Picked up a exhaust for my niner today. lmk what you think of the fab job? - JeepForum.com
post #1 of 7 Old 08-26-2013, 05:31 PM Thread Starter
Alotaglock
Hello guys,
I bought this exhaust today for my 5.9 from some guy that custom built it then his son wrecked it a week after he put it on. Just wanting to get your opinions on if it looks like it will be fully functional and do you think I'll notice a difference. He said he put a lot of hours in to building it. Was it worth 300.00? He says the stock exhaust is really restrictive. Here is what he emailed me...
"The exhaust system is in really good shape. The only original parts are the tailpipe and cast iron manifolds. (manifolds stay with the engine) I replaced the crimped down section of the tailpipe, where it goes over the axle with a new piece of 3". It fit fine without the crimp, but I do have a 2" lift, so that may be a factor in the clearance.
The 3" cat and muffler were around $90 each when I bought them. The mandrel bent tubing was not cheap either, but I don't remember how much I paid.
The stock primary tubes are 2" and the passenger side tube is crimped down to about half of that. You can't see the crimped section of this pipe because it has an aluminum wrap but it's there. I replaced it with 2 1/4" mandrel bent tubing, no crimps. Lots of work cutting and welding it all together. The exhaust system got about 35 miles on it before my son wrecked it. I'm asking $300 for the exhaust." I will have to upload pictures from my computer shortly. Thanks, Aaron
Alotaglock is offline
post #2 of 7 Old 08-26-2013, 05:43 PM Thread Starter
Alotaglock
Here are a few pictures. It does look to me like Air will flow a lot better through the Y pipe and the whole exhaust in general. But I'm not a professional.
post #3 of 7 Old 08-26-2013, 05:50 PM Thread Starter
Alotaglock
He cut out a crimped piece of exhause and put in full 3 inch on this back half where you can see the welds.
post #4 of 7 Old 08-27-2013, 01:19 AM
andrewmacc
Or get something like this for $120 and install your own cats/mufflers in between
http://www.mandrel-bends.com/catalog...te-bk-874.html
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #5 of 7 Old 08-27-2013, 04:24 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hmmm.. you might want to swing by a couple local muffler shops first.
I had a "header collector-to-rear bumper" dual exhaust bent and welded for my CJ5 for under $300. I did supply my own Flowmasters but the shop did all the tubework and hangers. Tucked everything up out of the way really nice too. This was at a local "Big Al's" muffler shop. All tube was 2.25".
Not saying the $300 is a bad deal.. I honestly don't know. I'd just check to see what a full system would cost if you supplied your own cat/muffler..
BESRK is offline
post #6 of 7 Old 08-27-2013, 06:34 PM
swirve
Doesnt look like anything special to me. If he custom built it why is the tail pipe section soo rusty.
swirve is offline
post #7 of 7 Old 08-28-2013, 12:37 AM Thread Starter
Alotaglock
He used the stock 3 inch pipe but cut out the crimped section and welded in a 3 inch round piece to replace it. The crimped section was smashed down to half its size meaning that air wouldn't leave as quickly. Plus this has a 3inch highflow cat and some type of aftermarket flowmaster type of muffler. Basically it seems as if the guy just took out all the crimped sections and built a smooth flowing Y-pipe. I'm going to have an exhaust shop mount it just incase I run in to any problems. I will let you know if I feel a difference. I'm sure I will. But who knows.
