New Tire Carrier - JeepForum.com
post #1 of 9 Old 07-09-2007, 02:52 PM Thread Starter
Border Dave
Got Sand?
Border Dave's Avatar
New Tire Carrier
Hey, check out what a friend of mine made for his JK:
What do you think about it?
Border Dave is offline
post #2 of 9 Old 07-09-2007, 04:24 PM
BigDaddyChoice
Looks good. I like that the carrier has a bit of an angle for departure, but the weight of the tire still rests on the tailgate. Ideally, it would be best to take the weight off your tailgate and onto your frame.
If you don't intend to get bigger tires than stock, then you're good to go. However, if/when the inevitable calling for bigger surfaces, you may want to rethink your tire-carrier options.
FUGIT IRREPARABILE TEMPUS... CARPE DIEM!
"Drive it there, wheel it, drive it home"
JEEP OBSESSION: Testing the limits of financial stability.
Windtunnel failed since September, 2000
BigDaddyChoice is offline
post #3 of 9 Old 07-09-2007, 04:38 PM
Ohenry13
nicely done sir.
the rally look is awesome
Ohenry13 is offline
post #4 of 9 Old 07-09-2007, 05:52 PM
bairy
Looks good, nice fab work, nice touch with the waterjet/laser logo, But I severely question the strength of the tailgate. Having the tire sit that far off the body adds more torque to the mounts(bad)
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #5 of 9 Old 07-09-2007, 08:13 PM Thread Starter
Border Dave
Got Sand?
He used a CNC plasma cutter ($15,000 Plasma Cam) to cut the logo into it.
post #6 of 9 Old 07-09-2007, 08:39 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Yeah.. kind of far off the tailgate but it sure looks good! Can you take a closeup of the logo?.. I'd like to see how clean that plasma cut it. I'm hoping to pick up a CNC plasma table before too long.
Edit: I just went back and looked at the setup again.. it appears that all 4 arms are cut from flat plate? If so, that carrier will buckle if you bump the spare into something (like a tree while offroading..etc.). I'd be willing to bet money that they would buckle.. right where the logo is cut. Angle iron or tube would be stronger but if the rig is only going to see light trail riding it shouldn't be a problem.
BESRK is offline
post #7 of 9 Old 07-09-2007, 11:47 PM Thread Starter
Border Dave
Got Sand?
I'm pretty sure he's mostly going to wheel it in the sand dunes and maybe some mud. If he doesn't read this post, I'll be sure to address the strength issue with him about the support arms.
post #8 of 9 Old 07-10-2007, 08:46 AM
bairy
I would think the tailgate would flex a lot more before the mount. But if I had a CNC plasma cutter, I would surely make something more substantial and adjustable.
But who am I? I don't even own a welder anymore.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #9 of 9 Old 07-10-2007, 08:58 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I think we should make a friendly wager on this.. say.. $1.00. Now, I need you to back that into a tree until either the carrier bends or the tailgate folds. I'll cut you in on 1/2 of my take..
BESRK is offline
Largest Tire on a Stock Tire Carrier wcusoccer0422 General Jeep & Off-Road Equipment 4 11-01-2008 11:21 AM
You can safely fit a 33" tire on the stock tire carrier on door CB3 Tires & Wheels 35 04-27-2008 01:46 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
32x11.5 tire on stock tire carrier TheDiabetic Tires & Wheels 5 05-10-2006 03:19 PM
Difference between LoD extreme duty tire carrier/Heavy Duty tire carrier djaychris General Jeep & Off-Road Equipment 7 12-18-2005 09:53 AM
