*Official* Cage idea/pic/discussion thread - Page 54 - JeepForum.com
 2Likes
post #796 of 1110 Old 06-07-2012, 12:50 PM
Molonlabemike
Originally Posted by zachv
Mike, that is fine. It could have been down 2-3" and still been fine, but you are on the right track--you want the shoulder harnesses to pull you back, not pull you down and compress your spine. The lap belts are supposed to hold you down.
BTW, I do not know who the harness straps in the seats are for--we have never used them either.
P.S. Now that you mentioned a 5'2" female we all need to see pictures of said young lady.
Thanks Zach, I did lots of reading and just wanted to double check my work. The harness slot would be nice so I don't have to fab up stops but man their really low.
Thanks again Zach!
Molon Labe
Molonlabemike is offline
post #797 of 1110 Old 06-07-2012, 12:57 PM
zachv
If you make the harness straps tight to the tube, like they should be, then beefy zip ties work well as locators so the harnesses don't move side-to-side.
Have a great day!!!
Zach Vaughn.
570-385-3931--shop
zachv is offline
post #798 of 1110 Old 06-07-2012, 01:05 PM
PDK
I bought those same seats when doing my cage and came to the same conclusion as you...they just aren't a good seat! They are entirely too short and your head could end up hitting tubing behind you since you essentially have no headrest. They only have the single slot...not designed to work with most everyone's double strap with the 5 point harness.
By and large, i bought them because they were the cheapest. After building up the cage and trying to make those fit/work...I finally just gave up. Sold 'em on Craigslist for not much less than I paid for them. I then saved up a bit and bought some PRP seats. I even had an extra 2" height added on my side (I'm over 6' 4"). Decided on colors I wanted and everything. So, my suggestion is to do the same/similar because you are not going to be as safe/comfortable in thos short Corb's. My .01 cent
PDK is offline
post #799 of 1110 Old 06-07-2012, 01:10 PM
Molonlabemike
Good idea thanks, I was planning on cutting some 1 3/4 and welding it lol.
Molon Labe
post #800 of 1110 Old 06-07-2012, 01:12 PM
Molonlabemike
Thanks for the input, my head hits the top of the head rest so they should be ok. I would go master craft or PRP if I had to do it over as Corbeau quality control seams to be lead by Stevie Wonder lol
Molon Labe
post #801 of 1110 Old 06-21-2012, 07:39 AM
rozzo842
XJ cage pics
rozzo842 is offline
post #802 of 1110 Old 06-21-2012, 07:59 AM
zachv
Looks very well thought out and the nodes all look to hit well--nice work. How did you weld the underneath of joints on the top? Lift it up, weld, paint, and then lower it back down to burn it to the main mounts?
Have a great day!!!
Zach Vaughn.
570-385-3931--shop
zachv is offline
post #803 of 1110 Old 06-21-2012, 10:02 AM
Renegade82
1982 CJ7
Nice job. Might be a bugger to get the rear hatch closed though!
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #804 of 1110 Old 06-21-2012, 12:04 PM
82JeepCJ7
1982 CJ7
What rear hatch....
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #805 of 1110 Old 06-21-2012, 12:22 PM
rozzo842
Yeah,pretty much Zach. The whole thing was removed exept for the B pillar. welded, painted then dropped back on. tacked the B together then lifted each side as much as I could to get better access.
rozzo842 is offline
post #806 of 1110 Old 06-21-2012, 12:26 PM
rozzo842
Out for finish welds
rozzo842 is offline
post #807 of 1110 Old 07-20-2012, 08:16 AM
Ben
I picked up my S&W front half conversion wednesday, getting started here.
I read this whole thread, this was the only bit I found about mounting the A pillar landing pad:
Originally Posted by UTmike View Post
This is my AtoZ cage at the floor. I was able to tie the outter two bolts into my Shrockworks rocksliders and the medial two into the double layered floor.
Attachment 94430
Attachment 94431
I don't really like that, is that how everyone has landed that A pillar?
It leaves almost an inch of dead space between the sandwich plates.
What I'd like to do is cut the inside floor pan of the tub.
Probably cut the tub (on the red rectangle) in a H like shape, so I can fold it down and tack it together to keep it nice and firm there.
That puts the cage down to the lower piece of the tub channel there.
here's a kick *** drawing I did.
Then my lower sandwich plate will just be incorporated into new rock sliders
Any comments on this?
If you landed an A pillar in a TJ and have any other ideas or pics I'm open to thoughts on this one.
Thanks,
Ben
Ben is offline
post #808 of 1110 Old 07-23-2012, 07:41 AM
zachv
FWIW, we have been doing it our way for almost ten years and dozens of cages without one failure and many rollovers.
Have a great day!!!
Zach Vaughn.
570-385-3931--shop
zachv is offline
post #809 of 1110 Old 07-23-2012, 08:13 AM
Ben
Thanks Zach. Nice of you to chime in even though I didn't buy your product.
Do you use a sandwich plate on the bottom?
I tried looking for pics of the AtoZ installs, cause I know you've cranked out a lot of them, and have a lot of satisfied customers.
Best I can see is 2 of your 4 bolts go through that channel, the other 2 are off to the side through the single-ply floor. Maybe just a plate on the single ply side?
Ben is offline
post #810 of 1110 Old 08-02-2012, 12:51 PM
stealthjk
Those are all awesome cages.
stealthjk is offline
Official BFG KM2 thread Magus2727 Tires & Wheels 8 12-07-2008 06:44 PM
The official HID thread lib Audio, CB & Ham Radios, GPS, & Electrical 88 10-16-2005 09:00 PM
The official 4x4 video thread mnjeep General Jeep & Off-Road Equipment 37 01-04-2005 12:03 AM
OFFICIAL ** Steering Fabrication Thread ** FunkSkunk Fabrication Shop 21 04-21-2004 06:41 PM
