*Official* Cage idea/pic/discussion thread - Page 21 - JeepForum.com
 2Likes
post #301 of 1110 Old 01-16-2009, 09:05 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Marten, a 110v welder should be able to do a cage since most of it is 1/8" thick. I built the entire back half of the frame/cage on an old CJ5 with a Craftsman 110v welder and flux core about 10 years ago. However, the bottom line is gonna be your ability with the welder. Only you know for sure. At the very least, practice with a few joints.. welding at different angles. Maybe even take a sawzall and cut thru a few of those joints to see how your penetration is.
BESRK is offline
post #302 of 1110 Old 01-16-2009, 09:44 PM
1Rustycj5
1980 CJ5
BESRK, Thank you for your response I was pretty sure it had been done before but I figured I would at least make sure that Im not attempting anything that has been a complete disaster.
What type of flux-core wire did you use?
Also Im planning on doing some custom bumpers and sports cages for my friends and I found some cheep tools at HF and I was wondering if these are any good?
http://www.harborfreight.com/cpi/cta...emnumber=38024
http://www.harborfreight.com/cpi/cta...emnumber=42324
Also what is the best way to go about tying the cage into the frame?
Remember that I have a body that has basically no stock floor supports, All custom fab.
Thanks again,
Marten
1Rustycj5 is offline
post #303 of 1110 Old 01-17-2009, 07:01 AM
Fred99TJ
The best way would probably be to go throught the floor and weld to the frame. BUT What I did on my TJ and will again on my XJ is use a 4x4 plate and bolt to the floor. Then another 4x4 on the other side of the floor board (sandwitch the floorboard). Then weld a piece of tube to the bottom 4x4 plate that goes to the frame and then either weld the tube directly to the frame OR weld another 4x4 plate to that tube and bolt it to the frame.
For what its worth my entire cage was done with a Lincoln 100 and flux core wire
Built 92 XJ For Sale
Fred99TJ is offline
post #304 of 1110 Old 01-17-2009, 04:13 PM
bikeboy
1982 CJ8
cage advice
Hi Everyone,
I'm rebuilding a Scrambler for DD and weekend camping/wheeling; nothing crazy.
Here's my cage design. I'm using the large diameter tubing from CJ Roll Bars.
Do you see any weaknesses for my intended use?
Thanks.
Live Justly, Love Mercy,
Walk Humbly with God.
Micah 6:8
bikeboy is offline
post #305 of 1110 Old 01-17-2009, 08:05 PM
Fred99TJ
Looks like it would be pretty stout. You can run one more tube from the front drop down legs to the B Pillar (middle one) on the bottm by the floor
Fred99TJ is offline
post #306 of 1110 Old 01-17-2009, 08:34 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Thanks again,
Marten
Harbor Freight sells PIPE BENDERS. What you need is a TUBING BENDER. http://www.jd2.com/
Pipe is NOT the same as Tubing. Pipe is designed to have stuff like air, water or some liquid flowing inside it. Tubing is designed to provide structural support in some application. The actual type of steel used is different, and they are manufactured differently. Use the correct type for the correct application.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #307 of 1110 Old 01-17-2009, 08:48 PM
jason m
Nothing but the facts
jason m's Avatar
this is how i tied my buddy's YJ into the fame. he had a set of warn rocker panels that were made of 3/16. so i spray welded the top tube to the rocker, then bent a chunk of tube to go under it. of course its welded to the frame to, but i dont have a pic of that.
jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #308 of 1110 Old 01-17-2009, 10:29 PM
1Rustycj5
1980 CJ5
Ya i figured that out last night, This looks like the cheapest way to go for a "tubing bender"
http://www.tjdieselperformance.com/s...-bender/Detail
Mostly because it also comes with the die and a hydraulic jack for only 319.
that dosent seem like a bad deal at all....
Also, is renting a tubing bender an option?
post #309 of 1110 Old 01-17-2009, 10:37 PM
goldswim5
I'm going to pick up some steel this week to get the back half of my cage going, is 1.75 x .12 going to look funny welded to my stock cage?
2005 Wrangler Unlimited
6 speed, hard top, bone stock
goldswim5 is offline
post #310 of 1110 Old 01-17-2009, 10:42 PM
jason m
jason m's Avatar
i used 1.5 .120 wall. i think 1.75 will be plenty strong. you can see the factory cage end about half way down and i capped he ends, the 1.75should look fine.
jason.
jason m is offline
post #311 of 1110 Old 01-18-2009, 11:32 PM
1Rustycj5
1980 CJ5
^^^ Does this seem like a good bender? its reasonably inexpensive for building a cage.^^^
post #312 of 1110 Old 01-19-2009, 05:19 PM
goldswim5
Alright the metal supply here didn't have .12 wall but they had 1.75x.095 which I think will be fine. I'm going to use the bluetorch dash tie ins to build off of, may not be as strong as a tube going to the floor but I've been informed I can't cut up my dash. Other than that I am just buying tube and making everything myself. Not planning on making any bends but I know there are a few people here that could do it if need be. Hopefully it will be done within the month, I'll post pics when it is.
Also, I looked though the whole topic and didn't see any diagonals that would still allow a backseat, can this be done?
post #313 of 1110 Old 01-20-2009, 03:29 PM
Stan99
1978 CJ7
Thought I would post a few of mine. I am still doing a few thing to it and I will post those up when I am done. But this is the finished design. I pretty much just did a knock off of a poison spyder TJ cage.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
1978 Jeep Cj7 Soa, Shackle Reversle, 36x13.5x15 Irocks, 4.5 Stroker MPI, Dana 300 twin Sticked, 4.88's
Stan99 is offline
post #314 of 1110 Old 01-20-2009, 08:02 PM
Fred99TJ
Not bad Are there going to be legs dropping down in the front? What welder are you useing?
Fred99TJ is offline
post #315 of 1110 Old 01-20-2009, 08:59 PM
Unlimited04
nope. lots of cages made of that...including mine (post #274)
Useful Write-Ups:
Funny:
Official BFG KM2 thread Magus2727 Tires & Wheels 8 12-07-2008 06:44 PM
The official HID thread lib Audio, CB & Ham Radios, GPS, & Electrical 88 10-16-2005 09:00 PM
The official 4x4 video thread mnjeep General Jeep & Off-Road Equipment 37 01-04-2005 12:03 AM
OFFICIAL ** Steering Fabrication Thread ** FunkSkunk Fabrication Shop 21 04-21-2004 06:41 PM
