nuts for the add-a-trunk - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > nuts for the add-a-trunk
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWe still have some great deals going on!Year End Clearance Sale! Save 20%
Unread 06-23-2005, 09:32 PM   #1
Go Juice
Sorry... hard to decide which forum this applies to, but I suppose here is as good as anything.
I am looking for help tracking down the nuts that attach to the wheelwall in the TJ that allow for the installation of the Mopar add-a-trunk. I bought it used and I only received the screws since the nuts are not removable. There used to be a guy on ebay that sold the screws and nuts but I can't find him. Does anyone happen to know an official name for these or a part number if there is? Thanks!
Go Juice is offline   Reply With Quote Quick reply to this message
Unread 06-23-2005, 10:38 PM   #2
Tdad
They're called Wellnuts. Here's what they look like
You can get them at any hardware store for a couple cents each. I don't remember which size you need, but I remember they were cheap enough that I bought 4 in about 4 different sizes.
You insert them into the holes, the screw catches the brass insert and pulls it back, mushrooming the rubber sleeve and effectively clamping it from the back side.
Hope this helps!
Tdad is offline   Reply With Quote Quick reply to this message
Unread 06-25-2005, 08:56 AM   #3
Go Juice
Thanks for the help.
So I don't neccessarily need the hex shaped well nut?
Unread 06-26-2005, 07:01 PM   #4
Tdad
Hex shaped? The ones I used are like the ones in the pic I linked.
Unread 06-27-2005, 08:14 PM   #5
Go Juice
OK... just wondering because the pre-drilled holes in my jeep are hex shaped. And the guy that used to sell them on ebay actually sold hex shaped nuts.
Unread 06-30-2005, 09:16 PM   #6
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Aw come on, round peg square (sorta) hole, you're a jeeper get a BFH and make it fit...
schitzangiggles is offline   Reply With Quote Quick reply to this message
Unread 12-21-2014, 10:18 AM   #7
rnitrox
brass well nuts. looking myself. Ive found rubber ones at hardware stores but not the actual parts. Started contacting best top and quadratec but haven't heard anything yet. GFood luck.
rnitrox is offline   Reply With Quote Quick reply to this message
Unread 12-21-2014, 10:48 AM   #8
rnitrox
I was going to try the round ones if qudratec, Jeep or smittybilt fails.
