*Official* Cage idea/pic/discussion thread - Page 64 - JeepForum.com
 1Likes
post #946 of 1110 Old 08-12-2013, 09:43 PM
WSS
WSS's Avatar
1972 CJ5
Originally Posted by KMD View Post
This is what it should look like when it is all done.
Here is mine for our CJ5, kinda like yours:
WSS is offline
post #947 of 1110 Old 08-13-2013, 10:03 AM
Coop02x
I really want to start on my cage build, but my lack of metal working experience has me leaning towards the Poison Spyder trail cage kit. Are there any other kits out there already cut and notched? I assume I will go with a "ready to weld in" kit.
Take a look at the KOZ Off Road cages. You can get their full cage kit for just $250 more than the Poison Spyder trail cage kit (a lot bigger bang for your buck). Or if you want to compare apple to apples, the KOZ trail cage kit is still a little cheaper than the PSC kit.
Also, there is the GenRight full kit or fastback kit and AtoZ front sport cage kit (AtoZ has a rear addition listed for 92-06 wranglers only. You might could check with them to see about options for your year model). The GenRight stuff just isn't as easy on the wallet.
I went with the PSC trail cage kit and heavy duty header bar kit for my TJ and if I were able to go back and do it over again, I would probably go with the KOZ kit (for more than one reason). The reason I didn't go with it in the first place was because I wasn't too keen on cutting the dash for the A pillar to go through. You live and you learn, right?
KOZ, GenRight, and AtoZ probably aren't your only options but they were a few that came to mind from when I was looking at cage kits. Whatever you do, if the YJs are like TJs, make sure you replace the header bars with something stronger!
Hope this helps!
Coop
Coop02x is offline
post #948 of 1110 Old 08-13-2013, 10:26 PM
MO2500
Here is a cage I recently finished. I sold the last cage I built (also in this thread) and started on this one to better fit my needs. I'm working on building a modified class jeep to race RcRocs/Ultra4/ect so I wanted to make a few revisions from my previous design and add some features that should make this cage stronger, safer and more roomier inside than my last one. This is the third cage I've done and it's amazing how much quicker it came together. My first cage took nearly 3 months to complete as it was my first time bending tube and building a cage, this one would have taken under 2 weeks if I didn't have to wait on seats/harnesses.
Instagram: @omsmike
MO2500 is offline
post #949 of 1110 Old 08-14-2013, 07:08 AM
Carlos14
Hope this helps!
Thanks for the help! I recently came across the KOZ kit and I have to say I like it. I guess it's time to start saving!
Luck Favours The Prepared
Carlos14 is offline
post #950 of 1110 Old 08-18-2013, 02:48 PM
Lifted96ZJ
1973 CJ5
Here's the start to the back half of my cage
Not really meant for rear passengers other than my kid. I'd like to add some gussets and a bar across the back where it mounts to the tub for stabilization
Build Thread
http://www.jeepforum.com/forum/f8/1973-cj5-trail-rig-hunting-rig-build-1403107/
Lifted96ZJ is offline
post #951 of 1110 Old 09-24-2013, 11:00 AM
g-rocc
Hey Mike, I don't know if you remember me or not from your trip out to CO but I had that white LJ on Patriot with you. Here is my question to you: was there any specific reason for flipping the 'V' in the dash on this cage from your last?
g-rocc is offline
post #952 of 1110 Old 09-24-2013, 11:51 AM
MO2500
Yes, I didn't forget you guys! I had a blast that day
The main reason for flipping the "V" in the windshield bars was for strength. When building a cage you want to try and avoid dead tubes (tubes that tie into the middle of a tube without anything behind it for support) as best you can and tie into nodes where multiple tubes come together. Reasoning is that the force during a roll will spread through more of the roll cage rather than loading into an unsupported structure.
Now, you can't completely eliminate the dead tubes in the windshield bars easily but you can see that with the tubes orientated like this "^", the center overhead support meets the two windshield bars and then they spread the force down and outwards towards the a-pillars. If they were flipped around like a "V" it would put all the force into the unsupported center of the dash bar. It also doesn't allow you to run a center overhead bar if you want them to tie into the windshield bars.
My first cage was built to retain the rear view mirror on the windshield so that is really the only reason I did it the other way. This cage was built entirely with strength and safety in mind, since I did away with the windshield, I went with what I believe is the strongest orientation of the windshield spreaders from my research of most Ultra4 and offroad racing cages.
However, both a "v" or a "^" is stronger than a single straight windshield spreader because it adds triangulation to the windshield area which will help prevent deformation if the cage takes a hit on the side.
Instagram: @omsmike
MO2500 is offline
post #953 of 1110 Old 09-24-2013, 12:52 PM
WSS
WSS's Avatar
1972 CJ5
Well said! Thanks for the detailed explanation.
WSS is offline
post #954 of 1110 Old 09-24-2013, 05:05 PM
jasonswelding
My start. This is to be more of a sport cage than a roll cage, if that makes sense.
jasonswelding is offline
post #955 of 1110 Old 09-24-2013, 09:42 PM
g-rocc
Thanks Mike. That all makes sense and was kind of what I was expecting to hear. The reason I was asking is because I wanted to carry the 'v' up into two front vertical spreaders so that there wasn't a dead end tube. I didn't really want to run a single front spreader in the center of the front section. I'm going to draw up a couple more concepts and see what I can put together.
g-rocc is offline
post #956 of 1110 Old 09-24-2013, 10:21 PM
8pitcher
8pitcher's Avatar
Does anyone have any pictures anywhere of how the cage ties into the frame? All I've ever seen has been to the tub but never from the tub to the frame. Thanks guys.
8pitcher is offline
post #957 of 1110 Old 09-25-2013, 05:55 PM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
Just a simple add-on cage. Using 1.75 dom and the genright dash stanchions (bottom half is not back in yet.)
These handles are made from old stock Jeep tierods. They seem to work nicely.
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #958 of 1110 Old 09-25-2013, 06:30 PM
MO2500
Here is how mine are tied in.
A-pillar
C-pillar
C-pillar changed a little with frame modifications but basically the same. I ditched the bushings and hard mounted my cage since it's a trail/race rig now.
Instagram: @omsmike
MO2500 is offline
post #959 of 1110 Old 09-25-2013, 06:32 PM
8pitcher
8pitcher's Avatar
A-pillar
C-pillar
Thank you
8pitcher is offline
post #960 of 1110 Old 09-26-2013, 08:43 AM
g-rocc
Did a few sketches of some ideas and would like to hear some input from you guys. Things to note is that I need to have a back seat so my boy can go out with us and this is only the top of the cage design that I am trying to decide on. Safety is the number one reason for building the cage. I'm not as concerned about the aesthetics of it but I don't want some heap of a cage either.
This is the first concept I had before Mike went off and started making sense and being practical.
With the ^ in the dash:
This one is based a lot off of yours Mike because it looks great.
^ in the dash but much simpler design:
Feel free to be brutal and give me your comments.
g-rocc is offline
Official BFG KM2 thread Magus2727 Tires & Wheels 8 12-07-2008 06:44 PM
The official HID thread lib Audio, CB & Ham Radios, GPS, & Electrical 88 10-16-2005 09:00 PM
The official 4x4 video thread mnjeep General Jeep & Off-Road Equipment 37 01-04-2005 12:03 AM
OFFICIAL ** Steering Fabrication Thread ** FunkSkunk Fabrication Shop 21 04-21-2004 06:41 PM
