Operation Slip n Slide: My first Jeep fab project - Page 2 - JeepForum.com
post #16 of 31 Old 09-12-2013, 11:45 PM Thread Starter
Dumpsterfish
Finally had a day off, and managed to get some work done.
First I made a Template out of cheap-o pine...
Then I cleaned up all my parts and got them clamped up for welding:
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
Dumpsterfish is offline
post #17 of 31 Old 09-12-2013, 11:48 PM Thread Starter
Dumpsterfish
Oops, hit send by accident.
All tacked together...
And when I fit it to the jeep...the dang mounts AREN'T ALL AT THE SAME HEIGHT!!!
Turns out the rear mount sits a full 1" lower w/r/t the tub than the front. Time to break out the calculator and make some miter cuts....at least all the holes line up. I'll take what I can get here.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #18 of 31 Old 09-13-2013, 02:24 PM Thread Starter
Dumpsterfish
Used some scrap tubing to move the ends of the sliders apart, tacked them up using miter cut standoffs (it was a 15 deg miter)
Don't like the way they line up. Close, probably passable, but not good enough. Headed to the yard to find some scrap plate, gonna make a jig and do this the right way.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #19 of 31 Old 09-20-2013, 12:23 AM Thread Starter
Dumpsterfish
Ok, got the stock for a jig, some 1x3x.125 from the rems section. Here's the progress I made today:
Also got my DOM in for the rub rails. Hope to have some more pics up soon.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #20 of 31 Old 09-24-2013, 06:58 PM Thread Starter
Dumpsterfish
The journey continues. As I noted a few comments up, the body mounts are not vertically equidistant from the tub. I had assumed they ran sequentially farther away from front to back, but before adjusting the mount heights on my jig, I took some measurements using a piece of scrap flat bar and a combo square. Back:
Middle:
Front:
So the front, at 1/2", is in fact the shortest...but the longest is the middle at 1&1/8". Glad I checked!
Here's a sketch of the planned adjustment to my jig:
I know I have some leftover 3/16" stock, and pretty sure I can rustle up some 5/8". Hope to finish this jig on Thursday, maybe have a set of sliders welded up by Friday afternoon.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #21 of 31 Old 09-25-2013, 03:40 PM
WSS
WSS's Avatar
1972 CJ5
two 5/16" plates would work in a pinch. I have some 5/8" in AR400 that I can plaz for you if you need it. I'm am in Inland Empire.
WSS
LOOKIN GOOD!
If you are a Purist, don't click here:
My CJ5 Build and fun stuff:
WSS is offline
post #22 of 31 Old 09-25-2013, 06:58 PM Thread Starter
Dumpsterfish
Originally Posted by WSS
two 5/16" plates would work in a pinch. I have some 5/8" in AR400 that I can plaz for you if you need it. I'm am in Inland Empire. WSS LOOKIN GOOD!
Thanks!
Our scrap bins runneth over, so I had no trouble digging up some 5/8 structural cutoffs. If only I had the day off....
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #23 of 31 Old 09-26-2013, 07:22 PM Thread Starter
Dumpsterfish
Only had an hour or so today...finished the jig:
Have tomorrow off though...will post progress!
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #24 of 31 Old 09-27-2013, 10:57 PM Thread Starter
Dumpsterfish
Big day today...
First I got all my pieces cleaned up and in the jig:
Attachment 713361
Then time to tack and check the fit:
Attachment 713369
And SWEET JEEBUS THEY ACTUALLY FIT!!! HUZZAH!!
Attachment 713377
So time to weld...
Attachment 713385
And start bending some tube. Gotta say, bending 1.75" .120 wall on my model 3 is a WORKOUT.
Attachment 713473
I use templates...because I was told there would be no math.
Attachment 713481
Attachment 713489
After bending, I struggled to find a good way to accurately miter the bent rails. Settled on a basic jig made of some 4" angle, and some fancy work with the old angle grinder/cutoff wheel.
Attachment 713505
Attachment 713513
Attachment 713521
Then it was time to toss them on the jig, and weld them on. I tried to match the upward angle of the rails to that of the lower portion of my rocker panels (54 degrees from horizontal). They look great, but the miter made for an opening way wider than the 2". Fit was bad, welds suffered. Had to use a little piece of 1/8" to fill the gap.
Pretty happy with the day's work. Should be able to finish next week.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #25 of 31 Old 09-27-2013, 11:29 PM Thread Starter
Dumpsterfish
None of my pics uploaded!
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #26 of 31 Old 09-27-2013, 11:29 PM Thread Starter
Dumpsterfish
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #27 of 31 Old 09-30-2013, 11:06 PM Thread Starter
Dumpsterfish
So I finally finished!
Had to weld in some standoffs...the miter/fit issue was solved by adding in some 1/8" flat bar ground to fit.
Finished and painted:
And mounted up!
All in all, I'm very happy with the fit. They sit just a bit higher than the frame rails, and the rub rails hug the tub nicely. Now to go test them on some rocks...
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #28 of 31 Old 10-01-2013, 12:08 AM
WSS
WSS's Avatar
1972 CJ5
Duly protected! A strip of anti-skid/slip across the top would make a nice footing to get in and out. I used the stuff that feels like sandpaper, it sticks really good
WSS is offline
post #29 of 31 Old 10-01-2013, 10:35 AM Thread Starter
Dumpsterfish
Nice. Yeah I'm gonna slap some on. The roll bar paint I used (VHT) says it fully cures in 7 days. Will stick some on then.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #30 of 31 Old 10-01-2013, 02:42 PM
407863
Guest
Sweeeeeeeet!!!!! Cant wait to get mine!!!!!!
407863 is offline
