*Official* Cage idea/pic/discussion thread - Page 70 - JeepForum.com
 1Likes
post #1036 of 1110 Old 01-04-2014, 05:52 AM
Danno6102
Originally Posted by skizriz
I like the looks of that design. While out in the garage last week, bored with nothing to do, I copied your basic design out of some 5/16" brake line that I had laying around. It was half out of sheer boredom, half learning experience. Seems to be a pretty strong overall design. Keep in mind that the brake line was bent using only my fingers, with a couple of small tack welds at each joint. Not scientific by any means, but a fun little experiment. A little bent, but not broken.
That is pretty sweet! Never thought of mocking one up out brake line.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #1037 of 1110 Old 01-06-2014, 07:40 AM
zachv
I wonder if it would have held if you had done grab handle gussets and a small corner gusset at the B-pillars.
Have a great day!!!
Zach Vaughn.
570-385-3931--shop
zachv is offline
post #1038 of 1110 Old 01-06-2014, 10:08 AM
skizriz
1978 CJ7
It sure wouldnt have hurt to have some gussets. My thinking after seeing the pictures, is that by raising the center section of the two middle overhead tubes (where it forms a square) higher than the outer tubes, would help carry the force to the corners.
Looking from the side it would be a somewhat triangulated roof.
Something like this. The black part would be slightly higher than the rest. If it tried to compress downward, the forces would go outward on the red tubes. That spreads it out over eight points.
The extra rear tubes I drew in wouldn't be a bad idea to help carry the load if the cage tries to fold rearward (endo, my worst nightmare). They would also make nice mounts for a hi lift jack, cooler rack, etc..
Having the overhead tubes flat and even, seems like it would rely on sheer strength to keep it from coming down on the seats, IF the load was all in the center and not spread out over the uprights.
A load in the center would want to cave in and bring the A pillars back towards the center.
The above picture would try to push the A pillars forward instead. The two flat outer overhead bars would keep it from doing so (unless they would stretch.).
Make sense??? I'm not an engineer by any means. LOL
skizriz is online now
post #1039 of 1110 Old 01-16-2014, 05:41 AM
Danno6102
My tube is in & I'll be starting the first of two cages beginning of February. Couple questions. This is going into a TJ. I don't really want to mess with the upper windshield brackets on the spreaders, but I think they're a necessity on the TJ as there isn't anything else holding the windshield from flopping forward. Is there anything stopping me from welding my windshield hinges? If anything needs to be done that requires the windshield being laid forward, it'd be almost as fast to just unbolt the "hinges" & remove the windshield completely.
post #1040 of 1110 Old 01-16-2014, 07:47 AM
PDK
I wouldn't recommend welding the windshield frame. Many folks, including myself are creating a windshield "quick release" so you can just pull the window off when wheeling. It's really as simple as taking out the stock pin (which isn't actually all that easy) and then getting an indent pin to replace it. Total cost is around $10. I also got new grade 8 bolts that hold the windshield from folding down.
I guess it also depends on what the Jeep is used for primarily. There are two sides to this and a lot of people prefer to have the windshield attached at the top...and many don't care-like me...it's up to you.
PDK is offline
post #1041 of 1110 Old 01-16-2014, 08:13 AM
Danno6102
I wouldn't be welding the actual windshield frame, just the hinge, so it no longer hinges. Would probably cut the hinge pin part off completely & fill the gap between upper & lower plates with weld & grind it smooth so it looks nice & clean. If I F them up, I guess I could always buy new ones. Maybe some nice chrome ones. I just want to make sure there isn't a reason it NEEDS to hinge before I weld the hinges up. Mine is more or less a trail rig & weekend cruiser. Only time I'd be taking the WS off is hardcore wheeling trips. Maybe 2 or 3 times a year, & an impact would make quick work of that.
post #1042 of 1110 Old 01-16-2014, 08:27 AM
kellerumps
kellerumps's Avatar
What size are the bolts? That way I can get rid of the Stock Star POS bolts.
I don't look for problems....They find me.
Member of:
kellerumps is offline
post #1043 of 1110 Old 01-16-2014, 08:29 AM
g-rocc
That is a good question and something I haven't taken much thought to. Any have pics of how the are attaching the windshield to the cage?
g-rocc is offline
post #1044 of 1110 Old 01-16-2014, 07:10 PM
PDK
Can't remember off the top of my head. Just take one with you to the bolt store
PDK is offline
post #1045 of 1110 Old 01-17-2014, 11:26 AM
Renegade82
1982 CJ7
Just throwing in my two cents, but I wouldn't even consider tying anything to the windshield frame. If they're anything like a Jeep's ws. it's just a rectangular tube of sheetmetal wrapped around glass. It lends very little in the way of structural support and should be irrelevant when it comes to a roll cages design. When the factory designed those spreader bars to bolt to the windshield it was just for looks, just as the sport bar is. Plus, if it's not tied back it's easily folded down.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #1046 of 1110 Old 01-17-2014, 12:05 PM
Danno6102
You guys aren't picking up what I'm laying down. I'm not welding on, or to, the windshield frame, or relying on the windshield frame at all for any part of the roll cage design. A pillars will go through the dash & to the floor. I was asking about welding the HINGE. This thing...
I'm just going to go the super simple route right now & lash it to the upper windshield bar & doing the quick disco PDK talked about.
post #1047 of 1110 Old 01-17-2014, 12:10 PM
geiman
I've seen many people post on JF about not having their windshield connected after installing a new cage and they all said it was just fine. I've yet to see anyone say otherwise.
YMMV of course.
geiman is offline
post #1048 of 1110 Old 01-21-2014, 07:44 PM
EdJonesJeeper
Anyone have pictures of how you tied in the c pillar?
EdJonesJeeper is online now
post #1049 of 1110 Old 02-02-2014, 08:03 AM
EdJonesJeeper
Originally Posted by cjlinn
Originally Posted by '92 vegas YJ View Post
Finally got my cage all finished up and just got back from a weekend of wheeling.
Those frame tie ins are beefy and sexy. Nice work. Makes me wanna watch a Jean-Claude Van Damme movie
Where did you find the c pillar bracket? Or was that custom fab?
post #1050 of 1110 Old 02-02-2014, 10:15 AM
'92 vegas YJ
I custom made everything. They are Ruffstuff bushings. Everything else was me.
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is online now
Official BFG KM2 thread Magus2727 Tires & Wheels 8 12-07-2008 06:44 PM
The official HID thread lib Audio, CB & Ham Radios, GPS, & Electrical 88 10-16-2005 09:00 PM
The official 4x4 video thread mnjeep General Jeep & Off-Road Equipment 37 01-04-2005 12:03 AM
OFFICIAL ** Steering Fabrication Thread ** FunkSkunk Fabrication Shop 21 04-21-2004 06:41 PM
