Off-road trailer build - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Off-road trailer build
RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBuild your Dream Jeep with Poison Spyder's Interactive Gar
Unread 06-13-2012, 12:31 AM   #1
gspup
Just so this doesn't get moved I have built a off-road trailer from scratch.
The only thing I didn't fabricate myself is the axles and leaf springs. I will start with the earliest photos I have from the build which regretfully is after the frame and tub were welded together. Well here we go...
gspup is offline   Reply With Quote
Unread 06-13-2012, 12:40 AM   #2
gspup
First photo I took was around October 2011. I had finished welding the axle to the frame, tub to the frame, and at this point had bought some pre-fab cold roll fenders.
Unread 06-13-2012, 12:45 AM   #3
gspup
Braced the inside of the tub because I wanted to be able to put an ATV on top of the trailer.
image-3770841919.jpg   image-2037246547.jpg   image-1396281266.jpg   image-21020667.jpg
Unread 06-13-2012, 12:48 AM   #4
gspup
Built a gerry can holder.
Unread 06-13-2012, 12:53 AM   #5
gspup
Formed up some runners to keep the ATV in place on-top of the trailer. I built these out of steel and would later scrap them because they were to heavy. I have since replaced them with shorter aluminum runners.
Unread 06-13-2012, 01:02 AM   #6
gspup
Between building the rails and modifying these spydertrax wheel spacers was a few months. I had sold my old TJ purchased a new one and started modifying it.
The axle I had wouldn't fit the TJ canyon rims so I bought some spydertrax wheel spacers and used the mill to cut the spacers to fit around the axle hub.
Unread 06-13-2012, 01:10 AM   #7
gspup
Now that I could put the wheeks and tires on I took the trailer for its first test run on 35's. Old fenders were removed to fit the tires. Trailer towed well.
Unread 06-13-2012, 01:21 AM   #8
gspup
Drilled some holes in the trailer lid through the supports for the aluminum ATV rails to bolt through.
image-3456362267.jpg   image-1281204337.jpg   image-1426038965.jpg   image-761020845.jpg   image-3462605091.jpg
Unread 06-13-2012, 01:24 AM   #9
gspup
Loaded the trailer with the ATV and drove it around to check how it would track. I wanted to try it behind a full size truck before my jeep.
Unread 06-13-2012, 01:33 AM   #10
gspup
You'll notice in the last photo there is almost no room for up travel which will be needed when off-road. So I had some redesigning to do. Moved the fenders higher up on the tub this is after making new ones. Took about 2 inches off the width and about the same off the length.
I aslo had to move the lock and added two more rubber tie downs.
I plug welded the holes from both previous fender designs and then sent the trailer to my powdercoater.
Unread 06-13-2012, 01:36 AM   #11
gspup
Got the trailer back from paint and added a rack on front for propane or a cooler.
Unread 06-13-2012, 01:37 AM   #12
gspup
Just wired the jeep up for the trailer.
Unread 06-13-2012, 01:39 AM   #13
gspup
Pic of the suspension.
Unread 06-13-2012, 01:44 AM   #14
gspup
Now we are up to speed, these pics were taken today. Fabbed up a multidirectional hitch. It might take awhile to install this because I will have to grind off the standard hitch receiver which will be a *****.
Unread 06-13-2012, 04:58 PM   #15
Necromancer_tat
Mall Crawler
Necromancer_tat's Avatar
Subscribing for awesome trailer build pics and ideas!
When someone tries to tell you that nothing is impossible, ask them to dribble a football!
Originally Posted by misterpookie View Post
my best recommendation is keeping a dictionary in the restroom.
word to the wise: dictionary pages are generally thin and not quilted. :nono:
Originally Posted by 1999TJRED85000 View Post
Are you on crack?
I think you're a little off. The shell on a turtle is thicker by a factor of 1.6783 while compared to the speed of a Puma, when chasing a rabbit. Therefore, if you hit a nail with a 4 lb. hammer, the thickness of the wood needs to be 4, and your grip should be on your lower regions.
Project "Wrong Way" Jeep build ----> http://www.jeepforum.com/forum/f22/p...g-way-1293197/
Project "Bassakwards" Jeep build---->http://www.jeepforum.com/forum/f22/b...build-1483076/
Necromancer_tat is offline   Reply With Quote
