NYS vehicle welding requirements...Anyone know the official rules? - JeepForum.com
 1Likes
  • 1 Post By JeeperDon
post #1 of 10 Old 05-18-2017, 03:49 PM Thread Starter
Ravenbar
Rumor has it you have to be DOT certified to weld on a vehicle frame. I can find no written proof of this anywhere. I've been searching online for weeks. The only DOT welder certificate I can find anything about is for welding on DOT Infrastructure projects.
I've got a '02 WJ and my next major undertaking is rust extermination. The Jeeps in really good shape for its age. My only welding required repair would be cutting out the rockers and welding in 2x6 tube. I may also cut a hole into the rear quarter panels behind the bumper to access inside as I've got rust issues internally up in that area as well(At least on the drivers side, not sure on passengers).
I do have a guy at work who welds commercial trucks that I could get to do it but thats not going to be cheap(He charger something like $40/hr for vehicle work, not sure on welding rate). Probably take 8-10 hours for fitment and welding + materials.
Project Thumper:
Ravenbar is offline
post #2 of 10 Old 05-18-2017, 06:30 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I've been involved with Jeepers and off-roading for 20+ years, and general garage wrenching for over 50 years. In all that time, zero people, New York (lived there for 41 years) or anywhere I've been, have ever been concerned with certifications for Jeep welding. Stop looking stuff up online and go back in the garage and fix the frame.
jason m likes this.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 10 Old 05-18-2017, 07:05 PM Thread Starter
Ravenbar
Current plan puts the welding required work at sometime in late summer or the fall. Currently project is an almost full suspension/steering rebuild and lift. Then I'll be tackling all the rusty areas. Rockers I believe will be one of the last steps of that. I wouldn't exactly call them rotted out. I've got some rust holes showing on the inners and the outers have a plastic cover but seem to be mostly there as well.
Jeep work is at a standstill due to waiting on a larger enough block of time to do the next stage(daily driver with no backup and I estimate it's going to take 3 days to get it all done, so Memorial weekends going to be busy), and waiting on funds & the last couple parts do complete that stage. Parts should have been at the store today and I'll have funds for them tomorrow(needed rear spring isolators I wasn't expecting.)
Reason for all the research is as this is my daily driver, I need it to pass inspection. Rumor is to weld a "frame" you need to be certified. AS a WJ is a uniframe vehicle(unibody that incorporates strong framerails), I wanted to get a definition of what the "frame" is(i.e. are rocker panels considered frame?).
Project Thumper:
Ravenbar is offline
post #4 of 10 Old 05-18-2017, 09:06 PM
JeeperDon
JeeperDon's Avatar
Do whatever makes you comfy, which varies for everyone. If you are concerned with work passing the NYS Safety Inspection though, I can offer you this. With my array of vehicles over time, I've received maybe 200 NYS Safety Inspections, and not one inspector even looked at frame repair, let alone ask for certifications for any work done. Good luck with your project.
Web Admin for
post #5 of 10 Old 05-21-2017, 07:20 AM
dwilliams35
Just move to a state that is more reasonable and less intrusive?
dwilliams35 is offline
post #6 of 10 Old 05-21-2017, 07:35 AM Thread Starter
Ravenbar
Already planning on it once I get enough cash in the bank to do so. Problem is I'm not even sure on the law on this as I can find nothing but rumors.
Project Thumper:
Ravenbar is offline
post #7 of 10 Old 05-21-2017, 10:04 AM
dwilliams35
. Having it on the books is one thing; in practice would be quite another. Ever actually heard of anybody checking for it during an inspection? It was probably just a legislative or regulatory gift to some welders union or something, but as far as one guy rolling into an inspection with a weld on a frame, I'd be surprised if a) they even would notice it, b) they wouldn't know the difference between it and a factory weld, and c) there's probably no mechanism for certifying that the thing was done by a certified welder anyway. Granted, I'm about as far from an expert on NY regulations as can be, but my gut feeling is that you're overthinking this.
post #8 of 10 Old 05-25-2017, 10:06 AM
bobracing
My guess is they are referring to med. and heavy duty trucks.
92 YJ
http://www.jeepforum.com/forum/f22/open-mouth-insert-jeep-2878945/
bobracing is offline
post #9 of 10 Old 05-25-2017, 10:49 AM
Shadownwpa
There is an aws welding code for vehicles but if I remember correctly it only applied to production welding when it was being manufactured. I've never even heard anyone claim to be a certified vehicle welder, and the welders I work with claim alot of things.
There's no reason a competent welder can't do your rockers like you mentioned. It's not too difficult to put down a better bead than the garbage welds the factory put on my yj. Forget the internet rumours and 'legal experts'.
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is offline
post #10 of 10 Old 05-30-2017, 05:52 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Ravenbar - I've you've ever seen any of the work that jsherb does here on the site, you may know that he lives up in Elmira and does a bunch of welding on his frames as part of his many projects. My guess is if there is anyone in NY who knows the law on welding on a frame, it would be Jeff. I bet if you sent him a PM he would be glad to offer his advice.
Jeff
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is online now
