*Official* Cage idea/pic/discussion thread - Page 72 - JeepForum.com
 2Likes
post #1066 of 1110 Old 03-14-2014, 11:05 AM
cjjon7
1983 CJ7
Has anyone developed a rollcage design that will still be able to use an aftermarket soft top? Im looking to fit a Rampage Frameless TJ top to my CJ, will just build the cage to mimick the oem roll bar but just was wondering if its been done before?
cjjon7 is offline
post #1067 of 1110 Old 03-14-2014, 02:14 PM
bigt2317
Mall Crawler
bigt2317's Avatar
Sure, just follow the lines of the factory and you should be good to go. Go measure a TJ stock bars and make the outside dimensions the same with the same degree of slope on the "C" pillar.
2005 LJ Black Rubicon - Boring mallcrawler
2005 LJ Khaki Rubicon - slightly modified - TOTALED
FOR SALE
PM me for great deals on enclosed or open trailers
bigt2317 is offline
post #1068 of 1110 Old 03-15-2014, 01:58 PM
Dr.Dirty
Here is one Im working on for a buddy. Still have a few bars to add then she will be done.
Dr.Dirty is offline
post #1069 of 1110 Old 03-17-2014, 01:13 PM
Lifted96ZJ
1973 CJ5
I really like the way that turned out Dr.Dirty. It will be a great looking cage once it's all welded up!
Build Thread
http://www.jeepforum.com/forum/f8/1973-cj5-trail-rig-hunting-rig-build-1403107/
Lifted96ZJ is offline
post #1070 of 1110 Old 03-24-2014, 12:22 PM
g-rocc
Finally got started on mine, here is a little teaser pic:
I have some serious questions about seat mounting to the cage though. Any pics and advice on seat mounts would be greatly appreciated.
g-rocc is offline
post #1071 of 1110 Old 03-24-2014, 12:27 PM
Dr.Dirty
Here is the YJ one all finished for now. This summer Ill add A to B pillar bars along with B to C pillar bars. I will also be adding all the seats mounts into the cage as well.
Dr.Dirty is offline
post #1072 of 1110 Old 03-24-2014, 12:46 PM
Danno6102
What seats are you installing? How do they mount? My method was pretty simple. I just ran a 1.75 DOM from B to B & then another right in front of the console ebrake lever behind the cup holders where the trannt tunnel steps down. You can mount tabs off of those tubes. Or in my case, my seats bolted down, instead of through the side, I used a C shaped piece notched over both tubes. You can see them in my pics in post #1062.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #1073 of 1110 Old 03-24-2014, 02:35 PM
g-rocc
I have the Corbeau Baja XRS seats. They bolt up from the bottom of the seat.
That's a good idea with the c-shape piece. How thick was the steel you used for that? Do you have a pic of that front tube placement in your Jeep?
g-rocc is offline
post #1074 of 1110 Old 03-24-2014, 07:12 PM
Danno6102
I used a piece of 2" x 6" 1/8" wall rectangular tube. You can get two out of one section. One warning, it is really difficult to access the rear seat bolts. Its a 2 person job to tighten or loosen them.
Pardon the mess.
post #1075 of 1110 Old 03-24-2014, 10:15 PM
g-rocc
That looks really good. Top of my list right now. Any regrets or changes you would make to that set-up?
g-rocc is offline
post #1076 of 1110 Old 03-25-2014, 05:20 AM
Danno6102
Maybe cut out the sides a bit at the bolt locations so they are a little easier to access. For my own personal preference, I might try to get them a little lower. Other than that, it was pretty simple to execute.
post #1077 of 1110 Old 06-05-2014, 05:00 PM
83cjnash
1983 CJ7
Not dig this back up but what are the reasons for mounting the roll bar to the frame using poly bushings? I've been seeing a lot of people doing that.
83 CJ7, 258 ci, T176, 33x10.5 km2 stock axles with 2.73 ratio
83cjnash is offline
post #1078 of 1110 Old 06-05-2014, 05:04 PM
bigt2317
Mall Crawler
bigt2317's Avatar
It gives the frame a little isolation from the cage and helps absorb harmonics and lower resignation on the inside
FOR SALE
bigt2317 is offline
post #1079 of 1110 Old 06-30-2014, 09:59 PM
cjjon7
1983 CJ7
Well here it is, Built to accept a Rampage frameless top for a TJ...Although this is a CJ...with a YJ family bar as a base, YJ Half Doors...and TJ Door Surrounds
We dubbed it a CYTJ during the build.
It was interesting to say the least. Design came out awesome, there are lots of hidden features that the pictures dont do justice, like provisions for an air tank mount behind the rear seat, plenty of OH SH*T handles to go around, gauge pods for some up front monitoring of engine status, flashlight/extinguisher/speaker mounting zones...The list continues.
Cage was designed by the three of us, but built by Dave and Sean of DS Fabworx in Pensacola FL.
cjjon7 is offline
post #1080 of 1110 Old 07-01-2014, 11:42 AM
Renegade82
1982 CJ7
I can finally contribute to this thread. My cage isn't installed but it's all done but the paint.
This is a side shot with it all tacked in place to locate the sliders before tacking them in place.
1
This is with all the welds done and working on the console.
2
Here's the sliders, which have the front tie-in, and the rear tie-ins, all welded up ready for paint.
3
Here's the front tie-in under the A-pillar with a 3/16" plate, (4) 3/8" bolts, and a piece of 3/8" thick rubber for an isolator.
4
This is the B-pillar tie-in made from 1/4" plate and angle, (3) 3/8" bolts and a 1/2" rubber isolator.
5
The rear tie-in is a piece of 2" HREW with a 3/16" plate on top and a 1/4" angle at the bottom.
6
A cover for the top of the console.
7
And the console underneath, minus the dome lights and CB.
8
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
Official BFG KM2 thread Magus2727 Tires & Wheels 8 12-07-2008 07:44 PM
The official HID thread lib Audio, CB & Ham Radios, GPS, & Electrical 88 10-16-2005 10:00 PM
The official 4x4 video thread mnjeep General Jeep & Off-Road Equipment 37 01-04-2005 01:03 AM
OFFICIAL ** Steering Fabrication Thread ** FunkSkunk Fabrication Shop 21 04-21-2004 07:41 PM
