*Official* Cage idea/pic/discussion thread - Page 65 - JeepForum.com
 2Likes
post #961 of 1110 Old 09-26-2013, 08:42 PM
soonermatt
I like the first one. I bet everyone says the third is strongest.
soonermatt is offline
post #962 of 1110 Old 09-26-2013, 09:41 PM
WSS
WSS's Avatar
1972 CJ5
Originally Posted by g-rocc View Post
Did a few sketches of some ideas and would like to hear some input from you guys. Things to note is that I need to have a back seat so my boy can go out with us and this is only the top of the cage design that I am trying to decide on. Safety is the number one reason for building the cage. I'm not as concerned about the aesthetics of it but I don't want some heap of a cage either.
This is the first concept I had before Mike went off and started making sense and being practical.
With the ^ in the dash:
This one is based a lot off of yours Mike because it looks great.
^ in the dash but much simpler design:
Feel free to be brutal and give me your comments.
What do you have in mind for side flop/roll? triagulate both C and B pillars if possible. Of course I see your /\ for the A
WSS is offline
post #963 of 1110 Old 09-27-2013, 08:51 AM
g-rocc
For the B pillar I am going to have a shoulder harness spreader and triangulate the bottom half of that. For the C I was planning on just adding tube gussets from the rear spreader to the top of the C pillar as I want to keep that area open.
g-rocc is offline
post #964 of 1110 Old 09-30-2013, 09:37 AM
'92 vegas YJ
Finally got my cage all finished up and just got back from a weekend of wheeling.
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #965 of 1110 Old 09-30-2013, 09:56 AM
kellerumps
kellerumps's Avatar
Got a really dumb question....How big of hole did you have to cut in your dash to fit the a-pillar floor plate thru it?
I don't look for problems....They find me.
Member of:
kellerumps is offline
post #966 of 1110 Old 09-30-2013, 10:33 AM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
That one doesn't go through the dash
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #967 of 1110 Old 09-30-2013, 10:53 AM
kellerumps
kellerumps's Avatar
Told you it was a stupid question.
Member of:
post #968 of 1110 Old 09-30-2013, 01:10 PM
WSS
WSS's Avatar
1972 CJ5
Right here on post #6 are some cage tie in feet:
http://www.jeepforum.com/forum/f37/c...sible-1521971/
One is larger than the other so it will not have a scissor/can opener effect and tear the tub floor in a high pressure situation. using these, you will only need four 7/16" holes though the tub per leg. I put the smaller on top, don't think it matters though, I just had more room under the tub.
WSS
WSS is offline
post #969 of 1110 Old 09-30-2013, 09:55 PM
8pitcher
8pitcher's Avatar
WSS
I know you did the different size pieces. You sent done spares
8pitcher is offline
post #970 of 1110 Old 10-01-2013, 12:01 AM
WSS
WSS's Avatar
1972 CJ5
I forgot about that, yours may have the 3/8" holes. Might need to run a die grinder through them when you do your final fit up, or is it already done? Did those bumper shackle mounts work? I cut them 1/2" longer now just to get away from them being too close, you never know what size the clevis neck is going to be.
WSS is offline
post #971 of 1110 Old 10-01-2013, 06:48 AM
8pitcher
8pitcher's Avatar
I haven't used the cage mounts yet will on the rock crawler. And the shackle mounts are on the jk and work amazing.
8pitcher is offline
post #972 of 1110 Old 10-03-2013, 02:45 PM
jasonswelding
Still have to pull it and weld it out.
jasonswelding is offline
post #973 of 1110 Old 10-17-2013, 06:36 PM
jeepinhokie
I like that design for an add on cage. I might steal the design, or portions of it.
HOKIES UNITED!
jeepinhokie is offline
post #974 of 1110 Old 10-30-2013, 03:27 PM
jasonswelding
With light, speakers, cb mount, and hard top back on.
post #975 of 1110 Old 11-04-2013, 08:52 AM
JayTJ
Do you have any cad files or something that I can use to recreate this?
JayTJ is offline
Official BFG KM2 thread Magus2727 Tires & Wheels 8 12-07-2008 06:44 PM
The official HID thread lib Audio, CB & Ham Radios, GPS, & Electrical 88 10-16-2005 09:00 PM
The official 4x4 video thread mnjeep General Jeep & Off-Road Equipment 37 01-04-2005 12:03 AM
OFFICIAL ** Steering Fabrication Thread ** FunkSkunk Fabrication Shop 21 04-21-2004 06:41 PM
