Oxy/acetalene welding pros and cons - JeepForum.com
post #1 of 8 Old 01-11-2008, 04:57 PM Thread Starter
dickensheets
Sorry for the new thread but this is a different question sort of...
I have a buddy who owns a chain of welding supply stores. He is willing to make me a great deal on a welder of my choice.
I'm leaning toward a Victor gas outfit. I can weld/cut/bend instead of just weld.
My real question is this: how practical is it for me to think I could make a safari rack or bumper with just this equipment. I know it's a slow way to weld but what am I missing to steer me to a 220v mig.
Thanks, Ryan
99 WJ V8, 245/75/16 MT/R and Rusty's 2.5" coils and shocks, IRO trac bar, homespun end links, block heater!! 220V MIG w/75-25 and OXY/Acetalene rig if you need it! Just let me know
dickensheets is offline
post #2 of 8 Old 01-14-2008, 09:42 PM
Psyker
O/A welding is a pain in the *** and most guys don't bother.
Don't get me wrong, my setup is one of the most used tools in the garage, but not for welding. If you are tying to save some money buy the O/A setup and a AC/DC stick welder. You can do anything with that combo. It will take more work, and not have as clean welds as Mig, but you will be able to build bumpers and stuff.
Call Sign: KF4ZHT
'96 Green XJ SE - I6, AX15, NP231, 2.5" Lift
'90 White YJ - 4 squirrels spinning a toothpick (i4 w/ax5) - WIP
Psyker is offline
post #3 of 8 Old 01-14-2008, 09:56 PM
Bigbob
Bigbob's Avatar
Oxy Act brazing is great for light stuff. But it develops a lot of heat and warping is a problem. It also does not penetrate at all. Most stuff you will do on a Jeep needs to be welded, not brazed.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #4 of 8 Old 01-14-2008, 10:45 PM
Waldn
Oxy actelene welding can produce very nice strong welds although it is a slow process, but should not be confused with brazing which is done with a brass or bronze filler rod much akin to soldering.
97 TJ SE 2.5L Auto, 3" BDS, 255/85-16 BFG MT KM
04 KJ LTD Frankenlifted, Full Mopar Armor, front reciever hitch for winch, Rubicon Moabs and MTRs
Waldn is offline
post #5 of 8 Old 01-15-2008, 07:53 AM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
If he is going to cut you a deal i'd say go for a good 220v miller MIG welder or if you are good enough get a TIG welder. my buddy worked for the navy for 10 years and is a master TIG welder and is teaching me the trade, its very strong and exact, MIG welder is good but it is defanitly thicker and doesn't penetrate as deep as TIG welding does. IMO, go TIG.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
post #6 of 8 Old 01-17-2008, 09:19 AM Thread Starter
dickensheets
I'm ready to spring for the Lincoln Power Mig 180 all things considered now. Are any of these MIG machines convertable to TIG?
Thanks guys
post #7 of 8 Old 01-17-2008, 06:42 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Thanks guys
Only if you're buying a high dollar multi-process machine.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #8 of 8 Old 01-29-2008, 09:04 PM
hansw3
1978 CJ5
2 comments:
1. I successfully brazed together a front clip mount for my fiber glass front end out of 1" square .090 wall steel tubing. I agree though that a mig or tig would be better for welding.
2. My buddie has a good quality miller tig and said he is lucky to get 1"/minute feed rate when using it. To compound the problem, if you buy a cheap import the duty cycles can be only 10% which means you'll be welding slow and stopping and waiting for it to cool down before you start again. Mig is easiest(IMO) and fastest (fact). A name brand 220V single phase Mig would be great.
hansw3 is offline
pros, cons of jeep with IFS? psycopanther Engines & Drivetrain 21 04-21-2009 08:45 PM
sub/amp more cons then pros? 03Wrangler Audio, CB & Ham Radios, GPS, & Electrical 2 11-19-2006 01:12 PM
Pros and cons of.... JeeperAbe Audio, CB & Ham Radios, GPS, & Electrical 17 10-04-2005 03:56 PM
Galaxy DX 959 Pros/Cons? 175MM BULLDOG Audio, CB & Ham Radios, GPS, & Electrical 3 10-03-2005 10:38 PM
pros & cons of tj lifts Jeep4fun Tires & Wheels 0 06-11-2004 11:23 PM
