*Official* Cage idea/pic/discussion thread - Page 48 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > *Official* Cage idea/pic/discussion thread
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 08-19-2011, 12:19 PM   #706
jkoz79
1964 CJ5
Originally Posted by DualPurposeXJ
No problem I got 15 degrees on my angle finder
Thank you very much
jkoz79 is offline   Reply With Quote
Unread 08-20-2011, 03:07 PM   #707
Jim1611
Jim1611's Avatar
I had thought that I might do more than just what you see here for the A pillar tie-in but after getting these fitted up I think this is enough. Very simple, almost too much so but simple is usually better. The plate that is bolted to the bottom of the tub is bigger than needed so after I get things tacked where they belong I'll do a little trimming on it.
Jim1611 is offline   Reply With Quote
Unread 08-21-2011, 08:58 PM   #708
MO2500
Fabramicator
MO2500's Avatar
Any reason your not welding directly to the frame instead of the plate body mount? Like rotating 90* and tieing right to the frame.
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Unread 08-21-2011, 09:18 PM   #709
silverjeep
I just looked at every page on this thread again. After much deliberation, I'm going with Zacks A to Z Fab addon kit. It looks very well thought out, it's priced right and is aesthetically pleasing. I will be adding more DOM in some of the recommended areas and possibly some guessets. Wheeling is a family event in our house hold. I wheel with a 9 and 4 year old in the back, I know this will keep them safe. Just in case.
I'll post pics once it's done.
I will be ordering his week, How do I get the JF discount????
CHECK OUT MY LJ BUILD THREAD
silverjeep is offline   Reply With Quote
Unread 08-22-2011, 08:40 AM   #710
Jim1611
Jim1611's Avatar
No not really. I had it turned that way earlier and this seemed better to me. What's your thoughts?
Unread 08-22-2011, 05:18 PM   #711
MO2500
Fabramicator
MO2500's Avatar
I was just curious if you had a reason to do it that way. I probably would weld it directly to the frame (I did with my own) but I don't know if one way is better than the other. It just seems straight to the frame would be the simplest way to go and it's how most do it. Everyone seems to have there own method of tieing the cage in and it's sort of difficult to really "test" the strength of different designs short of rolling the jeep down a hill. Most try to avoid that situation
Your cage is coming along great though. Keep up the good work
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 08-22-2011, 06:08 PM   #712
Jim1611
Jim1611's Avatar
Thanks Mike. I did go back today and hold it up to the frame. I'd have to make the 2" square pcs. over becuase the way they are isn't long enough. Guess I'll leave them as they are. You're right there's many ways to do the tie-ins and I hope to not test mine!! We never know though do we.
Unread 08-23-2011, 07:54 PM   #713
jkoz79
1964 CJ5
Getting there. A few cuts to shorten the b pillar and it fit better than I ever imagined.
Unread 09-03-2011, 07:34 PM   #714
jkoz79
1964 CJ5
DONE!!!!! Tied into the frame and everything. A YJ family cage into a 64 CJ5
Unread 09-12-2011, 02:07 PM   #715
rtbtitans50
A few things....
I can see a lot of people replace their entire stock cage, and people add on. I was planning on replacing my entire cage w/ 1.75 .120 wall DOM, except I was going to keep my stock b pillar. I would think this would make it easier to help keep some of the stock locations of the soft top, door surrounds etc. I will be adding lots
Any input on this?
Also I have seen the dash tie ins, going through the dash to the floor, and a combo of both. Recommendations? I am leaning towards the combo of dash tie in then connect through the floor to the frame. Seems like less time due to not having to take the dash off and snake some tubing through there. Input?
[URL="http://youtu.be/aZ5Oz60S-b0"]My 3 Year old son throwing a tomahawk[/URL]
[URL="http://www.youtube.com/watch?v=Z9udaVbLOHQ"]My 3 year old son shooting a bow[/URL]
[URL="http://www.jeepforum.com/forum/f22/college-w-kids-aka-very-low-budget-tj-build-1231456/"]My Jeep Build Thread[/URL]
[URL="http://www.jeepforum.com/forum/f37/my-first-fab-project-tj-front-bumper-1231585/#post11760786"]My First Fab Project... TJ Front Bumper[/URL]
[URL="http://www.jeepforum.com/forum/f9/my-cold-air-intake-writeup-1306786/#post12754414"]My Cold air intake 'build'[/URL]
[B][SIZE="5"]HILLTOP O.R.V.[/SIZE][/B]
rtbtitans50 is offline   Reply With Quote
Unread 09-12-2011, 02:23 PM   #716
zachv
Vendor
Originally Posted by rtbtitans50 View Post
A few things....
Any input on this?
Cage add-ons are great for general trail rigs. Full cages are best for hardcore trail rigs and comp rigs. Keeping the stock B-pillar does make a cage addition easier and if you are going to re-use the stock soft top you are going to have tubes there anyway.
IMO, running tube through the dash is the best/only true option. I do not trust bent plate steel that bolts to the cowl, whether it goes to the floor or not. You just do not know which way that bent plate will be loaded in a roll or flop and bolting to the cowl area is just weak and does not add much strength. BTW, you do not need to remove the dash to put tube through the dash and down to the floor. E-mail me for a copy of our install instructions and you will see how we do it.
AtoZ Fab Cage Additions
Have a great day!!!
Zach Vaughn.
AtoZ Fabrication, Inc.
570-385-3931--shop
570-385-3932--fax
MADE IN AMERICA---and proud of it!!!
Now scheduling cage/custom work so call now to get on the calendar.
CHECK OUT OUR DIY FAB PARTS FOR SALE!!
We also offer the best prices available on:
Advance Adapters
Clayton Offroad Suspension
RCV ultimate axle shafts
Corbeau Seats
Raceline Wheels
zachv is offline   Reply With Quote
Unread 09-12-2011, 02:54 PM   #717
Mud Machine
Jeep Addict
Mud Machine's Avatar
Here's one in my CJ
GR8 Half Top Conversion Thread
Does your gas tank overflow at the pump?
SUBMIT FORMAL COMPLAINT HERE!
2005 Rubicon LJ Unlimited - 4 1/2" BDS Suspension - 285/75/16 Toyo M/T's - 12,000# Winch - Ground Pounder Fab Rear Bumper - FabRieckAtions Custom Front Bumper - Overkill Engineering Tube Fenders - GR8 Half Top - Rock Hard Cage - Banks Monster Exhaust - 5.13 Gears - High Performance Flux Capacitor
1976 CJ-7 - 33" Super Swampers - BDS 4" Suspension - 6 Point Roll Cage
Mud Machine is offline   Reply With Quote
Unread 09-19-2011, 05:32 PM   #718
razorback84
razorback84's Avatar
How do you guys feel about the pre-fab cages such as the Genright cage?
06 TJ Sport
12 Chevrolet 2500 LTZ Duramax
69 Chevrolet Chevelle
79 Harley Lowrider
12 Caravelle Interceptor 232 Ski Boat
Build Thread
Razorback Rebuild
razorback84 is offline   Reply With Quote
Unread 10-01-2011, 02:04 PM   #719
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Avatar
Good simple proven design if you want DIY. But it may not suit your style or needs exactly. You would be surprised what you could get by checking out your local fab shop! And it would be exactly what you need instead of another cookie cutter cage
Don't Click Me!
FunkSkunk is offline   Reply With Quote
Unread 10-01-2011, 03:22 PM   #720
razorback84
Thats the route I'm taking. Found a local club guy that does cages. Plus I want a cage that goes through the dash
06 TJ Sport
79 Harley Lowrider
Build Thread
Razorback Rebuild
