*Official* Cage idea/pic/discussion thread - Page 16 - JeepForum.com
 2Likes
post #226 of 1110 Old 11-29-2007, 08:29 AM
tommaho
tommaho's Avatar
I made plates like Zach posted (4 bolts instead of 6 though), and tied in like this:
Yes I'm still running the stock mounts with a BL. No solid bushings. With 8 points tied in I like to think of the stockers as harmonic dampeners.
Tom
tommaho is offline
post #227 of 1110 Old 11-29-2007, 08:52 AM
BozoWise
BozoWise's Avatar
Originally Posted by zachv
We used to use and make B-pillar mounts like that, but then one day we cut that "bump" off and realized that it was for the body mount and now we use this plate to tie into the frame right there:
It is a great way to get a frame tie-in with little effort.
Zach I am a bit confused as to mounting this plate? Does your plate go both under and inside the tub sandwiching the tub between the plates? That is what I was planning on doing with the bottom plates being larger then the plates inside the tub. Then weld a bushing on the bottom plates and run tube to the frame with a fishmouth Joint at the frame.
I did see that the bump there inside the tub is the body mount bolt is. So are you using that bolt to bolt the inside bracket down?
My biggest concern was how I was going to construct the lower tub bracket plate (hope that makes since) 2 of the bolts for the inside bracket are blind and well over half the bracket is above the main body support channel.
Tom
Do you have a picture where your frame tube meets the cage mount? I plate and tie in to the inner 2 bolts holes on my mounts without having to cut the tub or even make my plates longer towards the inside of the tub and get more then two bolts but I want to keep the lower parts of the B pillar originating from the same spot as the factory cage.
I plan on making the A pillar and C pillar tie ins with 1" solid pins that will be male and female joined at the plates. Very similar to Kerts at diy 4x4.
My 1 ton TJ build project "Evil Monkey":
BozoWise is offline
post #228 of 1110 Old 11-29-2007, 09:14 AM
tommaho
tommaho's Avatar
No, I dont, but it's a mirror image of the foot you see here.
Instead of trying to maintain the support channel that goes along the underside of the tub I just cut it out so there was nothing there to collapse between the upper and lower plates. So I have a more or less solid sandwich of plate - tub - plate.
There's probably a better way to do it, but at some point I decided that the integrity of the cage was more important than the integrity of the tub/subframe.
Hope that makes sense.
tommaho is offline
post #229 of 1110 Old 11-29-2007, 09:47 AM
zachv
All we do is open that "bump" up with a slicer wheel and pound it flat so I can get the bolt through the body mount and so that the plate sits flat. Then, one of the holes in the plate is aligned so I can get a ~5" Grade 8 bolt through and after I drill out the nutsert in the tub I slide the bolt up from the bottom all the way through the body mount and then the plate and voila', instant B-pillar frame tie-in. I didn't see any pics on my computer, but if I find one I will post it up.
BTW, I understand the desire to use those shear pads in the picture above, but honestly, I have seen tons of cages roll, some that we have built, and none of the welds have sheared at the plates. If a weldor is competent there should not be an issue, but I guess it is never a bad idea. I just have a hard time hitting the same dead spot on a plate every time on some rigs, especially TJs when going through the dash. Either way, I guess overkill is not a bad thing.
Have fun.
Have a great day!!!
Zach Vaughn.
570-385-3931--shop
zachv is offline
post #230 of 1110 Old 11-29-2007, 09:50 AM
tweba99
tweba99's Avatar
Have fun.
Good idea Zach. So, do you only use the 1 body bolts for a tie in or do you add other bolts around it?
1999 Jeep TJ on 1 tons (OLDER)
2003 Jeep Rubicon (OLD)
2008 Jeep Unlimited X (NEW)
tweba99 is offline
post #231 of 1110 Old 11-29-2007, 09:55 AM
zachv
Depending on the model, we typically use 2-3 more of the holes and just use good washers on the bottom. There is not as much "up" push on a cage during a roll so the tie-ins see most of their forces down in that axis.
Have a great day!!!
Zach Vaughn.
570-385-3931--shop
zachv is offline
post #232 of 1110 Old 11-29-2007, 09:45 PM
BozoWise
BozoWise's Avatar
That makes much better sense now that I know you cut the subframe support. For some reason I thought you tied in without cutting it.
I really like that idea and I just might redesign the mounts for the B pillar to flare out and have a hole located above that body mount. Not sure if I would rather do that or notch the subframe and run a bushing like the other points.
Love the ideas though and appreciate the help!
Have fun.
I am running the 1" pins just to prevent side shear on the bolts. The tube does not mate perfectly with the plates but the two mounting plates mate perfectly with the pins. Thus the two plates can not seperate from a side to side force since not only are the grade eight bolts preventing it the 1" pins are.
