opinions- patch or new panel? - JeepForum.com
post #1 of 11 Old 02-05-2011, 05:17 PM Thread Starter
RJMICP
I bought a whole replacement rocker panel and was originally going to just try to replace the whole thing, but after reading a bit, I'm not quite sure... attached is the pic... what do you all think? give some advice/opinions?
RJMICP is offline
post #2 of 11 Old 02-06-2011, 05:04 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Generally, I try to replace as small an area as I can... especially, if the replacement panel has alot of complicated attachment points. However, some panels are easier to replace than others so I guess you'd just have to weigh the pros/cons.
How complete is the replacement panel? Where does it attach? How hard to remove the existing panel? Is that all the rust? These are the types of questions that will determine the point at which a panel replacement outweighs the patch panel... or vice-versa.
If the rust doesn't get up into the "Jeep" lettering, I'd really try to save the lettering... leaning toward a patch panel.
BESRK is offline
post #3 of 11 Old 02-06-2011, 05:31 PM
1222
RIP John
1222's Avatar
Since itís a flat piece that needs replacing I say to cut out the rusted part and replace it with new metal.
(2011-2016)
1222 is offline
post #4 of 11 Old 02-06-2011, 10:01 PM
dodger889
What is bad about that spot is what is behind it and under the plastic that can not be seen in that picture. That one spot seems to be the spot that just about all the YJ's rust out from the inside out. You should fix he reason moisture is retained in the area before you seal it up.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #5 of 11 Old 02-11-2011, 06:18 AM
zeronight
1982 CJ7
i vote for a patch but i think you are going to loose the p eather way. and the price of replacement pannels with jeep stamped in it are crazy high in my opinion.
good luck!
zeronight is offline
post #6 of 11 Old 02-11-2011, 06:50 AM
Machinist
That's what I would do also.I understand you will loose the jeep lettering after you get to cutting but its way easier and cheaper.if you get a fiberglass tub they dont have the letters and I have seen a few of the raised letter stickers places that are really close to being the same as what the metal is raised.
Machinist is offline
post #7 of 11 Old 02-11-2011, 12:04 PM Thread Starter
RJMICP
ah, in that case then, should I just cut the whole "Jeep" emblem so it doesn't look like an illiterate "Jee" that I drive? probably be a little easier to get it to look better with the weld too..
RJMICP is offline
post #8 of 11 Old 02-11-2011, 12:20 PM
Machinist
Yuppers
post #9 of 11 Old 02-11-2011, 02:25 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
I think you might get your feelings hurt when you start grinding. You're going to find a lot more rust than you might think is there.
I agree with saving the Jeep lettering. If it's rusted into your lettering, I'd go to a U-pick salvage yard and cut some out of a junk Jeep.
Pacfanweb is offline
post #10 of 11 Old 02-11-2011, 08:53 PM
TheNewbie
Someone on here a while back did that and then welded the "Jeep" part back in upside down. It looked pretty cool IMO.
1995 YJ 2.5 - 4Ē RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #11 of 11 Old 02-11-2011, 10:42 PM
Boodyrider
Once you have a hole that big... I'd find a rust free tub and start over. It ain't the only place it's a rust bucket.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
Body Tub Patch JEBETS Fabrication Shop 5 09-04-2011 09:24 PM
1st time welder: I want to weld patch panel onto Wrangler YJ....please advise GLOCK1 Fabrication Shop 13 01-02-2011 11:18 PM
gas tank patch PBR Fabrication Shop 6 03-23-2008 08:44 PM
Patch panel suntzur General Jeep & Off-Road Equipment 2 10-14-2007 06:18 PM
ZJ patch panels? Aceladriver General Jeep & Off-Road Equipment 0 11-13-2006 04:26 PM
