*Official* Cage idea/pic/discussion thread - Page 61 - JeepForum.com
 1Likes
post #901 of 1110 Old 02-01-2013, 01:36 AM
WSS
WSS's Avatar
1972 CJ5
MO2500, that is a really nice cage. What did you paint it with? I just painted mine yesterday with a quart of rustoleum semi gloss black. Went on good, no runs (good for a beginner like me) but I am wondering how it will harden up.
Again, nice cage!
WSS
WSS is offline
post #902 of 1110 Old 02-01-2013, 02:07 AM
82JeepCJ7
1982 CJ7
I plan on getting mine sand blasted and powder coated, but I have used the epoxy enamel appliance paint on cages before. It hardens to a nice shell that resists scratches etc.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #903 of 1110 Old 02-01-2013, 02:11 AM
MO2500
Again, nice cage!
WSS
Thanks!
I painted it with maybe 6-8 rattle cans of Krylon Satin Black after priming. I've found Krylon has a smoother look than Rustoleum's satin with less splotchyness. I use the Krylon satin black on just about everything so I should probably start buying in bulk!
Instagram: @omsmike
MO2500 is offline
post #904 of 1110 Old 02-01-2013, 08:55 AM
8pitcher
8pitcher's Avatar
When I do mine I will get it powdercoated since I got a sweet deal worked out with my powdercoater and he gives me ridiculous deals on my cj stuff.
sent from the bottom of an empty money pit
8pitcher is offline
post #905 of 1110 Old 02-01-2013, 08:03 PM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
Update on the scrambler cage. Almost done but ran out of tube.
Still need to finish the X behind the front seats, build the back seat harness bar and supports, the gussets and grab handles, the upside down "V" in the windshield, and some small pieces to support the genright tire carrier .
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #906 of 1110 Old 02-01-2013, 09:29 PM
WSS
WSS's Avatar
1972 CJ5
Originally Posted by MO2500 View Post
Thanks!
That is a nice looking rattle can job. It looks sprayed. I did spray mine and found that splotchiness your talking about, apparently 800 grit wet sanding will fix it. I am going to cover a large part of it with padding and what won't be covered will be fairly low so I won't do the sanding.
I got a quote to do all parts with powdercoat for $200 which seemed like a good deal but I painted everything for under $40 and spent the rest on this:
http://www.ebay.com/itm/170838165012...84.m1497.l2649
Being new to Jeep project financing has made me look at numbers closer
WSS
WSS is offline
post #907 of 1110 Old 02-01-2013, 09:34 PM
WSS
WSS's Avatar
1972 CJ5
How did I miss that? Very nice Halo job. Look forward to some progress/finished pics!
WSS
WSS is offline
post #908 of 1110 Old 02-01-2013, 10:05 PM
8pitcher
8pitcher's Avatar
WSS
I think you could get a cheaper price for powder coat.
8pitcher is offline
post #909 of 1110 Old 02-01-2013, 11:43 PM
WSS
WSS's Avatar
1972 CJ5
What would you think a good price woud be? the guy I showed the parts to had a $100 minimum and I had 15 pieces total, many small and easy but that cage had lots of angles to cover. I welded a 1/2-13 nut in the center to lift it with the forklift, that was slightly easier. Still took a lot of spray time.
WSS
WSS is offline
post #910 of 1110 Old 02-01-2013, 11:46 PM
8pitcher
8pitcher's Avatar
WSS
Well my powder coater did my frame and axles sandblasting and powder coating with a color change for $200
8pitcher is offline
post #911 of 1110 Old 02-02-2013, 10:21 AM
WSS
WSS's Avatar
1972 CJ5
Ours wanted an extra $100 for sandblasting, you definitely are getting a good deal. I better shop around some more. I will be doing the front fenders into tubes and want to match the color as close as possible, that might be a real expense.
WSS is offline
post #912 of 1110 Old 02-02-2013, 03:46 PM
8pitcher
8pitcher's Avatar
They also gave me such a good deal because I'm 17 and I did all the negotiating myself and they like that I was building my cj myself too.
8pitcher is offline
post #913 of 1110 Old 02-10-2013, 10:02 PM
OilfieldCowboy
Can anyone give me a ballpark footage for a full cage in an 87? I have the chance to get one hell of a deal on 1.75 tubing with any wall thickness I want. Looking at 1.75 od x 1.375 id. He said they mostly order CM instead of mild steel, but might be able to get mild in...
2006 Rubicon Unlimited
OilfieldCowboy is offline
post #914 of 1110 Old 02-10-2013, 10:11 PM
WSS
WSS's Avatar
1972 CJ5
My CJ5 took 2pcs 2" x .120 and 6pcs 1.5" x .120. I did make rear fenders and sliders too out of the 1.5". It looks like you are leaning toward the mild over the CM, you probably know it needs "special" attention when welding. LOL. .188 might be a little heavy.
WSS
WSS is offline
post #915 of 1110 Old 02-20-2013, 09:50 PM
cjjon7
1983 CJ7
Originally Posted by semperfi1919 View Post
SWEET, Man that is just what I want in my CJ, That cage is AWESOME...
+1 Unfortunately it may be a few years before I find the time for something this nice.
cjjon7 is offline
Official BFG KM2 thread Magus2727 Tires & Wheels 8 12-07-2008 07:44 PM
The official HID thread lib Audio, CB & Ham Radios, GPS, & Electrical 88 10-16-2005 10:00 PM
The official 4x4 video thread mnjeep General Jeep & Off-Road Equipment 37 01-04-2005 01:03 AM
OFFICIAL ** Steering Fabrication Thread ** FunkSkunk Fabrication Shop 21 04-21-2004 07:41 PM