I prefer to tack the plate with the "hole" on the end of the tube foot and drill the mounting holes. Then I break the tack and just have the foot mounted in the proper location and use the center hole to mark and cut the floor. Then if the tube is so off center on your mounting plate that it will not allow the male pin to enter inside the tube then you reverse your plates and have the male pin going through the floor (no effect on where the top tube mounts on the plate) and use the female plate under the floor.
Hope that makes some sort of sense
Zach, How many bends do you use on the front A pillar bar from floor to upper windshield? Is that a single bend or dual bend off plane? Do you have pictures of where the bar mounts on the floorboard?
BozoWise is offline
post #233 of 1110 Old 12-18-2007, 04:35 PM
ace2001
ace2001's Avatar
I know no one has posted on this thread for a little bit but I have a question. Does anyone have more pics of the first cage posted on this thread? I am in the market for a new cage and I really like that one. That and I like the center bars/harness bar from the last Bronco on post #11.
ace2001 is offline
post #234 of 1110 Old 12-24-2007, 10:43 PM
ugahopeful34
I am going to put in a cage soon and right now I have the back half which is identical to the backhalf of a stock tj.. what additions should I make to it, and it is designed to bolt to the back of the jeep body, should I tie it in to the frame instead? also I'm looking at these plates, so you cut a hole/square in the floor and bolt it to the body and have the pipe welded to the frame??
ugahopeful34 is offline
post #235 of 1110 Old 12-25-2007, 07:09 AM
Fred99TJ
Are you asking what you should add to a stock rear half of a TJ cage? I put a plate on bottom and bolted through the body and mounted to the frame that way. As for other additions to the rear half look back at my cage (on the prior page I think) and add supports at "crush" points on the TJ cage. be super sure to add a spreader to the rear between the two down bars.
Fred99TJ is offline
post #236 of 1110 Old 12-25-2007, 07:13 AM
Fred99TJ
Heres my cage.....
Originally Posted by Fred99TJ
Hey guys I was surfing on here and just found this thread.
I didn't read 15 pages but I flipped through them. There are some GREAT designs on here for cages. I too just did my cage. My first attempt was given to me from a frien who competes. He rolled over backwards and it tweaked the cage enough I didn't want to use it but it is being used in a jeep now.
This is my current cage:
I know some folks don't agree with re-useing the stock center and rears but thats what I did on both my cages. They are fully welded (even the bolted sections of the stock cage are welded). The front and rear came from TrailWorks in Nashville, TN and The 3 braces in the rear and the bottom windshield spreader I added. There are also braces along the floor board that I added. I know alot of people insist on DOM for cages too. We used HREW on the second DOM on the first. I did alot of research and re-useing the stock center with DOM additions is not totally benificial. The stock Cage portions are HREW and therefor the weak link. By braceing it and makeing the rest from HREW it distributes a hit a little better. Right now just the front two legs are frame tied, but when I finish it will have 6 frame tie-un locations. I am also going to add a few gussetts and grab handles.
I know this isn't the greatest cage in existance but I definatly feel safer with it!!!!
Fred99TJ is offline
post #237 of 1110 Old 12-26-2007, 12:09 AM
ugahopeful34
I may just have to throw out the back half b/c the previous owner just made it to where it bolts to the top of the "tailgate"...this would crush the body if it did roll obviously, so I think I'll model mine after yours, what did all the piping set you back, and do I have the whole bar to plate to frame right?
post #238 of 1110 Old 12-26-2007, 01:07 AM
Fred99TJ
First lets correct your terminoligy. It's Tube. Most of my cage is HREW 1.75".120, but the rear is 1.5" DOM. The DOM didn't cost me enything but I had a source for it at no cost to me. The top part cost me $175 for the materials pre cut and bent and notched. All the welding I had done by a friend and I paid him $100 plus 2 rolls of welding wire so I have about $350 in this cage total including paint. Something we did, which I don't know how well it will benifit, but is wehret eh center of the stock main hoop bolts together, we loosened the bolts and once everything was welded in place we tightened them down the welded that seam so this cage is kinda "fit" to my jeep. It would still bolt into any TJ but we felt this would make it fit better into mine, and make it a little stronger.
Fred99TJ is offline
post #239 of 1110 Old 12-27-2007, 04:29 PM
ugahopeful34
what'd you paint it with?
post #240 of 1110 Old 01-31-2008, 12:29 AM
BozoWise
BozoWise's Avatar
Got my cage done.
IMG_0942 (Medium).JPG   IMG_0969 (Medium).JPG   IMG_0972 (Medium).JPG   IMG_0943 (Medium).JPG   IMG_0944 (Medium).JPG
BozoWise is offline
Official BFG KM2 thread Magus2727 Tires & Wheels 8 12-07-2008 07:44 PM
The official HID thread lib Audio, CB & Ham Radios, GPS, & Electrical 88 10-16-2005 10:00 PM
The official 4x4 video thread mnjeep General Jeep & Off-Road Equipment 37 01-04-2005 01:03 AM
OFFICIAL ** Steering Fabrication Thread ** FunkSkunk Fabrication Shop 21 04-21-2004 07:41 PM
