NP231 Tail Shaft Leak Fix - Page 4 - JeepForum.com
 1Likes
post #46 of 47 Old 11-11-2013, 06:23 AM
87yjchris
1987 YJ Wrangler
Thanks for the writeup.I found this after a couple of seal replacements. I have a new bushing and seal. Going to have a local shop press in the new bushing and might as well do the u joints to.
87yjchris is offline
post #47 of 47 Old 03-09-2014, 04:27 PM
johnwalsh47
tailshaft seal/bushing R&R
Another thing you might try is heating the tailshaft with a propane torch which will expand the aluminum and soften the seal's OD to allow it to pop out easily. This will often help with the bushing removal as well. When going back together, heat housing a bit less (like with a hair dryer on high) and chill bushing in the freezer. Heated housing will expand and chilled bushing will contract, allowing an easier press fit.
johnwalsh47 is offline
Where can I find a 23 spline input shaft?(NP231) crf450ish Engines & Drivetrain 12 10-08-2013 07:52 PM
Output Shaft for NP231 Replacement AaronClement Engines & Drivetrain 6 01-06-2010 05:26 PM
early NP231 INPUT shaft 23spline crf450ish Engines & Drivetrain 2 09-23-2009 06:09 AM
NP231 output shaft housing question? Tigger3258 Engines & Drivetrain 1 09-30-2007 11:04 PM
oil leak from distributer shaft jmsjeep Engines & Drivetrain 2 10-15-2001 11:20 AM
