Newbie shopping for mig welder with questions - JeepForum.com
post #1 of 5 Old 02-07-2014, 03:22 PM Thread Starter
krazymatt
What size of tank should I get for a Hobart Handler 140 Mig? The main purpose of this mig welder will be to do some patch panel repair on an old chevy pickup.
krazymatt is offline
post #2 of 5 Old 02-07-2014, 05:25 PM
tjcj
You would probably be fine with a 10lb tank.
Sent from my XT881 freeze ray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #3 of 5 Old 02-07-2014, 05:40 PM
my-jeep-earl
1971 CJ5
A 80 cubic foot cylinder will give you 4 hrs. of straight welding @ 20 cfh flow, a 60 CF is about 3 hrs. A 10lb tank sounds like straight CO2? You'll get cleaner welds with AR/CD mix, just a thought!
my-jeep-earl is offline
post #4 of 5 Old 02-07-2014, 06:28 PM
AtTheHelm
Get the biggest one you can afford.
I just use straight C02 in a 25lb cylinder that lasts seemingly forever, probably 40-50 lbs of 0.035 wire.
I started out using a 20cf cylinder of c25 mix, but it only lasts about 5-6 lbs of 0.035 wire.
Straight C02 works well and does produce good welds, but c25 is a tad better.
AtTheHelm is offline
post #5 of 5 Old 02-07-2014, 07:59 PM Thread Starter
krazymatt
Thanks for the info guys!
