipe, if your setting it up right then its the pipe you have. Trust me I have made many trips to the scrap yard with split and kinked pipe.
Then I said screw this and bought a tube bender, along with the tube bender I bought a 1.25" sch40 Die and now I can make a mandrel bend in pipe and its as clean as what the tube I bend looks like.
The kinko bender is for those people cages I don't like, lol.
Jason.
Unread 09-10-2014, 02:49 PM   #7
rockymtwrangler
if you have access to and induction heater use it to warm the pipe up a bit if not use a torch but heat the pipe evenly across the outside radius 80-100
deg Celsius is all you need, i have to do this lots to bend aluminum
rockymtwrangler is offline   Reply With Quote Quick reply to this message
Unread 09-16-2014, 11:17 PM   #8
Bear304inc
Can't figure what's going on with my crap phone but look up,, "charlieboy65" harbor freight pipe bender modified for bending tube"
Another one I've seen is saying to use a smaller die,, use the die closer to the id of your tube/pipe. By turf dog? , also on you tube.
Bear304inc is offline   Reply With Quote Quick reply to this message
Unread 09-17-2014, 08:07 PM   #9
dwilliams35
Where is the pipe made? Haven't done it in a while, but we used to have huge problems with chinese pipe kinking: enough that we just changed everything to spec American pipe.
dwilliams35 is offline   Reply With Quote Quick reply to this message
Unread 09-17-2014, 08:26 PM   #10
Bear304inc
Not the first I've heard of this, guy I know will not buy from box stores, home depot etc, he goes to a welding supply shop. Cost more but he swears its worth saving the headache. I have had moderate luck with Chinese tube.
Unread 10-16-2014, 12:38 AM   #11
straightsixjeep
I have the 16 ton hf pipe bender. I've yet to bend pipe however I modded it for tube. You may want to search youtube for harbor freight bender modifications. Building a strap to retain the pipe in the center shoe may help with the kinking.
http://www.jeepforum.com/forum/f22/98-xj-gettin-her-trail-ready-1417602/
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 11-07-2014, 05:19 AM   #12
Nicksan
1995 XJ Cherokee
Have you tried bending slower?
I have the same bender and I noticed that the pipe would slip in the die sometimes.
Nicksan is offline   Reply With Quote Quick reply to this message
