newb question - JeepForum.com
post #1 of 3 Old 07-16-2011, 11:49 AM Thread Starter
yjhunter
newb question
i have a 90 yj laredo and after doing alot of browsing around here, i was wondering, the easiest looking(and cheapest) way to lift my yj would be to put the axels under the springs. but is it safe to do that? i really dont know a thing about lifts and things like that. and if i was to do that would the driveshaft in the rear have too much angle? i mean is it really that simple, just put the axel under instead of over the leafs?
yjhunter is offline
post #2 of 3 Old 07-16-2011, 11:59 AM
Jeep_tj_97
you would have more help in the YJ section!
Jeep_tj_97 is offline
post #3 of 3 Old 07-16-2011, 01:00 PM
Kettles
The YJ section would be approprite. However a SOA (spring over axle) conversion is extremely common. Lots of vehicles come stock with a SOA setup, including XJ's. The problem with a YJ is the front is also a leaf spring suspension, and you would have steering interference with a SOA axle without some type of high steer setup, which is why (at least one reason) they came that way from the factory.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
newb question dumcheesemonkey General Jeep & Off-Road Equipment 10 04-06-2011 12:36 AM
Newb question 1999sport Tires & Wheels 2 05-13-2008 09:02 AM
NEWB wiring question Smoke6 Audio, CB & Ham Radios, GPS, & Electrical 5 06-09-2007 10:14 PM
newb question frumpy Tires & Wheels 4 12-01-2006 01:11 PM
Newb question... Wulfram Tires & Wheels 2 07-11-2005 06:01 PM
