Offroad trailer - JeepForum.com
post #1 of 2 Old 07-23-2008, 05:15 PM Thread Starter
frumpy
frumpy's Avatar
Offroad trailer
I have been looking at a lot of these "offroad trailer" threads and am starting to think about getting/making one for myself.
I was origianlly thinking I was going to tow my jeep but most the trails here are close by and not much outside of 3 hours for wheeling unless you go a lot further.
I'm currently watching kijiji for a cheap utility trailer to overhaul. I'm pretty set on a utility trailer because it will not see much trails at all. I more so want it for carrying my spare tire, extra tools, camping gear, big cooler etc.
I'm trying to find something around 4x6 and plan on running 33" tires on it (and my jeep).
Now for my questions. Whats the best way to lift it to the proper hieght? I'm hoping SOA will put it close but if not should I be going to the wreckers to find some springs, build a custom pack, or just go out to a trailer store and buy some. Also, I would like to make it enclosed so I can use the top to set up a tent and keep it off the ground (and hopefully level).
Guess I'm just looking for ideas and pics.
thanks
2002 Dodge Dakota quad cab V8
2011 Dodge Grand Caravan
frumpy is offline
post #2 of 2 Old 07-23-2008, 05:25 PM
twobit
Most trailers are built with the springs mounted under the axle tube. If you build your own, build it with the springs above the axle tube. This gives you about 3 to 4 more inches of clearance for off-road. Also use extended shackles at the leaf ends.
Some makers of tent trailers are now making off-road models with high clearance. Go to a camper dealer and look under these for construction ideas.
06 Solar Yellow TJ X obtained 10-2009 with 3400 miles
99 Cherokee Sport, bought new, now @ 223,000 miles
Southwest Texas
twobit is offline
Fabbing Offroad Trailer herculz General Jeep & Off-Road Equipment 2 12-29-2009 10:49 AM
Offroad Trailer Build! dawsonc61 Fabrication Shop 27 10-09-2008 11:41 PM
Offroad Trailer Rebuild UTmike Fabrication Shop 12 08-04-2008 05:11 PM
I rebuild the offroad trailer again! deathblade556 General Jeep & Off-Road Equipment 8 07-24-2008 10:00 AM
Anyone have an Offroad Trailer? Jkeith0004 General Jeep & Off-Road Equipment 21 12-09-2007 06:47 PM
