*Official* Cage idea/pic/discussion thread - Page 55 - JeepForum.com
 1Likes
post #811 of 1110 Old 08-05-2012, 08:36 AM
Ben
Zach here's the A pillar foot I ended up with.
I got 2 through the channel, and 2 just to the inside of it.
Got the tubes all cleaned up and tacked together, but broke my T50 so I can't pull the family bar for the rest of the finish welding & painting.
Another day I guess...
Ben is offline
post #812 of 1110 Old 08-09-2012, 09:55 PM
8pitcher
8pitcher's Avatar
can i see a pic of how you tied that into the frame?
i will be needing all the help i can get when i build my CJ cage.
8pitcher is offline
post #813 of 1110 Old 08-11-2012, 07:45 AM
Ben
I did not do anything below the jeep yet. I want to focus on the cage for now, I'll come back later and add frame - A pillar and fram - B pillar mounts, and likely eliminate some body mounts in the process.
Now this is all 1-3/4" DOM so far, but would 3/4" pipe triangles help at all? or just add weight? Like 2 pieces coming from the center of the B pillar spreader to the top of the C pillar
Ben is offline
post #814 of 1110 Old 08-11-2012, 07:52 AM
8pitcher
8pitcher's Avatar
IMO more triangulation adds more strength.
And when you have some frame tie ins post pics please.
8pitcher is offline
post #815 of 1110 Old 08-11-2012, 03:34 PM
soonermatt
I think you're asking about two bars above the rear passenger's head. I suggest it and will be doing the same. Another idea is to add an LED third brake light up there. I'm pleased with mine. (It's described in my build thread.)
soonermatt is offline
post #816 of 1110 Old 08-12-2012, 06:38 AM
Ben
Damn 3rd brake light would have been cool, but I missed out on a hole where I added the spreader.
Made little grab bars up front, then decided against anything else.
Done. For now. There's a lot more I could add to it to really make it a cage, but for what it is, it's gotta be stronger than stock.
All thats left is just gotta wrestle it back in there.
Ben is offline
post #817 of 1110 Old 08-12-2012, 09:54 AM
82JeepCJ7
1982 CJ7
Some diagonal bracing on the main hoop would add some much needed triangulation. With out the bracing, a sideways flop will bend the cage off to the side. In a full roll, the cage will collapse right down on top of the seats.
Is that a TJ main cage? I'm not too fond of the crimped sections and holes.....
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #818 of 1110 Old 08-12-2012, 07:38 PM
Ben
Yep.
Ben is offline
post #819 of 1110 Old 08-21-2012, 05:13 PM
82JeepCJ7
1982 CJ7
Although not a Jeep, a cage would of meant little to no injuries. I've been through this trail many times and there are places you can roll a long ways.
http://www.yakimacounty.us/sheriff/P.../08_20_12.html
post #820 of 1110 Old 09-21-2012, 09:59 AM
RogueFab
Yeah a proper cage and harnesses would go a long way there. And remember- if you don't put handles on your cage, your passengers will use the cage as a handle, and in a roll they will break most of the bones in their hands/fingers. Handles are required if the top can come off
Rogue Fabrication - Portland OR -
Air/Hydraulic tube benders- $595 w/180 degree die sets
Universal Drill Press Reduction Kits- $119 shipped
RogueFab is offline
post #821 of 1110 Old 09-21-2012, 11:24 AM
Renegade82
1982 CJ7
Agreed. And handles of a smaller diameter tube, set to the inside so it gives you that extra space, should it roll while holding that handle. I will have 2 center bars above the front passengers and I plan on putting smaller angled tubes there to serve as both gussets and handles.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #822 of 1110 Old 09-21-2012, 03:24 PM
82JeepCJ7
1982 CJ7
I instruct my passengers to cross their arms across their chest and grab the opposing shoulder strap (I have 4pt belts in every seat). That helps keep their arms inside the vehicle and also helps keep their body in the seat. I have saw a lot of bruised/broken elbows from arms flailing around, never leaving the cage but hitting stuff inside the Jeep (driver hitting passenger included).
post #823 of 1110 Old 09-23-2012, 01:42 PM
papa355
1977 CJ7
was wondering if some guys could post some pics of the harness bars. I need to install a lower and upper harness bar. would like to see some pics please.
1977 CJ7, 360 AMC with HEI, TH400 quadratrac, dana30, AMC20, SOA, 35" M/T MTZ
papa355 is offline
post #824 of 1110 Old 10-12-2012, 10:19 AM
bigt2317
Mall Crawler
bigt2317's Avatar
Originally Posted by gabriel05 View Post
Wow, long thread. I've been thinking about getting a cage lately. After reading this and a few other threads I'm probably going to go with the AtoZ Fabrications kit that adds onto the factory cage. After reading about the benefits of having diagonals in the main hoop (B-pillar), I want to add something like that while still retaining the ability to use the rear seat. I usually have passengers when during trips.
I stole this picture from an earlier post in this thread, the green is what I plan on adding.
I know that it isn't the best design as far as strength is concerned but it still give room for people to get to the back seat, and has to be stronger than not having anything there. The vertical sections will attach to a piece of C-channel that will be placed over the tunnel just behind the console. Any suggestions or alternative ideas are welcome.
Edit: Not that it helps the cage, but it would make a handy spot to mount some cup holders for the rear passengers too.
I'm interested in this as well. I have a 2 year old son that has a car seat in the back that we use frequently. The jeep is a 3rd vehicle and not a DD but I do want it a "friendly" as I it can be with getting in and out of the back while still being safe.
I know it will not be the best cage or even close to buggy worthy. I'm not a pedal to the metal wheeler and will pull a line if I get in a bad situation, that said, I also understand a roll over will happen before you know it and can be bad which is why I need to find a compromise between "best cage possible" and "good DD usability".
Also, I plan on adding small gussets there and there to aid with strength as well as tie down points. I was thinking of putting a couple where the 2 parallel bars running from the windshield to the b pillar hoop in the center. Right in that corner parallel to the ground, so basically right above the center console.
2005 LJ Black Rubicon - Boring mallcrawler
2005 LJ Khaki Rubicon - slightly modified - TOTALED
FOR SALE
PM me for great deals on enclosed or open trailers
bigt2317 is offline
post #825 of 1110 Old 10-13-2012, 09:04 PM
jason m
Nothing but the facts
jason m's Avatar
I made some parts to make tube splicing easyer. Insteed of just using 1 1/4" .120 wall for inserts, I took some random 1.5" 1/4 wall and truned them down to fit the ID of the 1.5" .120 wall tube.
But I left a .40thou ridge about .80 thou wide, should give a perfect bevel for the the two tubes to be spliced.
Made a hanful of these,
I left them as a ruff cut as they will be burried under tube and weld.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
Official BFG KM2 thread Magus2727 Tires & Wheels 8 12-07-2008 07:44 PM
The official HID thread lib Audio, CB & Ham Radios, GPS, & Electrical 88 10-16-2005 10:00 PM
The official 4x4 video thread mnjeep General Jeep & Off-Road Equipment 37 01-04-2005 01:03 AM
OFFICIAL ** Steering Fabrication Thread ** FunkSkunk Fabrication Shop 21 04-21-2004 07:41 PM
